11-26-2008, 19:37 | #1 (permalink) |
No Life Poster Join Date: Jan 2006 Location: JAMAICA Age: 46
Member: 220143 Status: Offline Thanks Meter: 108 | K608 Need GDFS Repair Is it possible to repair a damaged GDFS (RED BLINK) for K608i using Suite? Please I dont see this model in the menu. What is the procedure for doing this? |
11-27-2008, 14:27 | #5 (permalink) | |
Freak Poster Join Date: Aug 2007
Member: 570050 Status: Offline Thanks Meter: 14 | K608i can use Firmware K600i Quote:
2nd : See&Check, what tab in that aplication is actived & can U use You can try to repair GDFS with file @ X:\Program Files\Cruiser\Supplementary Files\Full_GDFS\K600 ===================================== X: >>> is the actice drive of Ur system computer ===================================== before you can find that file and flashing, U must install :
Flash that file to your phone. If everything going well .... than flash Main Firmware > FS > Customize (with desire firmware version) Post Your result here | |
11-29-2008, 00:13 | #6 (permalink) | |
Member: 220143 Status: Offline Thanks Meter: 108 | Quote:
System diagnostics passed. Version 13.20 ready! [ --- Attach to Phone --- ] Connecting via Fighter USB Cable... Powering on the phone... Baseband chip ID: 0x7100 Protocol version: 3.1 Baudrate = 460800Bd Booting via ROM... Sony Ericsson phone detected. Phone CID: 37 Phone color: Brown Flash certificate: A1_DB2000_37_BROWN Trying Brown CID37 flash applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 2s Initializing phone hardware... Applet ID: 050810 0923 NPA1CXC125871_PRODUCTIO... Flash manufacturer: Intel Flash ID: 0x890D OTP Security Level: 1 (Retail) OTP CID: 37 Sending applet... Applet ID: 060207 0226 CRUCXC1325712_PRODUCTIO... Analyzing configuration... Failed! BATTERY VOLTAGE OR USB TRANSFER SIZE MAY BE TOO LOW! Analyzing RSA protection... Phone hardware initialized OK [ --- Flash Main Firmware --- ] Flash file: "K600i_FullGDFS_version1.ck6sw" Waiting for flash file to load... Preparing to program flash... Programming flash... Flash color/CID mismatch! Script error: Flash error [13.20.77] What should I do now. Thanks | |
11-29-2008, 10:50 | #7 (permalink) |
No Life Poster Join Date: Apr 2005 Location: between New Zealand - Canada Age: 42
Member: 135110 Status: Offline Thanks Meter: 302 | check that: BATTERY VOLTAGE OR USB TRANSFER SIZE MAY BE TOO LOW! and of crouse, before doing anything you have to unlock RSA. |
11-29-2008, 11:02 | #8 (permalink) |
Super Moderator Join Date: Aug 2005 Location: UK.... Age: 57
Member: 173077 Status: Offline Sonork: 100.1594293 Thanks Meter: 2,784 | This phone wont power up BECAUSE its BROWN,,,, untill certifaite is CHANGED to RED it wont WORK......... CID 37 Have to be RED........ Last edited by THE CLASH; 11-29-2008 at 11:09. |
11-29-2008, 22:19 | #10 (permalink) | |
Please how do I change the CID to RED then? You all have been very helpfull, I am learning alot. thanks | |
12-03-2008, 22:35 | #13 (permalink) |
Member: 173077 Status: Offline Sonork: 100.1594293 Thanks Meter: 2,784 | In supplemtry folder, you will find Eroms,, Flash cid 37 red as main, But if your Phone has some Hardware Issues you wont Repair this Phone. |
need gdfs repair without tp... | chandupyari | Universalbox | 1 | 05-02-2009 18:45 |
we need GDFS repair | taalhaat | Universalbox | 10 | 10-14-2008 14:06 |
Db Team We Need Db2012 W200 Gdfs Repair Solution | sairat | DreamBox | 3 | 05-22-2008 08:55 |
8380 gdfs repair - help needed | sgufa | Cruiser Suite | 0 | 01-02-2007 12:13 |
Need GDFS files for Repair R520m | -=SanSanyc=- | Sony Ericsson | 1 | 07-13-2003 21:30 |
