Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > Cruiser Suite
Old 01-12-2006, 11:17   #1 (permalink)
Member: 68672
Thanks Meter: 6
K608i Dead After repairing certificate
hi cruiser team
K608i Red After repairing certificate any solution?
i have try to repair eerom but it says eerom file not found.is there any solution
Plz help me soon
thanx in advance
Naresh
Old 01-12-2006, 18:04   #2 (permalink)
muppet's Avatar
Member: 42570
Thanks Meter: 11
What colour is the flash certificate at the moment?
It's well known that CID37 phones will not power on if you leave the certificate as brown when the CID certificate is red. Convert back to Red (once you have unlocked/flashed etc) and it will not be "dead" anymore.
Old 01-13-2006, 00:09   #3 (permalink)
rjsoo7's Avatar
Member: 39014
Thanks Meter: 7
K608 not working
Originally Posted by Naresh
hi cruiser team
Plz help me soon
thanx in advance
Naresh
hi
When you press the power button " If the RED led flashes "
then your phone is BROWN and will bot work untill if you convert itback to
RED as muppet said ..
Just convert it back to RED and all will be fine
RJS
Old 01-16-2006, 10:24   #4 (permalink)
Member: 68672
Thanks Meter: 6
its red dear friend in certificate.
is there any solution.
naresh
Old 01-16-2006, 19:42   #5 (permalink)
muppet's Avatar
Member: 42570
Thanks Meter: 11
Naresh: Post log of attaching to phone here please.
Old 01-17-2006, 08:00   #6 (permalink)
Member: 68672
Thanks Meter: 6
thanx friends i got it back
thanx
Naresh
Old 01-20-2006, 15:40   #7 (permalink)
gsm-decode's Avatar
Member: 47441
Thanks Meter: 14
What does this error mean?
Applet error: ERROR GETTING THE FIRST FLASHDEVICE
The applet has intentionally turned the phone off!
Script error: Unspecified [8.00 alpha.30]
Old 01-20-2006, 20:39   #8 (permalink)
muppet's Avatar
Member: 42570
Thanks Meter: 11
According to this post, it's a hardware problem.
Old 01-29-2006, 11:18   #9 (permalink)
gsm-decode's Avatar
Member: 47441
Thanks Meter: 14
Well is the second phone with this problem
I think there is a bug in Cruiser.
After converting to brown it stopes and ow says this
What is the problem?
Can this be repaired?
Rgds
Old 01-29-2006, 21:14   #10 (permalink)
Lead's Avatar
Member: 1841
Thanks Meter: 469
Rgds
What is the OTP CID of that phone?
Have you used TP to convert it to brown?
Old 01-29-2006, 21:44   #11 (permalink)
Registered User
mr_x4you's Avatar
Member: 4989
Thanks Meter: 13
I did one today with this problem, resistor was broken, I replaced it, and all is ok now
Old 01-30-2006, 00:28   #12 (permalink)
Member: 67104
Thanks Meter: 2
plz which resistor u used to change it i have one dead
Old 01-30-2006, 10:41   #13 (permalink)
gsm-decode's Avatar
Member: 47441
Thanks Meter: 14
Ok
Problem solved!
It's good when you have all boxes working.
Rgds
Old 01-30-2006, 18:33   #14 (permalink)
Registered User
mr_x4you's Avatar
Member: 4989
Thanks Meter: 13
If you have that message ,it means that resistor is broken, that's a 30 ohm resistor, you must change it
Old 01-31-2006, 19:07   #15 (permalink)
Member: 135688
PLEASE I USED UFS-SONIC TO UNLOCK K608i
AND AFTER IT ONLY BLINK THE RED LIGHT ON IT. IT DOES NOT COME ON
BUT STILL RESPONDCE TO SONIC AND DICTECT CID 37, BROWN AND SO ON
PLEASE CAN UFS-SONIC CHANGE THE CERT TO RED? PLS IF YES HOW?
PLEASE STEP BY STEP PROCIDURE PLEASE
THANXXX
BIGDADA
K608i dead after READ ! karletto66 SonyEricsson (USB-Smart) 31 02-28-2009 09:19
w800i dead after replacing certificate to brown ber747 Cruiser Suite 10 07-26-2006 22:37
k608i dead after unlock without tp basim Sony Ericsson 5 03-24-2006 15:44
k608i dead after unlock SIXTUS Sony Ericsson 2 11-30-2005 07:47
k608i dead after unlocking & cid changing adam92se Sony Ericsson 2 11-27-2005 17:05
Page generated in 0.22203 seconds with 9 queries
