01-16-2006, 11:01 | #1 (permalink) |
Junior Member Join Date: Oct 2004 Age: 51
Member: 85502 Status: Offline Thanks Meter: 0 | the correct method to flash z520i cid red 36 Some z520i when you flash it with brown cid 36 and convert it to brown , after you flash the phone start up and give pleas wait and vibrator is on, so this is the correct method to flash z520I cid red 36: 1- attach phone 2- don't convert to brown cid36 , only put mark in leave rsa certificate untouched (look in the picture down) . 3- Now flash arm with this flash: Z520i_CXC1250143_EU1_R3F015_Brown36 You well ask me why this flash only ? I tell you because I test all flashes and I fond this flash is the best 4- now write raw fs like example: Z520i_CXC1250151_EMEA6_R3F015_Brown36 5- custumise fs 6- shut down fs 7- open now the phone. |
what is the method to flash 5800 by usb which options need to select | observer123 | Universalbox | 2 | 07-27-2009 02:25 |
correct method to unlock 703 cid 73???? | nafg | Cruiser Suite | 4 | 08-21-2007 17:41 |
How to flash K608 Cid 49 Red | enibig | Cruiser Suite | 29 | 11-29-2005 15:52 |
what is correct method to debrand k700i? | ajh927 | TOTAL MultiServer | 4 | 11-24-2004 12:38 |
what is the correct method to install mobimb? | rajkanneganti | Nokia Multimedia | 2 | 12-04-2003 13:58 |
