04-04-2009, 15:03 | #1 (permalink) |
No Life Poster Join Date: Mar 2004
Member: 57803 Status: Offline Thanks Meter: 99 | Java and fast java problems [code] 14:52:45 SE A1 Fast Java Unlocker v1.01 by Cruiser Team 14:52:45 Initializing... ! 14:52:45 1. Please see the documentation first (tab 'Info') ! 14:52:45 2. Choose the phone model ! 14:52:45 3. Please connect the phone while holding its C button… 14:53:01 Connecting via SEMC USB Flash Device (USB1)… 14:53:01 Device driver version: 2.1.0.0 14:53:01 Device driver date: 3-20-2008 14:53:01 Connecting to the baseband CPU... 14:53:01 Entering baseband CPU service mode... 14:53:02 Detected chipset: DB2012 14:53:02 Boot mode: EROM 14:53:02 EROM version: R3A022 prgCXC1250729_EROM_DB2010_MELINDA_FOTA_SIMLOCK_FLA FLA_SIBLEY_SEMCUSB 14:53:02 Sending loader... 14:53:02 Sending loader... 14:53:04 Starting up System... 14:53:04 Starting up GDFS... 14:53:22 Starting up FS... Thats it, both Java and Fast Java just hang at starting up fs for ever more. Not had any problems until today and it's probably something simple but I cannot find a solution. Uninstalled and re installed both of them a couple of times but still not working. Any ideas. |
04-07-2009, 11:58 | #2 (permalink) |
Member: 57803 Status: Offline Thanks Meter: 99 | This is the log for a W200 on Java unlocker. [code] 11:47:28 SE A1 Java Unlocker v1.10 by Cruiser Team 11:47:28 Initializing... ! 11:47:28 1. Choose the phone model ! 11:47:28 2. Select main firmware flash file (*.a1sw) ! 11:47:28 3. Select raw FS flash file (*.a1fs) ! 11:47:28 4. Please connect the phone while holding its C button… 11:47:56 Connecting via SEMC USB Flash Device (USB4)… 11:47:56 Device driver version: 2.2.0.0 11:47:56 Device driver date: 9-18-2008 11:47:56 Connecting to the baseband CPU... 11:47:56 Entering baseband CPU service mode... 11:47:57 Detected chipset: DB2012 11:47:57 Boot mode: EROM 11:47:57 EROM version: R3A022 prgCXC1250729_EROM_DB2010_MELINDA_FOTA_SIMLOCK_FLA FLA_SIBLEY_SEMCUSB 11:47:57 Initializing flash files... 11:48:00 Sending loader... 11:48:00 Sending loader... 11:48:01 About to flash 29 MB of data… 11:51:39 Sending loader... 11:51:42 System starting up... 11:51:42 GDFS starting up... 11:52:09 FS starting up... 11:52:31 FS data uploading... Both Fast Java and Java unlocker hang at this point, anyone help, Please !!!!! I think I am going insane |
04-07-2009, 13:48 | #4 (permalink) |
Member: 57803 Status: Offline Thanks Meter: 99 | Many thanks for the quick reply, I had a feeling it was a driver fault and I have spent ages trying to replace 2.2.0 with 2.1.0 but it keeps reverting back to 2.2.0. Is there an easy way to do this, a dummy's guide if you like. I am obviously going about it the wrong way but I'm buggered if I can do it the correct way. |
04-07-2009, 14:33 | #5 (permalink) |
No Life Poster Join Date: Apr 2005 Location: between New Zealand - Canada Age: 42
Member: 135110 Status: Offline Thanks Meter: 302 | you must downgrade the driver manually. it means, connect the phone while holding itc C button (or 2 for W880), click on proporties, update driver, choose the device manually, locate the driver and let´s continue. |
04-08-2009, 09:33 | #6 (permalink) |
Member: 57803 Status: Offline Thanks Meter: 99 | After spending nearly 2 days trying to sort this baby out, came in this morning and cracked it in less than 3 minutes. Must be something to do with my hormones. Many thanks FilipLudvik |
problem with fast java unlocker | kinggsm team | Cruiser Suite | 3 | 10-12-2009 22:04 |
SE A1 fast java unlocker problem (FREEEZING) | wodashie | Cruiser Suite | 5 | 08-30-2009 18:54 |
Fast Java unlocker problem | DonaldDuck69 | Cruiser Suite | 31 | 01-28-2009 22:30 |
W300 CID51 and A1 Fast Java Unlocker | jepetu | Cruiser Suite | 3 | 07-25-2008 22:00 |
W660 and FAST JAVA UNLOCKER | TPFINDER | Cruiser Suite | 0 | 07-13-2008 18:09 |
