11-21-2008, 20:07 | #1 (permalink) |
No Life Poster Join Date: Mar 2001 Location: ALBANIA(Tirana) Age: 51
Member: 3617 Status: Offline Thanks Meter: 579 | K 610 problem resolving GDFS Phone Red blinking now i try again and i recived this message Code: 19:56:18 D-Ultimate Unlocker v3.05 by Cruiser Team 19:56:18 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 19:56:18 Initializing... ! 19:56:18 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 19:56:18 2. Choose the phone model ! 19:56:18 3. Select the desired options ! 19:56:18 4. Please connect the phone either via USB while holding 2-5… ! 19:56:18 - or via a serial cable and double-click on it in the device list 19:56:40 Selected phone: K610 19:56:40 Connecting via Generic EMP USB Flash Device (USB2)… 19:56:40 Device driver version: 2.1.0.0 19:56:40 Device driver date: 3-20-2008 19:56:41 Connecting to the baseband CPU... 19:56:41 Entering baseband CPU service mode... 19:56:41 Detected chipset: DB2020 19:56:41 Boot mode: ROM 19:56:41 Sending loader... 19:56:42 IMEI: 35170901043881 19:56:42 OTP CID: 49 19:56:42 Effective CID: 52 19:56:44 Please reconnect the phone (disconnect, connect while holding 2-5) 19:56:53 Sending loader... 19:56:53 Communicating with server… ! 19:56:58 News: Your credit consumption policy: Level 1 (Novice) 19:56:59 Remainig credit (supreme): 0.09 E 19:56:59 Error: 0x4D5EFC5D E 19:56:59 Error: 0x4D5EFC5D E 19:56:59 Error: 0x16D3BA97 E 19:56:59 Error: 0x834ACC0E E 19:56:59 Error: 0x51A411A0 E 19:56:59 Error: 0x78E56923 E 19:56:59 Error: 0x5C5AEBE3 E 19:56:59 Error: 0x3D35EAF1 E 19:57:00 Not enough credit E 19:57:00 Failed! ! 19:57:00 To report errors right-click this window in the second try soft it say Not enough credit???? |
11-21-2008, 20:25 | #2 (permalink) |
Member: 3617 Status: Offline Thanks Meter: 579 | as i know here log are free SE ultimate unlocker Code: 20:22:06 SE Ultimate Unlocker v1.03 by Cruiser Team 20:22:06 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 20:22:06 Initializing... ! 20:22:06 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 20:22:06 2. Choose the phone model ! 20:22:06 3. Select the desired options ! 20:22:06 4. Please connect the phone either via USB while holding 2-5… ! 20:22:06 - or via a serial cable and double-click on it in the device list 20:22:49 Selected phone: K610 20:22:49 Connecting via Generic EMP USB Flash Device (USB2)… 20:22:49 Device driver version: 2.1.0.0 20:22:49 Device driver date: 3-20-2008 20:22:51 Connecting to the baseband CPU... 20:22:51 Entering baseband CPU service mode... 20:22:51 Detected chipset: DB2020 20:22:51 Boot mode: ROM 20:22:51 Sending loader... 20:22:51 IMEI: 35170901043881 20:22:51 Please reconnect the phone (disconnect, connect while holding 2-5) 20:23:03 Sending loader... 20:23:03 Communicating with server… ! 20:23:07 News: !!! A NEW VERSION OF SE-ULTIMATE UNLOCKER 2.01 IS AVAILABLE !!! 20:23:08 Remainig credit (supreme): 0.00 E 20:23:08 Error: 0x4D5EFC5D E 20:23:08 Error: 0x4D5EFC5D E 20:23:08 Error: 0x16D3BA97 E 20:23:08 Error: 0x834ACC0E E 20:23:08 Error: 0x51A411A0 E 20:23:08 Error: 0x78E56923 E 20:23:08 Error: 0x5C5AEBE3 E 20:23:08 Error: 0x3D35EAF1 E 20:23:08 Not enough credit E 20:23:08 Failed! ! 20:23:08 Please disconnect battery and cable from the phone! ! 20:23:08 To report errors right-click this window |
11-24-2008, 13:13 | #5 (permalink) |
Member: 3617 Status: Offline Thanks Meter: 579 | Still the same problem I lost 2 times credits and phone still stay please wait problem gdfs i want back my credis please ] 12:41:50 SE Ultimate Unlocker v1.03 by Cruiser Team 12:41:50 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 12:41:50 Initializing... ! 12:41:50 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 12:41:50 2. Choose the phone model ! 12:41:50 3. Select the desired options ! 12:41:50 4. Please connect the phone either via USB while holding 2-5… ! 12:41:50 - or via a serial cable and double-click on it in the device list 12:41:59 Selected phone: K610 12:41:59 Connecting via Generic EMP USB Flash Device (USB2)… 12:41:59 Device driver version: 2.1.0.0 12:41:59 Device driver date: 3-20-2008 12:42:01 Connecting to the baseband CPU... 12:42:01 Entering baseband CPU service mode... 12:42:01 Detected chipset: DB2020 12:42:01 Boot mode: ROM 12:42:01 Sending loader... 12:42:01 IMEI: 35170901043881 12:42:01 Please reconnect the phone (disconnect, connect while holding 2-5) 12:42:10 Sending loader... 12:42:10 Communicating with server… ! 12:42:31 News: !!! A NEW VERSION OF SE-ULTIMATE UNLOCKER 2.01 IS AVAILABLE !!! ! 12:42:35 News: Your credit consumption policy: Level 1 (Novice) 12:42:39 Remainig credit (supreme): 1.00 12:43:06 Remainig credit (supreme): 0.67 12:43:07 Please reconnect the phone (disconnect, connect while holding 2-5) 12:43:17 Sending loader... 12:43:20 Code NCK for relock: 1054493326662411 12:43:20 Code NSCK for relock: 8744478120632609 12:43:20 Code SPCK for relock: 1547533764037858 12:43:20 Code CCK for relock: 2932643261024535 12:43:20 Code PCK for relock: 5533619161560704 12:43:20 Code ESLCK for relock: 8416101339782965 12:43:21 Code NCK for unlock: 6315121793684044 12:43:21 Code NSCK for unlock: 7734709404784352 12:43:21 Code SPCK for unlock: 9105869928094021 12:43:21 Code CCK for unlock: 0574562771171580 12:43:21 Code PCK for unlock: 7913544047393542 12:43:21 Code ESLCK for unlock: 9829914129650789 12:43:21 To enter a code, type < * * < on the phone with SIM-card inserted 12:43:21 Writing flash… 12:43:22 Turning off the phone... 12:43:24 Done. ! 12:43:24 Please disconnect battery and cable from the phone! [/code] |
11-24-2008, 16:25 | #7 (permalink) |
Member: 3617 Status: Offline Thanks Meter: 579 | Please FilipLudvik see the logo here i flash the phone also i make full unlock still the same Code: 16:20:42 SE Ultimate Unlocker v3.05 by Cruiser Team 16:20:42 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 16:20:42 Initializing... ! 16:20:42 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 16:20:42 2. Choose the phone model ! 16:20:42 3. Select the desired options ! 16:20:42 4. Please connect the phone either via USB while holding 2-5… ! 16:20:42 - or via a serial cable and double-click on it in the device list 16:21:01 Selected phone: K610 16:21:01 Connecting via Generic EMP USB Flash Device (USB2)… 16:21:01 Device driver version: 2.1.0.0 16:21:01 Device driver date: 3-20-2008 16:21:03 Connecting to the baseband CPU... 16:21:03 Entering baseband CPU service mode... 16:21:03 Detected chipset: DB2020 16:21:03 Boot mode: ROM 16:21:03 Sending loader... 16:21:03 IMEI: 35170901043881 16:21:03 OTP CID: 49 16:21:03 Effective CID: 52 16:21:05 Please reconnect the phone (disconnect, connect while holding 2-5) 16:21:19 Sending loader... 16:21:19 Communicating with server… ! 16:21:24 News: Your credit consumption policy: Level 1 (Novice) 16:21:25 Remainig credit (supreme): 0.67 16:21:28 Remainig credit (supreme): 0.67 16:21:32 Please reconnect the phone (disconnect, connect while holding 2-5) 16:21:43 Sending loader... 16:21:48 Code NCK for relock: 1054493326662411 16:21:48 Code NSCK for relock: 8744478120632609 16:21:48 Code SPCK for relock: 1547533764037858 16:21:48 Code CCK for relock: 2932643261024535 16:21:48 Code PCK for relock: 5533619161560704 16:21:48 Code ESLCK for relock: 8416101339782965 16:21:48 Code NCK for unlock: 6315121793684044 16:21:48 Code NSCK for unlock: 7734709404784352 16:21:48 Code SPCK for unlock: 9105869928094021 16:21:48 Code CCK for unlock: 0574562771171580 16:21:48 Code PCK for unlock: 7913544047393542 16:21:48 Code ESLCK for unlock: 9829914129650789 16:21:48 To enter a code, type < * * < on the phone with SIM-card inserted 16:21:48 Writing flash… 16:21:50 Turning off the phone... 16:21:52 Done. |
11-24-2008, 16:58 | #8 (permalink) |
No Life Poster Join Date: Jul 2007 Location: Indonesia Age: 47
Member: 551188 Status: Offline Sonork: 100.1580118 Thanks Meter: 59 | do gdfs reconstruction using UU 3.05 put this file on it and follow the UU procedure......... good luck http://www.mediafire.com/?dvmaorxj9z2 |
11-24-2008, 20:34 | #10 (permalink) |
Member: 3617 Status: Offline Thanks Meter: 579 | System diagnostics passed. Version 13.20 ready! [ --- Attach to Phone --- ] Connecting via Fighter USB Cable... Powering on the phone... Baseband chip ID: 0x9900 Protocol version: 3.1 Baudrate = 460800Bd Booting via ROM... Trying CID53 recovery applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 2s Initializing phone hardware... Applet ID: 070703 1229 NPA4_CXC1329130_DB2020_... Flash manufacturer: Intel Flash ID: 0x897E OTP Security Level: 1 (Retail) OTP CID: 49 Phone CID: 52 Phone color: Red Sending applet... Applet ID: 061205 1523 HANCXC9876543210_DB2020... Sending applet... Applet ID: 061201 1314 HANCXC1329129_DB2020_FL... RSA protection state cannot be determined for this CID. Phone hardware initialized OK [ --- Customize File System --- ] Sending CS applet... Applet ID: 070410 1557 HANCXC1250562_DB2020_CS... Initializing CS applet... Applet ID: 070410 1557 HANCXC1250562_DB2020_CS... Baudrate = 921600Bd Starting up GDFS service... Starting up filesystem, please wait... Building customization... Customizing phone... Done. Writing CDA Article MS string... New value: CDA102568/10 Done. Writing CDA Version MS string... New value: R5A Done. Writing Default Article MS string... New value: cxc1250376 Done. Writing Default Version MS string... New value: R8BE001 Done. Writing langpack string... New value: EUROPE_1 Done. Writing country... New value: Generic Trade Done. |
11-24-2008, 21:06 | #11 (permalink) |
Member: 3617 Status: Offline Thanks Meter: 579 | Code: 21:01:10 SE GDFS Backuper & Restorer v1.04 by Cruiser Team 21:01:10 Initializing... ! 21:01:11 1. Choose the phone model ! 21:01:11 2. If you want to perform restore, select GDFS backup file (*.gdfs) ! 21:01:11 3. Please connect the phone while holding its C button… ! 21:01:11 4. Warning: Restoring a phone from a backup made from a different phone destroys the phone specific data 21:01:39 Connecting via Cruiser UC-20 Cable (COM12)… 21:01:39 Device driver version: 2.4.6.0 21:01:39 Device driver date: 3-13-2008 21:01:41 Connecting to the baseband CPU... 21:01:43 Entering baseband CPU service mode... 21:01:43 Detected chipset: DB2020 21:01:43 Boot mode: ROM 21:01:43 Sending loader... 21:01:45 Performing backups… 21:01:52 Sending loader... 21:01:59 Initializing loader... 21:01:59 Initializing GDFS access... 21:02:21 Writing GDFS… 21:02:37 Turning off the phone... 21:02:39 Done. ! 21:02:39 Please disconnect battery and cable from the phone! |
11-24-2008, 21:09 | #12 (permalink) |
Member: 3617 Status: Offline Thanks Meter: 579 | phone still with display white Code: 21:06:38 SE Ultimate Unlocker v3.05 by Cruiser Team 21:06:38 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 21:06:38 Initializing... ! 21:06:39 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 21:06:39 2. Choose the phone model ! 21:06:39 3. Select the desired options ! 21:06:39 4. Please connect the phone either via USB while holding 2-5… ! 21:06:39 - or via a serial cable and double-click on it in the device list 21:07:09 Selected phone: K610 21:07:09 Connecting via Cruiser UC-20 Cable (COM12)… 21:07:09 Device driver version: 2.4.6.0 21:07:09 Device driver date: 3-13-2008 21:07:11 Connecting to the baseband CPU... 21:07:11 Entering baseband CPU service mode... 21:07:11 Detected chipset: DB2020 21:07:11 Boot mode: ROM 21:07:11 Sending loader... 21:07:12 IMEI: 35170901043881 21:07:12 OTP CID: 49 21:07:12 Effective CID: 52 21:07:12 Restarting phone … 21:07:15 Sending loader... 21:07:16 Communicating with server… ! 21:07:21 News: Your credit consumption policy: Level 1 (Novice) 21:07:21 Remainig credit (supreme): 0.67 21:07:25 Remainig credit (supreme): 0.67 21:07:26 Restarting phone … 21:07:28 Sending loader... 21:07:43 Initializing GDFS access... 21:07:43 Writing GDFS… 21:07:55 Code NCK for relock: 1054493326662411 21:07:55 Code NSCK for relock: 8744478120632609 21:07:55 Code SPCK for relock: 1547533764037858 21:07:56 Code CCK for relock: 2932643261024535 21:07:56 Code PCK for relock: 5533619161560704 21:07:56 Code ESLCK for relock: 8416101339782965 21:07:56 Code NCK for unlock: 6315121793684044 21:07:56 Code NSCK for unlock: 7734709404784352 21:07:56 Code SPCK for unlock: 9105869928094021 21:07:56 Code CCK for unlock: 0574562771171580 21:07:56 Code PCK for unlock: 7913544047393542 21:07:56 Code ESLCK for unlock: 9829914129650789 21:07:56 To enter a code, type < * * < on the phone with SIM-card inserted 21:07:56 Writing flash… 21:07:58 Turning off the phone... 21:08:00 Done. |
complete t 610 flashing with gdfs | .::ricky rayya::. | Sony Ericsson | 3 | 03-17-2007 22:10 |
610 problem flash | hightechsquare | UFS2 + UFS3-Tornadoflasher | 0 | 11-01-2004 15:46 |
t 610 problem | uqbah | Sony Ericsson Hardware Repair | 1 | 10-20-2004 08:50 |
SL45 Probleme resolved thanks guys | CHATAR | x1x to x45/x50 | 0 | 11-09-2001 05:33 |
Security Code problems resolved now! | alaraf | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 07-08-2001 02:13 |
