03-20-2008, 19:17 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Pakistan Age: 33
Member: 323959 Status: Offline Sonork: 100.1613721 Thanks Meter: 79 | how to unlock k800 i have k800 cid52 red i try flash setool but after flash phone insert corect sim card any one tell me how to unlock it with cruiser i have setool /cruiser |
03-20-2008, 19:37 | #3 (permalink) |
Banned Join Date: Aug 2005 Location: GPGIndustries Age: 41
Member: 168237 Status: Offline Thanks Meter: 15 | Download latest firmware for your phone (ARM and FS file). Open USB cable window in Cruiser. In Primary tab -> Attach phone. Flash -> Write raw FS Security RSA -> Unlock RSA Flash -> Flash ARM Locks -> Direct unlock Flash -> Select language pack and firmware version matching FS flash file Customize FS on set****l Use DCU-60 cable. Procedure: 1. identify phone first by ticking "Identify" button. 2. goto "settings" tab then tick "use server for csca flash/unlock and empty user/password section 3. write this misc. files "DB2020_CID49_51_to_CID52" then tick "write script" * you can find this file in script folder 4. tick "identify" button again and the result is like this Now your phone is cid52... The phone is ready to unlock.. Unlocking Procedure: 1. In "Settings" Tab tick "Complete phone after flash", "Unlock After Flash", "Use sever for csca unlock/flash", "Enable alternative security bypass" and empty user/password area. 2. Add flash files Main & fs (you need to put main & fs files if you don't have the same files that the phone is presently using, but if you have files then you can use the main file only.) 3. then click "Flash" button and follow all instructions and wait until it finished. |
03-20-2008, 19:41 | #4 (permalink) | |
Member: 323959 Status: Offline Sonork: 100.1613721 Thanks Meter: 79 | Quote:
i try but security rsa > unlockrsa invisibal security rsa > restore firmware visibal i try restore firmware but show this message log here System diagnostics passed. Version 13.01 ready! [ --- Attach to Phone --- ] Connecting via Fighter USB Cable... Powering on the phone... Baseband chip ID: 0x9900 Protocol version: 3.1 Baudrate = 460800Bd Booting via ROM... Trying CID52 recovery applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 2s Initializing phone hardware... Applet ID: 061220 1711 NPA4_CXC1329130_DB2020_... Flash manufacturer: ST Microelectronics Flash ID: 0x2019 OTP Security Level: 1 (Retail) OTP CID: 49 Phone CID: 52 Phone color: Red Sending applet... Applet ID: 061205 1523 HANCXC9876543210_DB2020... Sending applet... Applet ID: 061201 1314 HANCXC1329129_DB2020_FL... RSA protection state cannot be determined for this CID. Phone hardware initialized OK [ --- Restore Firmware --- ] Waiting for the phone to turn off... Should the communication hang, reinsert battery. Baudrate = 460800Bd Sending applet prologue... Sending applet body... Waiting for acknowledge... no responce ? any idea | |
03-20-2008, 21:05 | #12 (permalink) | |
Product Supporter Join Date: Mar 2007 Location: GSD Pro (Dongle) Age: 38
Member: 460762 Status: Offline Sonork: 100.1592082 Thanks Meter: 3,104 | Quote:
from setting menu, have u check these given below option from setting Tab . . . ? 1:Complete phone after flash. 2:Unlock after flash 3:Use server for CSCA Unlock/Flash 4:Enable alternative security bypass If u will skip anyone of them, so ur phone will not unlock. B.R., kashi4gul | |
03-21-2008, 04:00 | #14 (permalink) | |
No Life Poster Join Date: Dec 2007 Location: Beside U Age: 37
Member: 647414 Status: Offline Thanks Meter: 127 | Quote:
No Need Logs........ Dis Is For Unlocking Prosedure For Cruiser CID 49/51/52 patch unlocking 1. For unlocking you can use only DCU-60 cable. 2. Download latest firmware for your phone (ARM and FS file). Open USB cable window in Cruiser. 3. In Primary tab -> Attach phone. 4. Flash -> Write raw FS 5. Security RSA -> Unlock RSA 6. Flash -> Flash ARM 7. Locks -> Direct unlock 8. Flash -> Select language pack and firmware version matching FS flash file 9. Customize FS 10. Main tab -> Turn off phone Best Regard WinD | |
The Following User Says Thank You to WinD_VteC For This Useful Post: |
03-21-2008, 11:40 | #15 (permalink) | |
how to unlock k800? | jmecherul | Sony Ericsson | 3 | 04-18-2007 20:16 |
how to unlock k800 securuty code not simlock? | ebu mohammed-emin | Universalbox | 2 | 02-11-2007 02:41 |
How To Unlock K800 | wichaigul | Universalbox | 1 | 01-05-2007 18:34 |
how to unlock k800 db2020 | men | Sony Ericsson | 2 | 12-08-2006 11:18 |
How to unlock K800? | jires | Sony Ericsson | 5 | 12-03-2006 20:51 |
