12-29-2007, 07:10 | #1 (permalink) |
Freak Poster Join Date: Sep 2007 Location: Indonesia Age: 41
Member: 584778 Status: Offline Thanks Meter: 78 | How to unlock w580i with Cruiser I have a few question. I Install the latest Cruiser ver. 13.01 and I haVE THIS W580i for unlock it. I connect the phone and attached it, but there I got only few function active. See picture attached . Questions : 1. Is it possible to unlock this model with cruiser yet? 2. If it is, how can I get function REMOVE RSA and DIRECT unlock 3. The phone has applet ID = CXC1329130, on cruiser support site only CXC1123364 exist, can I flash it with that one? 4. Will I get extra functions when I Write RAW FS? give me solution and step by step when cruiser working with this phone Thanks in advance for any answers or suggestions. |
12-29-2007, 13:54 | #2 (permalink) |
Super Moderator Join Date: Aug 2005 Location: UK.... Age: 57
Member: 173077 Status: Offline Sonork: 100.1594293 Thanks Meter: 2,784 | 07 card, and valid account, even though cid52 is free. tick free 52 unlock on server tab. Flash it with any firmware, MAIN and Filesystem. W580 (that is) unlock before you customise. |
12-30-2007, 22:55 | #4 (permalink) |
Freak Poster Join Date: Jan 2005 Location: With My !!!?
Member: 107069 Status: Offline Thanks Meter: 31 | Man u have to follow the insturaction that i will post first u hane to check that u have phone with CID 52 so if u have it u do that open ur cruiser go to setting - server - check unlock db2020 for free so connect ur phone with dcu-60 cable and do that 1 - flasah file system 2 - unlock rsa and follow the introducation for remove battery and insert it again 3 - flash main 4 - customize file system 5 - direct unlock 6 - than the phone automatacly deattached so ur phone will be unlock note if ur phone with CID51 - 50 - 49 u have to upgrade the gdfs to cid 52 how to ? attach phone with dcu-60 cable go to gdfs tab check upgrade to cid 52 then push the button modify gdfs than deattach the phone remove battery for 5 minutes reconnect again and ur phone will be cid 52 and do the unlock steps br |
12-31-2007, 08:15 | #5 (permalink) | |
Freak Poster Join Date: Dec 2007 Location: karachi
Member: 656238 Status: Offline Thanks Meter: 1 | Quote:
thank you very much i unlocked k610i without any problem | |
12-31-2007, 15:07 | #6 (permalink) | |
Member: 173077 Status: Offline Sonork: 100.1594293 Thanks Meter: 2,784 | Quote:
unlock it before you customise it. | |
01-10-2008, 13:54 | #8 (permalink) |
Freak Poster Join Date: Jul 2003 Location: india Age: 40
Member: 35563 Status: Offline Thanks Meter: 4 | thats wat u have to customize it first..... once u do that everything will be fine |
The Following User Says Thank You to cliffrock4u005 For This Useful Post: |
01-18-2008, 02:13 | #9 (permalink) |
Junior Member Join Date: Mar 2007 Location: Canada and USA
Member: 479438 Status: Offline Thanks Meter: 0 | Failed! on RSA Unlock System diagnostics passed. Version 13.01 ready! Do NOT connect the phone at this time! [ --- Attach to Phone --- ] Connecting via SEMC DCU-60... Connect the phone while holding its C button! USB connection established. Baseband chip ID: 0x9900 Protocol version: 3.1 Booting via EROM... Sony Ericsson phone detected. Phone CID: 52 Phone color: Red EROM version: R3A022 Trying CID52 recovery applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 0s Initializing phone hardware... Applet ID: 061220 1711 NPA4_CXC1329130_DB2020_... Flash manufacturer: Intel Flash ID: 0x897E OTP Security Level: 1 (Retail) OTP CID: 51 Phone CID: 52 Phone color: Red Sending applet... Applet ID: 061205 1523 HANCXC9876543210_DB2020... Sending applet... Applet ID: 061201 1314 HANCXC1329129_DB2020_FL... RSA protection state cannot be determined for this CID. Phone hardware initialized OK [ --- Flash Raw File System --- ] Flash file: "W580i_CXC1123364_Europe1_R8BA024_Red52.cw58fs " Waiting for flash file to load... Preparing to program flash... Programming flash... Time: 00:01:46 Flash process done. [ --- Unlock RSA --- ] Preparing to program flash... Programming flash... Time: 00:00:21 Flash process done. Preparing to program flash... Programming flash... Time: 00:00:03 Flash process done. Sending CS applet... Applet ID: 070410 1557 HANCXC1250562_DB2020_CS... Initializing CS applet... Starting up GDFS service... Starting up filesystem, please wait... Removing RSA lock... Restarting phone... Connect the phone while holding its C button! Failed! Is-it normal ? |
01-23-2008, 17:12 | #10 (permalink) |
No Life Poster Join Date: Oct 2003 Location: South Spain
Member: 42553 Status: Offline Thanks Meter: 23 | Cruiser can't customize W580i. You can see the phone version in software? It's something like (????????-BV). So don't try to unlock this model with Cruiser. Better to use patch with setool2 lite, you can find all this info in this forum Best Regards, |
01-23-2008, 22:34 | #11 (permalink) | |
Freak Poster Join Date: Oct 2005 Location: SLOVAKIA
Member: 194282 Status: Offline Thanks Meter: 9 | Quote:
yes, it's normal. you can connect the phone manualy, remove batery from the phone, insert back, and hold button C, connect cable in the phone.... | |
The Following User Says Thank You to afo For This Useful Post: |
04-01-2008, 05:52 | #12 (permalink) | |
Insane Poster Join Date: Apr 2007
Member: 495719 Status: Offline Thanks Meter: 8 | w580i att Quote:
i have 06 card can i still use it to unlock this phone (w580i) i went step by step i couldn't do it i did fs and arm but i didn't get the rsa and direct unlock option please help me guys | |
04-01-2008, 12:36 | #14 (permalink) |
Freak Poster Join Date: Aug 2006 Location: EGYPT
Member: 324373 Status: Offline Sonork: 1573932 Thanks Meter: 38 | i unlocked w580i with cruiser with normal 1 - unlock RSA 2- direct unlock ( if not accept flash only main same version ) 3 - direct unlock -BR- -==unloOok==- |
How to unlock w580i with only DCU-60 cable | kletscher | Sony Ericsson Hardware Repair | 2 | 04-11-2009 19:13 |
How to Unlock K608i with Cruiser v5.00 .... | GSMAlleyWay | Cruiser Suite | 5 | 09-02-2005 08:41 |
how to unlock 8380 with cruiser | bcnboy | Cruiser Suite | 3 | 06-27-2005 00:12 |
How to unlock z1010 with cruiser? | Uvedovle | Cruiser Suite | 3 | 04-07-2005 12:20 |
how to unlock z500a with cruiser,please help? | baomobile | Cruiser Suite | 0 | 01-21-2005 04:07 |
