Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > Cruiser Suite
Old 10-07-2008, 17:48   #1 (permalink)
F@RUK S's Avatar
Member: 51153
Sonork: 100.113241
K530 problem with SE Ultimate Unlocker v2.00
  18:47:15  SE Ultimate Unlocker v2.00 by Cruiser Team
  18:47:15  - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change
  18:47:15  Initializing...
! 18:47:15  1. Please see the documentation first (the tab 'Info' or attached .pdf file)
! 18:47:15  2. Choose the phone model
! 18:47:15  3. Select the desired options
! 18:47:15  4. Please connect the phone either via USB while holding 2-5…
! 18:47:15  - or via a serial cable and double-click on it in the device list
  18:47:25  Selected phone: K530
  18:47:25  Connecting via Generic EMP USB Flash Device (USB3)…
  18:47:25  Device driver version: 2.0.0.4
  18:47:25  Device driver date: 9-12-2007
  18:47:26  Connecting to the baseband CPU...
  18:47:26  Entering baseband CPU service mode...
  18:47:26  Detected chipset: DB2020
  18:47:26  Boot mode: ROM
  18:47:26  Sending loader...
  18:47:26  IMEI: 35602702100177
  18:47:26  Please reconnect the phone (disconnect, connect while holding 2-5)
  18:47:36  Sending loader...
E 18:47:39  Error: 0x916000B5
E 18:47:39  Error: 0x10BE36DC
E 18:47:39  Error: 0x59AF7680
E 18:47:39  Failed!
! 18:47:39  Please disconnect battery and cable from the phone!
! 18:47:39  To report errors right-click this window
Old 10-08-2008, 13:18   #2 (permalink)
Member: 670274
Hi,
This is a 'GDFS startup failed' problem. This case is not related to wrong gdfs configuration, so the only way how to fix it, is to make GDFS full reconstruction. This feature is currently supported in TestPoint Full Unlocker, and will be supported in the future versions of UltimateUnlocker, too.
GLaDOS
problem with SE ultimate unlocker Wizard715 Cruiser Suite 1 12-19-2008 09:54
Repairing dead W880i error with SE Ultimate Unlocker 2.00 danned Cruiser Suite 13 10-08-2008 22:59
Problem with SE ultimate Unlocker Wizard715 Cruiser Suite 5 09-28-2008 23:45
problem with SE Ultimate Unlocker v1.01 Bernie Cruiser Suite 13 09-28-2008 15:23
Page generated in 0.46768 seconds with 11 queries
