J200i problem !!!!! HI all! Cruiser flash the phone successful, but after that in the place of the letters there are arrows, squares, and another simbols. I think that is wrong flash type. I tried to flash it with any flash type R1B, and R1C, but stil the same. May be it is R2C, or R2B, but it is missed in the support area . Have anybothy solution for that? |
Yes, i also have same problem here, i thought maybe the firmware have some problem! hope some one can help here! BR., Growell Team |
Same problem i flash the phone successful (type R1B, and R1C), but can't power on. |
u all can try flash this file into your phone 'J200i_World_Generic_NOT_TESTED.ARM' then to Cruiser team pls check this file 'J200c_China_CXC125975_R1C.ARM' coz after i flash to J200 phone dun have chinese wording and i use EMMA II to detect and it show english version not chinese. BR |
R2B flashes will appear in the support area soon. R2 firmwares should not be downgraded to R1. |
10x Lead! I'll be happy! |
@Lead: Can you please upload R2B flashes to support area? I need them too... Thank you! EH |
I noticed another problem with J200i: the phone doesn't always power on after any operation with fighter cables, resulting in 'dead' phone. Solution is to use simple serial cable and unlock it again. Now phone will power on and after shutting it down normally everything works fine. EH |
There's a good post by evan_silbert about Z200 unlocking, the same will apply to the J200i |
Yes, I am aware of that. But with fighter cable the phone doesn't power on automatiacally after unlocking, so I can't power it off and then the phone is 'dead'. With a simple serial cable it does power on: after power off it is alive again. Just thought I would post it here, because I hear more ppl having problems with 'dead' j200. Using a simple serial cable instead of fighter cable can bring it back to live for some ppl... EH |
Lead: Can you please upload R2B flashes to support area? I need them too... Thank you! |
i have j200i with blank lcd after flash its work good but after 1 hour its back with lcd blank again. then try reflash phone again but still lcd blank |
same problem with my j200i phone can power on but blank lcd, any solution for that |
just reflash with UFS and try it Uncheck Exit Boot Select Appropriate Con File Select Appropriate Fix File Select Appropriate Cust File Flash MCU + Cust Then Select Z200 as a Model & Do Unlock & Then Init Secblk . __________________________________________________ __ i use this method its working 100% BR Kashif Khan |
that model of repairing in my case do not work, i have j 200 who is f***d up with virgin cust file before about 2 months. I by it. I was read backup from phone before start unlocking, it was my 1rst. Try-ed with converted flash bin2ufs ->phone power up only with autoignition serial cable when remake crcs, give screen charging, when pres power Death Try-ed with all flashes from ufsx support area -> same sh*t Try-ed with cruiser -> nothing hapen's only one solution now is to try with zuleas USB-Smart i will post results but first i have to find j200 arm flash that's my eXpiriance... |
