04-01-2005, 12:38 | #1 (permalink) |
Freak Poster Join Date: Mar 2005 Location: india Age: 55
Member: 125424 Status: Offline Thanks Meter: 21 | k500i blinking problem even i flash it by cruiser 3.40, but now it shows sonyeric when startup, then start blinking. pls.. help thx |
04-01-2005, 20:51 | #2 (permalink) |
No Life Poster Join Date: Oct 2003 Location: Auckland, New Zealand
Member: 42570 Status: Offline Thanks Meter: 11 | Flash not only the Firmware, but also flash fully the FileSystem and then flash a customise file to the phone. The phone will then be alive. From the manual: Go to the Primary Page of the Control Window. Turn the phone off and attach it to the cable (select "Attach To Phone"). If using auto-detect phone type (the default) be sure Cruiser has correctly identified your phone type. If not, detach the phone, remove and insert the battery and then manually select your phone type from the menu. If necessary, select the Locks tab and press "Unlock RSA". Then reattach the phone. Select your desired language and the desired filesystem (languages are stored in the filesystem image). Be sure to match the correct firmware with the correct filesystem. Select the Flash tab, press "Flash ARM" and select the Firmware image to flash to the phone, Cruiser will then flash the Firmware to the phone. Select the File System tab, press "Write Raw FS" and then select the FileSystem image. Cruiser will then flash the FileSystem to the phone. Select the "Customize FS" option, then flash the correct cusomisation file for the type of phone you're flashing. If you forget to do this step when you power the phone on you will recieve the message "Configuration Error..." on the display. Select "Shutdown FS" and detach the cable. |
04-02-2005, 08:00 | #4 (permalink) |
No Life Poster Join Date: Feb 2003 Location: ..::India::.. Age: 40
Member: 22538 Status: Offline Sonork: 100.67180 Thanks Meter: 2,252 | amarjeet,, you have to pick the fw and fs files from the same folder, after that customize fs and shutdown fs,, if any problem,, give me a call. WBR Naman |
04-02-2005, 08:39 | #5 (permalink) |
No Life Poster Join Date: Jun 2004 Location: MACEDONIA
Member: 67805 Status: Offline Thanks Meter: 364 | Main firmware + same FS (lang-file) + generic costumization (untick check where is latin costumization and select from folder generic costumization). I repaired one k500 blinking and must work. wbr. |
04-09-2005, 22:31 | #7 (permalink) |
Member: 42570 Status: Offline Thanks Meter: 11 | amarjeet: Please tell us what files you are using and explain (in detail) the procedure you're using. I suspect you're mixing up files or forgetting to flash part of the phone. |
04-09-2005, 23:35 | #8 (permalink) |
No Life Poster Join Date: Sep 2003 Location: Belgium - SYRIA
Member: 39014 Status: Offline Thanks Meter: 7 | @ amarjeet As previuosly told before If the full flashing didn't solve the problem then you may have Hardware problem. Try to reflow the flash IC , but be carefull not to exceed the tempratur, otherwaise you will damage the IC for full flashing , 1. after booting .. make full flash you can download the MAIN FS file from zone 1 ( it depends on the language you like ) as example KF500_CXC125873_EU1_R2AA003_Red29.rar 2. then after finished make language flash from RAW FS folder as example KF500_CXC125879_EMEA7_R2AA003_Red29.rar 3. then go to file system folder and make finalization good luck RJS |
04-10-2005, 12:09 | #9 (permalink) |
Member: 125424 Status: Offline Thanks Meter: 21 | hello friends first had unlock RSA detach phone reatach Analyzing RSA protection... RSA protection is weak. RSA protection weakness type: PERMANENT Flash file: "KF500_CXC125885_HongKong_R2Y005_Red29.ck5sw" Waiting for flash file to load... Preparing to program flash... Baudrate = 921600Bd Programming flash... Time: 00:03:56 Flash process done. Flash file: "KF500_CXC125961_HongKong_R2Y005_Red29.ck5fs" Waiting for flash file to load... Preparing to program flash... Programming flash... Time: 00:01:13 Flash process done. then detach retach Flash file: "K500_generic.cc10" Defeating RSA protection... Defeated! Sending CS applet... Initializing CS applet... Baudrate = 921600Bd Starting up GDFS service... Starting up filesystem, please wait... Customizing phone... Done. Uploading certificates... Certificates uploaded successfuly. Turning off phone... GDFS access terminated. Phone automatically detached. also i tried "K500_EMEA2.cc10" but no use also Tried to reflow the flash IC pls........... help thx to everybody for ans. wating.. |
k500i blinking? | DjSwift | Cruiser Suite | 2 | 11-18-2007 10:19 |
SE K500i blinking lcd if sim inserted :s | janar_jk | Sony Ericsson Hardware Repair | 0 | 12-01-2005 07:50 |
K500i Camera Problem need suggestion | .::Zafar Communication::. | Sony Ericsson | 3 | 10-29-2005 12:34 |
k500i blinking | paklink | FuriouS II | 10 | 10-13-2005 19:26 |
