10-06-2006, 11:23 | #1 (permalink) |
No Life Poster Join Date: Jul 2006 Location: UK
Member: 318507 Status: Offline Thanks Meter: 17 | K300i testpoint covered with black glue The testpoint is covered with black glue. What do I use to remove it without damaging the track? |
10-06-2006, 18:10 | #3 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: inside emmc ufs Age: 19
Member: 221603 Status: Offline Sonork: 100.1581270 Thanks Meter: 6,395 | Quote:
just forget the testpoint and flash your phone............ | |
10-06-2006, 21:03 | #4 (permalink) | |
Member: 318507 Status: Offline Thanks Meter: 17 | Quote:
This is my first time with Cruiser. The instructions seem to be for older versions. They refer to cables that need batteries. I don't have any cables that need batteries. I have an SE-TOOL. So I am winging it as I go along. | |
10-07-2006, 00:24 | #6 (permalink) | |
I can't access Cruiser at the moment. I just get message The time for this version has expired. I have only just bought it. Upgraded to V10. Still get message: System diagnostics passed. Version 10.00 ready! [ --- Attach to Phone --- ] Connecting via UC-10 Universal Cable... Powering on the phone... Just hangs there. Goes no further. I tried flashing ARM and full flash after downgrading to brown. I don't really know what I am doing. I think I flashed with the wrong files. Help!!!!!! Last edited by justmegt; 10-07-2006 at 01:05. | |
10-07-2006, 18:44 | #9 (permalink) | |
[ --- Attach to Phone --- ] Connecting via UC-10 Universal Cable... Powering on the phone... Just hangs there. Goes no further. | |
10-07-2006, 19:24 | #10 (permalink) | |
System diagnostics passed. Version 10.00 ready! [ --- Attach to Phone --- ] Connecting via UC-10 Universal Cable... Powering on the phone... Baseband chip ID: 0x8000 Protocol version: 3.1 Baudrate = 460800Bd Trying CID36 recovery applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 1s Initializing phone hardware... Applet ID: 041213 1452 MATCXC1326739_COMPACTCERTLOADER R2L Flash manufacturer: Intel Flash ID: 0x890D OTP Security Level: 1 (Retail) OTP CID: 36 Analyzing RSA protection... RSA protection is normal. Phone hardware initialized OK [ --- Repair Certificate --- ] Preparing to program flash... Programming flash... Time: 00:00:01 Flash process done. Cruiser displays only Primary and Security RSA tabs. Please can someone tell me what to do next. This is my first attempt at using Cruiser. | |
10-07-2006, 20:35 | #11 (permalink) | |
http:///vbb/showthread.php?t=258958 | |
10-08-2006, 11:28 | #12 (permalink) | |
After several hours of experimentation I have re-flashed phone back to life. I performed too many operations to remember exactly how it happened. New problem 1: Put sim in (I tried Vodafone, O2 and T-mobile), phone says 'insert correct sim' I tried: 'Direct unlock' and 'read codes' get the following: [ --- Direct Unlock --- ] Reading security zone... Phone automatically detached. [ --- Read Codes --- ] Calculating codes... Reading security zone... Phone automatically detached. Plus some error messages in red underneath. Phone still won't accpt sim cards. New problem 2: When phone is turned off manually it cannot be turned back on again without remove/ replace battery routine. Please help !!!!!!!!!!!!!!!! Last edited by justmegt; 10-08-2006 at 11:41. | |
10-08-2006, 14:38 | #13 (permalink) |
Member: 221603 Status: Offline Sonork: 100.1581270 Thanks Meter: 6,395 | aha....................... attach phone... change the phone clolour to brown... remove rsa direct unlock customise fs shut down fs you are done.. if you still get any earror.... post your log... |
10-08-2006, 15:08 | #14 (permalink) | |
Version 10.00 ready! [ --- Attach to Phone --- ] Connecting via UC-10 Universal Cable... Powering on the phone... Baseband chip ID: 0x8000 Protocol version: 3.1 Baudrate = 460800Bd Sony Ericsson phone detected. Phone CID: 36 Phone color: Red Flash certificate: A1_DB2010_36_RED Trying Red CID36 flash applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 2s Initializing phone hardware... Applet ID: 050425 0904 MATCXC1326738_COMPACTFLASHLOADER R2AB Flash manufacturer: Intel Flash ID: 0x890D OTP Security Level: 1 (Retail) OTP CID: 36 Analyzing configuration... Reading primary certificate... Primary certificate CID: 36 Primary certificate color: Red Secondary certificate not found. GDFS configuration found. OSE configuration found. TestProgram configuration not found. Analysing GDFS... Done. Analyzing RSA protection... RSA protection is weak. RSA protection weakness type: PERMANENT Phone hardware initialized OK [ --- Change Certificate Color --- ] Defeating RSA protection... Waiting for the phone to turn off... Should the communication hang, reinsert battery. Baudrate = 460800Bd Sending applet prologue... Sending applet body... Applet ID: 050404 1011 LLECXC125872_COMPACTPRODUCTION_ID_LOADER R2F Sending applet... Applet ID: 040319 0923 LLECXC1326739_COMPACTCERTLOADER R2E Defeated! Sending applet... Applet ID: Prepare yourself for a nice surprise! Initializing applet... Replacing primary certificate... Certificate replaced successfully. Turning off phone... Phone automatically detached. [ --- Attach to Phone --- ] Connecting via UC-10 Universal Cable... Powering on the phone... Baseband chip ID: 0x8000 Protocol version: 3.1 Baudrate = 460800Bd Sony Ericsson phone detected. Phone CID: 36 Phone color: Brown Flash certificate: A1_DB2010_36_BROWN Trying Brown CID36 flash applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 2s Initializing phone hardware... Applet ID: 060222 0202 CRUCXC1250166_1_SEMC_COMPACTPRODUCTION NAN Flash manufacturer: Intel Flash ID: 0x890D OTP Security Level: 1 (Retail) OTP CID: 36 Analyzing configuration... Reading primary certificate... Primary certificate CID: 36 Primary certificate color: Brown Secondary certificate not found. GDFS configuration found. OSE configuration found. TestProgram configuration not found. Analysing GDFS... Done. Analyzing RSA protection... RSA protection is weak. RSA protection weakness type: PERMANENT Phone hardware initialized OK [ --- Unlock RSA --- ] Restarting phone... Defeating RSA protection... Waiting for the phone to turn off... Should the communication hang, reinsert battery. Baudrate = 460800Bd Sending applet prologue... Sending applet body... Applet ID: 050404 1011 LLECXC125872_COMPACTPRODUCTION_ID_LOADER R2F Sending applet... Applet ID: 040319 0923 LLECXC1326739_COMPACTCERTLOADER R2E Defeated! Sending CS applet... Applet ID: 060119 0203 CRUCXC1327364_COMPACT_SEMC_CS_LOADER_V20 Initializing CS applet... Applet ID: 060119 0203 CRUCXC1327364_COMPACT_SEMC_CS_LOADER_V20 Baudrate = 921600Bd Starting up GDFS service... Writing unsigned code... Turning off phone... Done. Phone automatically detached. [ --- Attach to Phone --- ] Connecting via UC-10 Universal Cable... Powering on the phone... Baseband chip ID: 0x8000 Protocol version: 3.1 Baudrate = 460800Bd Sony Ericsson phone detected. Phone CID: 36 Phone color: Brown Flash certificate: A1_DB2010_36_BROWN Trying Brown CID36 flash applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 2s Initializing phone hardware... Applet ID: 060222 0202 CRUCXC1250166_1_SEMC_COMPACTPRODUCTION NAN Flash manufacturer: Intel Flash ID: 0x890D OTP Security Level: 1 (Retail) OTP CID: 36 Analyzing configuration... Reading primary certificate... Primary certificate CID: 36 Primary certificate color: Brown Secondary certificate not found. GDFS configuration found. OSE configuration found. TestProgram configuration not found. Analysing GDFS... Done. Analyzing RSA protection... RSA protection is weak. RSA protection weakness type: PERMANENT Phone hardware initialized OK [ --- Direct Unlock --- ] Reading security zone... Phone automatically detached. GDFS Error: EAccessViolation (displayed in red in bottom window) Last edited by justmegt; 10-08-2006 at 15:22. | |
Adorama Classic Photo Album, Black Leather Cover with Library Bound Black Pages, Hold | IPMART | ipmart WebShop | 0 | 11-26-2008 11:40 |
Adorama Pro Photo Album, Black Leatherette Cover with Library Bound Black Pages, Hold | IPMART | ipmart WebShop | 0 | 11-26-2008 07:40 |
Adorama Pro Photo Album, Black Leatherette Cover with Library Bound Black Pages, Hold | IPMART | ipmart WebShop | 0 | 11-26-2008 03:30 |
Does all the N80 TP points covered by IC Glue? | samuelscu | BB5BOX | 3 | 12-09-2007 21:57 |
8330 dead test point covered with glue | gorgans | VygisToolbox | 1 | 09-17-2005 01:27 |
