12-20-2006, 13:14 | #1 (permalink) |
No Life Poster Join Date: Sep 2003 Location: Right There ( Croatia )
Member: 38150 Status: Offline Sonork: 100.1611516 Thanks Meter: 143 | K310i and K510i Unlocking problem With Cruiser Today i recieve brand NEW K510i Croatian VIP locked and same network but K310 but cruiser get this message : Sorry, no EROM is available for this phone Here is logs From K310i try to unlock : System diagnostics passed. Version 10.09 alpha ready! [ --- Attach to Phone --- ] Connecting via Fighter USB Cable... Powering on the phone... Baseband chip ID: 0x8040 Protocol version: 3.1 Baudrate = 460800Bd Sony Ericsson phone detected. Phone CID: 49 Phone color: Red Flash certificate: A1_DB2010_49_RED Trying Red CID49 flash applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 1s Initializing phone hardware... Applet ID: 060206 1814 NPACXC125872_COMPACTPRO... Flash manufacturer: Intel Flash ID: 0x897E OTP Security Level: 1 (Retail) OTP CID: 49 Phone type (from GDFS): K310i CXC article: R4DA044 prgCXC1250471_VODAFONE_DO CXC version: R4DA044 Language package: VFE_LIVE_3 Operator: VIP Net (Vfe) CDA article: CDA102570/126 CDA version: R1A Default article: cxc1250474 Default version: R4DA044 Crash counter: 0 Phonecode: 0000 Sending applet... Applet ID: 060305 1000 104_DB2010_FLASHLOADER_... RSA protection state cannot be determined for this CID. Phone hardware initialized OK How to unlock that Phone .... regrads Mario |
12-20-2006, 14:51 | #3 (permalink) | |
Member: 38150 Status: Offline Sonork: 100.1611516 Thanks Meter: 143 | @vertz Quote:
1. I read manual and work like manual say But when i try rešplace RED to BROWN like MANUAL say I get this Error Sorry, no EROM is available for this phone. BTW . I first try all soluttion then ask for help so im not write this all without reason ..... Regrads Mario | |
12-20-2006, 15:04 | #4 (permalink) | |
Freak Poster Join Date: Feb 2004 Age: 44
Member: 53457 Status: Offline Thanks Meter: 9 | @jankovic brother u just do this process for unlock @jankovic brother u just do this process for unlock all new cid 49 1 attech 2 go in sceuirty Ras 3 unlock Ras 4 and attech agin 5 go in locks and direct unlock 6 attech agin + go in sceuirty Ras do resotre firmware all is done Quote:
cellworld | |
12-20-2006, 15:41 | #6 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Chittagong, Bangladesh.
Member: 152752 Status: Offline Sonork: 100.1581661 Thanks Meter: 182 | Just follow "Cellworld" process atteched phone unlock RSA reattech phone direct unlock flash SW(main) customize turnoff phone. 100% I also unlocked more (DB2010) phones. |
12-20-2006, 16:07 | #7 (permalink) |
No Life Poster Join Date: Feb 2004 Location: ALGERIA
Member: 54116 Status: Offline Thanks Meter: 218 | attach ur phone, unlock rsa (don't make convertion to brow), the phone is autodetached, remove battery& reisert it againe, attach ur phone and do direct unlock& don't forget to make restore firmewar in end regards |
12-20-2006, 16:15 | #8 (permalink) |
No Life Poster Join Date: Sep 2005 Age: 40
Member: 181442 Status: Offline Sonork: 100:1574950 Thanks Meter: 184 | I Use The Method From The Manual And It Works For Me 100% 1. Attach Phone 2. Unlock RSA 3. Remove And Re-Insert Battery. 4. Attach Phone 5. Restore Firmware (If Restoral File Cannot Be Found, Flash Main FW and FS And Customize The Phone) 6. Clear Direct Lock Code Best Regards Yasin |
12-20-2006, 17:33 | #9 (permalink) | |
No Life Poster Join Date: May 2005 Location: Denmark Age: 42
Member: 146369 Status: Offline Thanks Meter: 119 | Quote:
The correct procedure is: 1. Attach Phone 2. Unlock RSA 3. Remove And Re-Insert Battery. 4. Attach Phone 5. Direct Unlock 6. Restore firmware Volia your phone is unlocked and fully working... Wbr | |
12-20-2006, 20:49 | #10 (permalink) |
Member: 181442 Status: Offline Sonork: 100:1574950 Thanks Meter: 184 | [QUOTE=Crazy_ratata;2153519]You are wrong... After you have restored firmware you will have to unlock rsa agin, as a firmware restore will restore the 128/256 kb of main firmware where the RSA protection lays... Sorry to inform you of this but my way is RIGHT (you way may be right also) and is in accordance with cruiser_v.9.72_guide.pdf. Download it from the support section, and read it under page 91 section: newer phones with locked-down EROM area. My way is tried and tested 100% Best regards Yasin |
12-21-2006, 03:00 | #11 (permalink) |
Member: 146369 Status: Offline Thanks Meter: 119 | I have never used this method... Never... I always do direct unlock... My method works 2... But I do not understand why this method works... Firmware restore will also restore the RSA protection... wbr |
12-21-2006, 12:31 | #12 (permalink) | |
Member: 152752 Status: Offline Sonork: 100.1581661 Thanks Meter: 182 | Quote:
I tryed 7 or more phone, not for me "direct unlock" | |
w880i unlocking problem with cruisere | software zone | D-Unlock Suite | 1 | 09-30-2007 23:37 |
k310i connecting problems with cruiser 10.10 | the ghoste | Cruiser Suite | 0 | 12-20-2006 20:55 |
k310i and k510i Detecting Prob | zubairok | Cruiser Suite | 3 | 11-06-2006 14:15 |
Problem with Cruiser and DSS-25 | Bohosh | Cruiser Suite | 0 | 05-11-2006 12:23 |
Problem with Cruiser 4in1-Cable and ARM-Flashfile for T610 | Megaron | Cruiser Suite | 4 | 06-27-2005 21:41 |
