03-21-2006, 14:24 | #1 (permalink) |
No Life Poster Join Date: Feb 2005 Location: In Internet Age: 40
Member: 116970 Status: Offline Thanks Meter: 3 | i have problem with T630 i flashed it ok but now network come 5 second |
03-21-2006, 15:04 | #7 (permalink) |
Freak Poster Join Date: Jan 2003 Location: Tomislavgrad Bosna i hercegovi
Member: 19473 Status: Offline Thanks Meter: 12 | no problems flash this fone full flash file T630_R8C005_EMEA2.bis 12,0 MB (12.582.932 bajtova , after flashing this flash file signal is good. |
03-21-2006, 20:05 | #8 (permalink) |
No Life Poster Join Date: Oct 2003 Location: Auckland, New Zealand
Member: 42570 Status: Offline Thanks Meter: 11 | @mirolic: What file is that? Not one that Cruiser supports. @all: Reread Nizze's post (and ensure you have R7A11 in the phone - lower will probably not work due to newer hardware) |
03-21-2006, 21:35 | #10 (permalink) | |
Member: 42570 Status: Offline Thanks Meter: 11 | Quote:
So suggesting it in the Cruiser forum isn't a lot of help R7A011 for T630 is available in Cruiser support area and should fix this problem, as long as Nizze's advice is also followed. | |
03-22-2006, 05:59 | #13 (permalink) | |
Major Poster Join Date: Jul 2005 Age: 43
Member: 163337 Status: Offline Thanks Meter: 0 | Quote:
Update software to R7A011 after that go to GDFS TAP ----> Modify GDFS with ( No network ) br | |
03-22-2006, 06:04 | #14 (permalink) |
No Life Poster Join Date: Jan 2004 Age: 45
Member: 49581 Status: Offline Thanks Meter: 73 | if you have network for a while and then go into 'No Access' ... it is hardware problem the radio can receive but cannot send out .... the network tower is strong enough that your phone can still receive signal, but ur t630 cannot send the signal back to tower i had the same problem before, and the technician told me that ~~ by the way, it happens on SE phones, on other brand it shows some other things |
03-22-2006, 11:10 | #15 (permalink) |
Member: 163337 Status: Offline Thanks Meter: 0 | @gwaai Have u ever repaired T630??? That problem in here : Some T630 made in 2005 have Ingela (N201) difference before, specific production date 05w11 to 05w..., if u update software by cruiser then this phone will show 'No access" ... solution have posted allow br |
Flash KS20 ok but no network ???? | vnsun | VygisToolbox | 7 | 09-19-2009 08:39 |
Problem with simloc from Z300 - was ok but it's not now | grodzid | Sony Ericsson | 0 | 03-09-2007 11:38 |
i have problem with K750 after flash it phone stop in please wait what can i do | gsm4libya | Cruiser Suite | 4 | 04-12-2006 01:23 |
i have problem with T630 if i try attathed it stop Bypassing please Mr Lead | gsm4libya | Cruiser Suite | 3 | 03-21-2006 07:54 |
Problem with BE1 ver16c - flash read(no problem) but Power ON - NO !!! | Ved | Alcatel & TCL Old Models | 2 | 03-21-2002 18:54 |
