Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > Cruiser Suite
Old 08-12-2009, 10:08   #1 (permalink)
surinder's Avatar
Member: 224632
Sonork: 100.1594422
Thanks Meter: 16
i can't repair gdfs k550i with supreem cr. plz hep me
i am trying to repair k550i gdfs software showing folowing errors
  14:22:38  SE Ultimate Unlocker v4.01 by Cruiser Team
  14:22:38  - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change
  14:22:38  Initializing...
! 14:22:38  1. Please see the documentation first (the tab 'Info' or attached .pdf file)
! 14:22:38  2. Choose the phone model
! 14:22:38  3. Select the desired options
! 14:22:38  4. Please connect the phone either via USB while holding 2-5…
! 14:22:38  - or via a serial cable and double-click on it in the device list
  14:23:13  Selected phone: K550 i-Mode
  14:23:13  Connecting via Generic EMP USB Flash Device (USB2)…
  14:23:13  Device driver version: 1.1.0.12
  14:23:13  Device driver date: 9-25-2006
  14:23:13  Connecting to the baseband CPU...
  14:23:13  Entering baseband CPU service mode...
  14:23:14  Detected chipset: DB2020
  14:23:14  Boot mode: ROM
  14:23:14  Sending loader...
  14:23:14  IMEI: 35489301858613
  14:23:14  OTP CID: 51
  14:23:14  Effective CID: 49
  14:23:16  Please reconnect the phone (disconnect, connect while holding 2-5)
  14:23:22  Sending loader...
E 14:24:01  Error: 0xE76A503E
E 14:24:01  Error: 0x780BA8B0
E 14:24:01  Error: 0x599D63C1
E 14:24:01  Error: 0x10BE36DC
E 14:24:01  Error: 0x59AF7680
E 14:24:01  GDFS start-up problem
E 14:24:01  Failed!
! 14:24:01  To report errors right-click this window
Old 08-12-2009, 11:18   #2 (permalink)
deepakgarg's Avatar
Member: 220603
Thanks Meter: 1,164
E 14:24:01  Failed!
wrong model selected...select k550
also u cant downgrade cid less than otp.cid 51 cannot b downgraded to 49
Old 08-12-2009, 12:36   #3 (permalink)
Maiwand khan's Avatar
Member: 295886
Sonork: 100.1583369
Thanks Meter: 1,472
same problem with me here
i have selected correct model
also i havent select downgrade cid
i am selecting cid52 or 53
Old 08-12-2009, 12:47   #4 (permalink)
NawabN Sahoo's Avatar
Member: 687312
Thanks Meter: 290
Bro have you flashed the phone before repairing GDFS? I also had an unsuccessfull experience with this model, maybe Ultimate Unlocker cant repair this model.
WBR
Old 08-12-2009, 14:02   #5 (permalink)
deepakgarg's Avatar
Member: 220603
Thanks Meter: 1,164
explain procedure u followed.i never had such problem with k550
Old 08-12-2009, 15:06   #6 (permalink)
Member: 295886
Sonork: 100.1583369
Thanks Meter: 1,472
what kind od prucedure should i explain mate?
i just open software than read my credits info
and than i select model and also select CID52 under certificate
than i hold 2+5 and connect USB to phone
than software says desconnect phone and connect again
i remove battrey from phone and put it back and hold2+5 botton
than software goes and give this error
credits has already taken
Old 08-12-2009, 15:43   #7 (permalink)
Member: 687312
Thanks Meter: 290
Bro have you chosen GDFS Reconstraction in "Security Opreation" tab and select a good GDFS Backup file?
WBR
Old 08-15-2009, 19:19   #8 (permalink)
asad_nomy7's Avatar
Member: 570093
Thanks Meter: 1,067
i have same problem first i do operation and operation terminated on error as usula and set on but cid show 49 i connect again and gave error.
  23:14:15  SE Ultimate Unlocker v4.01 by Cruiser Team
  23:14:16  - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change
  23:14:16  Initializing...
! 23:14:16  1. Please see the documentation first (the tab 'Info' or attached .pdf file)
! 23:14:16  2. Choose the phone model
! 23:14:16  3. Select the desired options
! 23:14:16  4. Please connect the phone either via USB while holding 2-5…
! 23:14:16  - or via a serial cable and double-click on it in the device list
  23:15:28  Selected phone: K550
  23:15:28  Connecting via Generic FTDI Cable (COM9)…
  23:15:28  Device driver version: 2.2.4.0
  23:15:28  Device driver date: 6-27-2007
  23:15:29  Connecting to the baseband CPU...
E 23:17:17  Error: 0x11990C76
E 23:17:17  Error: 0x03FA0F16
E 23:17:17  Error: 0x889C690F
E 23:17:17  Failed!
! 23:17:17  To report errors right-click this window
Old 08-15-2009, 23:51   #9 (permalink)
Mainboard's Avatar
Member: 25671
Thanks Meter: 719
@asad_nomy7
try use DCU-60 cable
@surinder
you only performed unlock and nothing more, unlocking doesn't mean gdfs repair! gdfs repair is done only by function GDFS Reconstruction
The Following User Says Thank You to Mainboard For This Useful Post:
Old 08-16-2009, 07:50   #10 (permalink)
asad_nomy7's Avatar
Member: 570093
Thanks Meter: 1,067
thanks sir i also try USB but error comes.now i return mobile to customer because he is in HUrry but i lost money (supreme credit).
Old 08-17-2009, 04:42   #11 (permalink)
surinder's Avatar
Member: 224632
Sonork: 100.1594422
Thanks Meter: 16
i also tryied gdfs reconstrution
  09:07:04  SE Ultimate Unlocker v4.01 by Cruiser Team
  09:07:04  - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change
  09:07:04  Initializing...
! 09:07:04  1. Please see the documentation first (the tab 'Info' or attached .pdf file)
! 09:07:04  2. Choose the phone model
! 09:07:04  3. Select the desired options
! 09:07:04  4. Please connect the phone either via USB while holding 2-5…
! 09:07:04  - or via a serial cable and double-click on it in the device list
  09:07:26  Selected phone: K550
  09:07:26  Connecting via Generic EMP USB Flash Device (USB1)…
  09:07:26  Device driver version: 1.0.0.8
  09:07:26  Device driver date: 3-30-2006
  09:07:27  Connecting to the baseband CPU...
  09:07:27  Entering baseband CPU service mode...
  09:07:27  Detected chipset: DB2020
  09:07:27  Boot mode: ROM
  09:07:27  Sending loader...
  09:07:27  IMEI: 35489301858613
  09:07:27  OTP CID: 51
  09:07:27  Effective CID: 49
  09:07:29  Please reconnect the phone (disconnect, connect while holding 2-5)
E 09:07:44  Error: 0x786A2743
E 09:07:44  Error: 0x753B3327
E 09:07:44  Error: 0x59AF7680
E 09:07:44  Unsupported boot mode
! 09:07:44  Please boot via ROM
E 09:07:44  Failed!
! 09:07:44  To report errors right-click this window
but i got errors
Old 08-17-2009, 04:42   #12 (permalink)
surinder's Avatar
Member: 224632
Sonork: 100.1594422
Thanks Meter: 16
E 09:07:44  Failed!
but i got errors
Old 08-17-2009, 05:31   #13 (permalink)
Member: 278546
Thanks Meter: 145
bro , error means gdfs swaped but not write, if u have setool go to empty and refill write same model gdfs in ssw format then write updrade eeprom what cid it have or write cid 52 , then go to flash tab and flash with 2 files u r problem solve .. supreme cruiser log 100% gdfs swap no need try tsecond time , if not done [email protected]..
Old 08-17-2009, 05:45   #14 (permalink)
haji rahim's Avatar
Member: 723410
Sonork: 📱 100.1592732
Thanks Meter: 3,374
with this model ....i mean k550 many users have complain.
alot of user could not repair gdfs ............completly.
cridet cut but not repair .........cid goes to brown but not completed
Old 08-17-2009, 05:56   #15 (permalink)
Member: 687312
Thanks Meter: 290
@yalamandareddy
Do you mean that we can write GDFS with Setool Withouth TP whenever SEUltimate Unlocker failed to Complete the GDFS repairing Process?
Please give a little more details there is many times that I have lost logs but phone hasnt been repaired.
WBR
how can repair gdf k550i ........ hajji1 SETool2 4 11-16-2015 11:38
n70 phone start-up failed.contact the retailer plz hep me. sood Nokia Hardware & Hardware Repair 15 06-12-2011 11:03
k550i after repair gdfs cid53 with log phone onley sony ericsson logo ..:::Gsm india:::.. SETool2 7 02-27-2010 04:34
n70 phone start-up failed.contact the retailer plz hep me. alaaeldin Nokia Hardware & Hardware Repair 28 11-16-2009 13:13
plz hep me nokia 6280 FLASHDIMO Nokia Hardware & Hardware Repair 11 09-04-2008 19:39
Page generated in 0.28484 seconds with 9 queries
