10-10-2005, 17:05 | #1 (permalink) |
Freak Poster Join Date: Dec 2004 Age: 51
Member: 96593 Status: Offline Thanks Meter: 13 | HOW to unlock K608i and convert to brown OTP CID: 37 Phone hardware initialized OK Analyzing configuration... Reading primary certificate... Primary certificate CID: 37 Primary certificate color: Red Reading secondary certificate... Secondary certificate CID: 36 Secondary certificate color: Brown OSE configuration found. Analysing GDFS... Done. Analyzing RSA protection... RSA protection is weak. RSA protection weakness type: PERMANENT You have to convert the phone to brown first! You have to convert the phone to brown first! |
10-10-2005, 20:39 | #2 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 72567 Status: Offline Thanks Meter: 8 | How to convert a V600i/K608i to K600i?
Go to Security RSA area, replace certificate to brown CID 37 then do the rest as listed. If only onlycking is wanted convert to brown 37, direct unlock and convert back to red 37 Last edited by MG77; 10-11-2005 at 21:06. |
10-11-2005, 18:45 | #6 (permalink) | |
No Life Poster Join Date: Jun 2005 Location: Computer Age: 41
Member: 154696 Status: Offline Thanks Meter: 16 | Quote:
10-12-2005, 02:08 | #9 (permalink) | |
No Life Poster Join Date: Sep 2005 Location: Melbourne / Australia Age: 47
Member: 177834 Status: Offline Thanks Meter: 1,800 | Quote:
k750i is cid37 u don need 2 convert it back 2 red but with k608i which is cid 42 , u have 2 convert it back 2 red br | |
10-12-2005, 06:40 | #10 (permalink) |
Freak Poster Join Date: Jun 2003
Member: 31066 Status: Offline Thanks Meter: 0 | It's strongly recommended to convert every phone back to red. If you don't do that phone won't be recognized on EMMA. No normal Service Point can flash such phones. If you attach a brown phone to EMMA "product not supported" appears. Mickey09 |
10-12-2005, 07:41 | #11 (permalink) | |
Member: 72567 Status: Offline Thanks Meter: 8 | Quote:
K750i/D750i/W800i is sofar CID 36 | |
10-12-2005, 13:06 | #12 (permalink) |
Freak Poster Join Date: Jan 2005 Age: 53
Member: 103635 Status: Offline Thanks Meter: 86 | Tony To unlock K608i with the cruiser program attach the phone use RSA first ans then you convert to brown, unlock direct when it finish attach the phone convert to red. |
10-13-2005, 09:48 | #14 (permalink) |
Freak Poster Join Date: Feb 2003 Age: 42
Member: 22109 Status: Offline Thanks Meter: 0 | @Lead Is it true that an unlocked SE phones should be converted back to red when it has been unlocked or an SE Service Center won't repair the phone under warranty? In the cruiser.chm file the section regarding conversion from brown to red is called obsolete. Thanks in advance Best regards Martin |
10-13-2005, 10:03 | #15 (permalink) | |
Member: 31066 Status: Offline Thanks Meter: 0 | Quote:
EMMA2 for normal SPs without advanced services can't boot such brown phones. Mickey09 | |
How to unlock K608i and work in 2G network | amehdi | Cruiser Suite | 1 | 06-05-2006 17:04 |
