10-10-2008, 14:23 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Location: Georgia GE
Member: 162473 Status: Offline Sonork: Not have Thanks Meter: 592 | how tu repair K770 with cruiser if with setool identifyed as K700 Open COM port OK ChipID:9900,EMP protocol:0301 Speed:921600 Flash ID check:897E Flash props sent ok OTP LOCKED:1 CID:51 PAF:1 IMEI:************ CERT:N/A FLASH CID:52 COLOR:RED Model:K700 MAPP CXC article: R8BA024 prg1201-7587_GENERIC_VI MAPP CXC version: R8BA024 Language Package:BALTIC CDA article: CDA102568/1 CDA version: R7A Default article: 1201-7603 Default version: R8BA024 PROVIDER: 000-00 SIMLOCKS NOT DETECTED RESTORATION FILE PRESENT FOR DETECTED FIRMWARE BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE Elapsed: 8 secs. Step by step. Please help me |
10-10-2008, 14:34 | #2 (permalink) |
Member: 162473 Status: Offline Sonork: Not have Thanks Meter: 592 | here log with SE Ultimate Unlocker Code: 17:28:56 SE Ultimate Unlocker v2.01 by Cruiser Team 17:28:56 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 17:28:56 Initializing... ! 17:28:56 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 17:28:56 2. Choose the phone model ! 17:28:56 3. Select the desired options ! 17:28:56 4. Please connect the phone either via USB while holding 2-5… ! 17:28:56 - or via a serial cable and double-click on it in the device list 17:30:00 Selected phone: K770 17:30:00 Connecting via SEMC USB Flash Device (USB1)… 17:30:00 Device driver version: 2.0.0.4 17:30:00 Device driver date: 9-12-2007 17:30:01 Connecting to the baseband CPU... 17:30:01 Entering baseband CPU service mode... 17:30:02 Detected chipset: DB2020 17:30:02 Boot mode: EROM E 17:30:32 Error: 0x9D2F2420 E 17:30:32 Error: 0xAE24C00E E 17:30:32 Error: 0xEB80927F E 17:30:32 Error: 0xEB4BD9D2 E 17:30:32 Error: 0x889C690F E 17:30:32 Failed! ! 17:30:32 Please disconnect battery and cable from the phone! ! 17:30:32 To report errors right-click this window |
10-10-2008, 19:37 | #3 (permalink) | |
No Life Poster Join Date: Mar 2005 Location: lets See.
Member: 128918 Status: Offline Thanks Meter: 282 | Quote:
use 2+5 to connect not C | |
10-11-2008, 06:46 | #5 (permalink) |
Freak Poster Join Date: Jun 2007 Location: Proud 2b Pinoy
Member: 534932 Status: Offline Thanks Meter: 49 | in cruiser, 1. select correct phone type. 2. then go to boot type select identify. 3. cllick attached phone. 4. power on unit. wait until unit attached. |
10-11-2008, 07:06 | #6 (permalink) |
Member: 162473 Status: Offline Sonork: Not have Thanks Meter: 592 | [ --- Attach to Phone --- ] Connecting via Fighter USB Cable... Powering on the phone... Baseband chip ID: 0x9900 Protocol version: 3.1 Baudrate = 460800Bd Booting via ROM... Trying SEMC ID applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 1s Initializing phone hardware... Applet ID: 070129 0950 NGUCXC1250330_DB2020_PR... Flash manufacturer: Intel Flash ID: 0x897E OTP Security Level: 1 (Retail) OTP CID: 51 Phone CID: 52 Phone color: Red Phone type (from GDFS): K700 CXC article: R8BA024 prg1201-7587_GENERIC_VI CXC version: R8BA024 Language package: BALTIC Turning off phone... Terminating threads... All threads terminated. |
10-11-2008, 08:48 | #7 (permalink) |
Member: 163076 Status: Offline Thanks Meter: 97 | ok do it now. select correct gdfs in bin format in misc mark format gdfs in settings click write gdfs flash main+fs post identify log afterwards. do all operation with tool u messed it ;P |
10-11-2008, 15:02 | #11 (permalink) |
Super Moderator Join Date: Aug 2005 Location: UK.... Age: 57
Member: 173077 Status: Offline Sonork: 100.1594293 Thanks Meter: 2,784 | Look,, Flash correct GDFS with CRUISER, Via main.. useing cruiser 13.20.. Then attach with ULTIMATE UNLOCKER, and Make sure Security Rebuild Box is Checked. |
10-11-2008, 17:37 | #12 (permalink) |
No Life Poster Join Date: Oct 2007 Location: South Africa/Pakistan
Member: 619308 Status: Offline Sonork: 100.1591829 Thanks Meter: 243 | i also have one k850 its vibrate and show light and keep doing like that and secreed dardk noting on it i flashed with setool and then unlock with ultimate unlocker but still same i tick securty zone rebuld option . but i didn write any gdfs on it. coz i hade one k810 phone with gdfs problem and fixed just by unlock with ultimate unlocker no need to write gdfs. but this phone is not ok would any one help me how to fix this problem plz with ultimate unlocker 10/10/2008 2:30:36 PM v0.914040/UNI 10/10/2008 2:30:36 PM CARD SERIAL: 00064467 10/10/2008 2:30:36 PM Loaded 51 flash descriptors 10/10/2008 2:34:21 PM SIGNED MODE (USING SERVER). 10/10/2008 2:34:33 PM ChipID:C802,EMP protocol:0401 10/10/2008 2:34:33 PM 10/10/2008 2:34:33 PM PHONE IS RED RETAIL PRODUCT 10/10/2008 2:34:33 PM FLASH CID detected:52 10/10/2008 2:34:34 PM OTP LOCKED:1 CID:52 PAF:1 IMEI:35182902952757 CERT:RED 10/10/2008 2:34:35 PM LDR:2008-07-23 12:03 CXC1250843_DB31XX_CS_LOADER_ACC_SDRAM_R2A065 10/10/2008 2:34:35 PM LDR CAPS:SYSTEM FLASH SIGNATURE AUTH 10/10/2008 2:34:37 PM LDR:2008-07-23 12:03 CXC1250780_DB31XX_CS_LOADER_APP_SDRAM_R2A065 10/10/2008 2:34:37 PM LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA 10/10/2008 2:34:37 PM writing C:\Program Files\setool2g\flash file\k850\R1EA037_APP_SW_1200_4394_VODAFONE_SO_RED BROWNBLUE_CID52_49_DB3150.software.cry 10/10/2008 2:34:51 PM ALLOWED DOMAINS:BLUE BROWN RED 10/10/2008 2:34:51 PM MAXIMUM CID:52 10/10/2008 2:34:51 PM Will flash 697 blocks... 10/10/2008 2:42:04 PM ssw file accepted 10/10/2008 2:42:04 PM writing C:\Program Files\setool2g\flash file\k850\R1EA037_FS_APAC_ANZ_SO_REDBROWNBLUE_CID5 2_49.software.cry 10/10/2008 2:42:15 PM ALLOWED DOMAINS:BLUE BROWN RED 10/10/2008 2:42:15 PM MAXIMUM CID:52 10/10/2008 2:42:15 PM Will flash 497 blocks... 10/10/2008 2:47:22 PM ssw file accepted 10/10/2008 2:48:29 PM writing tpa/preset/custom/CONTENT_DOWNLOAD_HOOK.itm 10/10/2008 2:48:30 PM writing tpa/preset/custom/FM_PICTURES_HOOK_3.itm 10/10/2008 2:48:30 PM writing tpa/preset/custom/FM_SOUNDS_HOOK_3.itm 10/10/2008 2:48:30 PM writing tpa/preset/custom/FM_THEMES_HOOK_3.itm 10/10/2008 2:48:30 PM writing tpa/preset/custom/FM_VIDEOS_HOOK_3.itm 10/10/2008 2:48:30 PM writing tpa/preset/custom/GAMES_HOOK_3.itm 10/10/2008 2:48:30 PM writing tpa/preset/custom/MC_MUSIC_HOOK_3.itm 10/10/2008 2:48:31 PM writing tpa/preset/custom/MC_PHOTO_HOOK_3.itm 10/10/2008 2:48:32 PM writing tpa/preset/custom/MC_VIDEO_HOOK_3.itm 10/10/2008 2:48:32 PM writing tpa/preset/custom/ORG_APPLICATIONS_HOOK_3.itm 10/10/2008 2:48:32 PM writing tpa/preset/custom/preloaded_config.xml 10/10/2008 2:48:34 PM writing tpa/preset/custom/SETT_RINGTONE_HOOK_1.itm 10/10/2008 2:48:34 PM writing tpa/preset/custom/SETT_SCREENSAVER_HOOK_1.itm 10/10/2008 2:48:34 PM writing tpa/preset/custom/SETT_STARTSHOW_HOOK_1.itm 10/10/2008 2:48:34 PM writing tpa/preset/custom/SETT_WALLPAPER_HOOK_1.itm 10/10/2008 2:48:35 PM writing tpa/preset/custom/Customize.xml 10/10/2008 2:48:36 PM Phone detached 10/10/2008 2:48:38 PM Elapsed: 856 secs. |
10-11-2008, 19:40 | #13 (permalink) |
Member: 173077 Status: Offline Sonork: 100.1594293 Thanks Meter: 2,784 | If it is a GDFS, issue then Write an alien gdfs to it, once this is done phone is Dead, (this is Normal) Now attach to Ultimate Unlocker and rebuild security zone... You own Setool, you may find its Easier to Write GDFS with that, (i do) |
Sony Ericsson Z750 Identify as K700 help | ASHRIFF | SETool2 | 10 | 02-05-2010 18:39 |
how to repair gdfs K800i cid 53 with setool | ..::proudcracker::.. | SETool2 | 1 | 10-25-2009 11:48 |
K610 CID52 RED white blinking - identified as K700 | R@jusat | SETool2 | 7 | 07-14-2009 06:49 |
k800 identified as k700 | garguantan | SETool2 | 6 | 04-25-2009 07:17 |
how to repair erom k800i cid 49 with setool. | toutou_gsm | Sony Ericsson | 7 | 03-02-2008 08:02 |
