06-08-2005, 15:30 | #1 (permalink) |
Freak Poster Join Date: Sep 2003
Member: 38888 Status: Offline Thanks Meter: 52 | J200i problem !!!!! |
06-08-2005, 16:11 | #4 (permalink) |
Freak Poster Join Date: Apr 2005 Location: Global Trend Tele(KLANG)
Member: 136609 Status: Offline Thanks Meter: 3 | u all can try flash this file into your phone 'J200i_World_Generic_NOT_TESTED.ARM' then to Cruiser team pls check this file 'J200c_China_CXC125975_R1C.ARM' coz after i flash to J200 phone dun have chinese wording and i use EMMA II to detect and it show english version not chinese. BR |
06-30-2005, 06:53 | #8 (permalink) |
Freak Poster Join Date: Jan 2002 Location: Enschede, The Netherlands Age: 41
Member: 8594 Status: Offline Thanks Meter: 13 | I noticed another problem with J200i: the phone doesn't always power on after any operation with fighter cables, resulting in 'dead' phone. Solution is to use simple serial cable and unlock it again. Now phone will power on and after shutting it down normally everything works fine. EH |
06-30-2005, 06:57 | #9 (permalink) | |
No Life Poster Join Date: Oct 2003 Location: Auckland, New Zealand
Member: 42570 Status: Offline Thanks Meter: 11 | Quote:
There's a good post by evan_silbert about Z200 unlocking, the same will apply to the J200i | |
06-30-2005, 07:42 | #10 (permalink) |
Member: 8594 Status: Offline Thanks Meter: 13 | Yes, I am aware of that. But with fighter cable the phone doesn't power on automatiacally after unlocking, so I can't power it off and then the phone is 'dead'. With a simple serial cable it does power on: after power off it is alive again. Just thought I would post it here, because I hear more ppl having problems with 'dead' j200. Using a simple serial cable instead of fighter cable can bring it back to live for some ppl... EH |
07-02-2005, 17:43 | #12 (permalink) |
Freak Poster Join Date: Sep 2003 Location: Purwokerto, ID Age: 42
Member: 39539 Status: Offline Thanks Meter: 65 | i have j200i with blank lcd after flash its work good but after 1 hour its back with lcd blank again. then try reflash phone again but still lcd blank |
07-29-2005, 16:37 | #14 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Holland China Brazil Age: 43
Member: 88016 Status: Offline Thanks Meter: 320 | just reflash with UFS and try it Uncheck Exit Boot Select Appropriate Con File Select Appropriate Fix File Select Appropriate Cust File Flash MCU + Cust Then Select Z200 as a Model & Do Unlock & Then Init Secblk . __________________________________________________ __ i use this method its working 100% BR Kashif Khan |
10-12-2005, 22:33 | #15 (permalink) |
Freak Poster Join Date: Aug 2004 Age: 46
Member: 78018 Status: Offline Thanks Meter: 4 | that model of repairing in my case do not work, i have j 200 who is f***d up with virgin cust file before about 2 months. I by it. I was read backup from phone before start unlocking, it was my 1rst. Try-ed with converted flash bin2ufs ->phone power up only with autoignition serial cable when remake crcs, give screen charging, when pres power Death Try-ed with all flashes from ufsx support area -> same sh*t Try-ed with cruiser -> nothing hapen's only one solution now is to try with zuleas USB-Smart i will post results but first i have to find j200 arm flash that's my eXpiriance... |
acount id problem.help uregent plz [SOLVED] | dani2080 | PolarBox 3 | 2 | 03-29-2010 12:46 |
J200i Restrat Problem | Ja\/\/aD | Sony Ericsson | 30 | 05-28-2006 00:28 |
j200i problem later flash | erayturkoglu | MT-BOX | 1 | 05-18-2006 15:08 |
J200i Problem in Unlocking | fateh76dz | FuriouS II | 8 | 08-17-2005 21:21 |
j200i charging problem | sanjeev_in | Sony Ericsson Hardware Repair | 4 | 04-01-2005 12:42 |
