Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > Cruiser Suite
Old 02-08-2010, 06:07   #1 (permalink)
Member: 76614
Thanks Meter: 29
How to Rrmove PERSONAL Security Passwords on W580i CID53
Please help:
I used SE A1 Fast Java Unlocker
But this does not reset the user passwords to "0000"
Please reply especially if you have first hand experience with this problem.
I can search the Cruiser forum for some reason for quite some time. Is there a trick to searching Cruiser forum here.
Thanks;
Old 02-08-2010, 06:12   #2 (permalink)
Member: 1109337
Thanks Meter: 197
http://www.ultimate-unlocker.com/web...%20and%20Reset
Old 02-08-2010, 06:25   #3 (permalink)
Member: 76614
Thanks Meter: 29
Do I need server credits ?
  21:23:10  SE Ultimate Unlocker v5.04 by Cruiser Team
  21:23:10  - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change
  21:23:10  Initializing...
! 21:23:12  1. Please see the documentation first (the tab 'Info' or attached .pdf file)
! 21:23:12  2. Choose the phone model
! 21:23:12  3. Select the desired options
! 21:23:12  4. Please connect the phone either via USB while holding 2-5…
! 21:23:12  - or via a serial cable and double-click on it in the device list
  21:23:57  Selected phone: W580
  21:23:57  Connecting via Generic EMP USB Flash Device (USB1)…
  21:23:57  Device driver version: 2.2.0.2
  21:23:57  Device driver date: 12-5-2008
  21:23:58  Connecting to the baseband CPU...
  21:23:58  Entering baseband CPU service mode...
  21:23:58  Detected chipset: DB2020
  21:23:58  Boot mode: ROM
  21:23:58  Sending loader...
  21:23:58  IMEI: 35256002837839
  21:23:58  OTP CID: 51
  21:23:58  Effective CID: 53
  21:24:00  Please reconnect the phone (disconnect, connect while holding 2-5)
  21:24:16  Sending loader...
  21:24:16  Communicating with server…
E 21:24:19  Error: 0xF984FBBB
E 21:24:19  Error data: 0xF984FBBB - 00000004:1F000000
E 21:24:19  Error: 0xD0EA59C1
E 21:24:19  Error: 0x659FFCB8
E 21:24:19  Error: 0x523901CA
E 21:24:19  Error: 0x5C5AEBE3
E 21:24:19  Error: 0x3D35EAF1
E 21:24:19  Error: 0x07F5EFDA
E 21:24:19  Error data: 0xF984FBBB - 00000004:E3030000
E 21:24:19  Your account has not been activated yet
E 21:24:19  Login to server failed
E 21:24:19  Failed!
! 21:24:19  To report errors right-click this window
Old 02-08-2010, 06:44   #4 (permalink)
Member: 76614
Thanks Meter: 29
got it.
Run Cruiser 13.21
Go to Settings -- Server and enter your cruiser server account passwirds.
Attach phone
Click Locks Tab
Click Clear Passwords.
System diagnostics passed.
Version 13.21 ready!
[ --- Attach to Phone --- ]
Connecting via SEMC DCU-60...
Connect the phone while holding its C button!
USB connection established.
Baseband chip ID: 0x9900
Protocol version: 3.1
Booting via EROM...
Sony Ericsson phone detected.
Phone CID: 53
Phone color: Red
EROM version: R3A022
Trying CID53 recovery applet...
Sending applet prologue...
Sending applet body...
Time spent entering bootstrap: 0s
Initializing phone hardware...
Applet ID: 070703 1229 NPA4_CXC1329130_DB2020_...
Flash manufacturer: Intel
Flash ID: 0x897E
OTP Security Level: 1 (Retail)
OTP CID: 51
Phone CID: 53
Phone color: Red
Sending applet...
Applet ID: 071120 1355 HANCXC9876543210_DB2020...
Sending applet...
Applet ID: 080108 1810 ESGCXC1329129_DB2020_FL...
RSA protection state cannot be determined for this CID.
Phone hardware initialized OK
[ --- Clear Phone Lock --- ]
Sending CS applet...
Applet ID: 070904 1245 AN2CXC1250562_DB2020_CS...
Initializing CS applet...
Starting up GDFS service...
Clearing phonelock...
Done.
procedure on how to reset mx-key password amats211 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 0 02-22-2010 16:02
iPhone | How to Change the Root Password on Your iPhone 00aa iPhone 2 / iPhone 3G / iPhone 3GS 0 11-03-2009 11:04
how to use a BTS? (Report on the security of the french GSM network) initial GSM Programming & Reverse Engineering 5 12-13-2006 18:55
how to reset sim lock password on E800?please ramos SYSOL Platform 3 01-15-2005 10:06
how to bypass telephone/security lock on mc922 shawn Infineon C16X M51 & ARM7 M52 BASED 3 05-12-2002 08:38
Page generated in 0.17935 seconds with 9 queries
