12-14-2007, 22:28 | #1 (permalink) |
Freak Poster Join Date: Jan 2007 Location: Ghana-Ashanti-Kumasi
Member: 434980 Status: Offline Thanks Meter: 6 | Flashing D750i error Applet error: ERROR|EraseBlock| 04 FF FF 7F 45 Error flashing block at address: 0x45820000 Script error: Flash error [13.01.78] |
12-14-2007, 23:20 | #2 (permalink) |
Super Moderator Join Date: Aug 2005 Location: UK.... Age: 57
Member: 173077 Status: Offline Sonork: 100.1594293 Thanks Meter: 2,784 | is this 750, a cid 49, unlock RSA then flash the filesystem, customise filesystem Restore firmware,, BUT if you have changed Version, i advise you to Flash a new Main(arm) to match Filesystem. flash main last if you flash both FS & main. |
12-15-2007, 11:52 | #4 (permalink) |
Member: 173077 Status: Offline Sonork: 100.1594293 Thanks Meter: 2,784 | turn the certifaite Brown, direct unlock it. then do the Flashing, you can flash main first, filesystem last,, Make sure Battery is Fully charged. |
error flash 6500c ..error white d blok | berlinsanto | HWK | 11 | 09-16-2011 15:51 |
Flashing D750i FS Problem | Cobbysyms | Cruiser Suite | 2 | 12-24-2007 18:50 |
flashing D750i | mazhar_rehman | Sony Ericsson | 1 | 05-17-2006 14:52 |
How Flashing D750i with Davinci and finalize with semctool v 1.218. | schlecker-1 | Sony Ericsson | 4 | 12-25-2005 04:52 |
Maxon 7922 Flash Write Error at 101000 ??? While Flashing UNLOCKED Flash File | Aamir_Zia | Redbox | 8 | 12-09-2004 19:11 |
