07-14-2006, 13:41 | #1 (permalink) |
No Life Poster Join Date: Feb 2006 Location: EDSELLULAR
Member: 236564 Status: Offline Sonork: 100.1667122 Thanks Meter: 816 | K600 problem HW or SW??? Version 9.74 ready! [ --- Attach to Phone --- ] Connecting via Fighter USB Cable... Powering on the phone... Baseband chip ID: 0x7100 Protocol version: 3.1 Baudrate = 460800Bd Sony Ericsson phone detected. Phone CID: 49 Phone color: Red Flash certificate: A1_DB2000_49_RED Trying Red CID49 flash applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 1s Initializing phone hardware... Applet ID: 050810 0923 NPA1CXC125871_PRODUCTION_ID_LOADER R2B Flash manufacturer: Intel Flash ID: 0x890D OTP Security Level: 1 (Retail) OTP CID: 49 Sending applet... Applet ID: 050926 1419 NPA1CXC1250163_SEMC_FLASHLOADER R2A RSA protection state cannot be determined for this CID. Phone hardware initialized OK [ --- Flash Main Firmware --- ] Flash file: "K600i_CXC1250014_Europe1_R2BA019.ck6sw" Waiting for flash file to load... Preparing to program flash... Defeating RSA protection... Waiting for the phone to turn off... Should the communication hang, reinsert battery. Baudrate = 460800Bd Sending applet prologue... Sending applet body... Waiting for acknowledge... This may indicate damaged EROM area! Try repairing the phone via testpoint method. If it is an old phone, try converting it to brown first. Script error: Unspecified [9.74.41] (of course i unlock RSA first) any idea??? dezel |
07-14-2006, 13:45 | #2 (permalink) |
Member: 236564 Status: Offline Sonork: 100.1667122 Thanks Meter: 816 | trying repair via testpoint System diagnostics passed. Version 9.74 ready! [ --- Attach to Phone --- ] Connecting via Fighter USB Cable... Connect the testpoint! Powering on the phone... Baseband chip ID: 0x7100 Protocol version: 3.1 Baudrate = 460800Bd Trying recovery applet... Sending applet prologue... Disconnect the testpoint! Sending applet body... Time spent entering bootstrap: 6s Initializing phone hardware... Applet ID: 040422 0732 LLECXC1325413_CERTLOADER R3L Flash manufacturer: Intel Flash ID: 0x890D OTP Security Level: 1 (Retail) OTP CID: 49 Defeating RSA protection... Defeated! Sending applet... Applet ID: 060207 0226 CRUCXC1325712_PRODUCTION STD Flash manufacturer: Intel Flash ID: 0x890D OTP Security Level: 1 (Retail) OTP CID: 49 Analyzing configuration... Failed! BATTERY VOLTAGE OR USB TRANSFER SIZE MAY BE TOO LOW! Phone hardware initialized OK Applet error: ERROR|GetFlashInfo| |
07-15-2006, 05:29 | #4 (permalink) | |
Member: 236564 Status: Offline Sonork: 100.1667122 Thanks Meter: 816 | Quote:
this is CID49. i try to convert it to brown (via TP) but i get error Analyzing configuration... Failed! BATTERY VOLTAGE OR USB TRANSFER SIZE MAY BE TOO LOW!: Phone hardware initialized OK [ --- Change Certificate Color --- ] Replacing primary certificate... Phone automatically detached. Last edited by rea1One; 07-15-2006 at 10:03. | |
07-15-2006, 11:13 | #7 (permalink) |
Member: 236564 Status: Offline Sonork: 100.1667122 Thanks Meter: 816 | i used fully charged battery but the same same error BATTERY VOLTAGE OR USB TRANSFER SIZE MAY BE TOO LOW!: and i try also use power supply it measures 3.8volts - 4.0volts but the same error BATTERY VOLTAGE OR USB TRANSFER SIZE MAY BE TOO LOW!: |
07-30-2006, 07:49 | #11 (permalink) |
No Life Poster Join Date: Apr 2005 Location: .... Ghari Matani ...... Age: 18
Member: 135601 Status: Offline Sonork: 100.1612518 Thanks Meter: 68 | i also hve same error like dis (((BATTERY VOLTAGE OR USB TRANSFER SIZE MAY BE TOO LOW!: )) .. wid K700i ... st time its connect & working bt after flah i try again & foun tht .. SImple falsh wid HWK ..... u also try wid HWK .. possible dis will work for U?? BR |
07-30-2006, 09:38 | #12 (permalink) | |
Freak Poster Join Date: Jan 2003 Location: INSIDE INTEL
Member: 19616 Status: Offline Thanks Meter: 23 | Quote:
· Connect the phone to the cable and select Normal boot. · Attach Cruiser to the phone. · Go to the Security RSA page and replace the certificate by Brown CID49. Remove battery when asked by Cruiser. If this process fails, the phone has a locked-down EROM area and therefore it cannot be converted to Brown CID49. · Now press the Direct Unlock button. Newer phones with locked-down EROM area: · Be sure to have installed the latest Cruiser firmware restoral package from our support area. · Connect the phone to the cable and select Normal boot. · Attach Cruiser to the phone. · Go to the Security RSA page and press the Unlock RSA button. Remove battery when asked by Cruiser. This will overwrite part of main firmware by special code thus causing the phone to appear "dead". · Reinsert the battery and reattach Cruiser to the phone. · Go to the Security RSA page and press the Restore firmware button. Cruiser will search for a restore file then. If it cannot be found, you will also have to reflash main FW and raw FS and to customize the phone. · Now go to the Locks page and press the Direct unlock button. Remember, if you encounter any new firmware it is wise to make a security zone backup too (or a full GDFS backup). Note: You may use the Ctrl-A key combination to attach the phone and the Ctrl-O key combination to turn the phone off. | |
07-30-2006, 20:42 | #13 (permalink) |
Major Poster Join Date: May 2006
Member: 280339 Status: Offline Thanks Meter: 0 | If u see "battery too low" plz check the phone plug in socket, because sometime water damage at this place or u can try reheat charging chips, if u use power supply, the current for k600, k700,k750....is 0.04-0.06(frist press the power button), if high then this current will get battery too low. |
07-31-2006, 09:47 | #15 (permalink) | |
No Life Poster Join Date: Aug 2005 Age: 41
Member: 170313 Status: Offline Thanks Meter: 46 | Quote:
Another R600: is it HW or SW problem? | johny3310 | Sony Ericsson Hardware Repair | 4 | 04-26-2003 23:03 |
8310 problem: HW or SW? | chris_ua | Nokia Digital Core Technology 4 ( DCT-4 ) | 3 | 09-27-2002 08:08 |
Trium Mars: HW or SW problem? | levsha | Mitsubishi | 7 | 06-30-2002 20:39 |
8810 Hangs . HW or SW PROBLEM PLZ ?! | makona | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 05-29-2001 14:31 |
