Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > Cruiser Suite
Old 04-19-2007, 16:15   #1 (permalink)
Member: 247981
Problem after unlock K700i :(
Hi,
I have to unlock a K700i with cruiser and after an message indicate:
" error of configuration, contact network operator...."
Please give me a correctly method for unlock and repair my K700i
I have to use this method:
1) Attach to phone and Unlock RSA
2) Flash Main Firmware by using the "Flash ARM" button.
3) Flash Raw FileSystem by using the "Write raw FS" button - Note down what langpack you used (For example, EU5)
4) Under "Customize FS" menu, select the same information as the langpack you wrote in step 3. In the free text field, type in the firmware version (for exmaple R1Y005) you've flashed to the phone.
5) Now click Customise FS
6) Go to File System tab and click on "Shutdown FS"
Thx.
Sully.
Old 04-19-2007, 16:31   #2 (permalink)
Member: 201126
hi
try this proceduer
3) after write fs just custo mize it
Old 04-19-2007, 16:38   #3 (permalink)
mily2's Avatar
Member: 290638
Thanks Meter: 50
atatch phone and post log
Old 04-19-2007, 17:10   #4 (permalink)
..::GsmEasy::..'s Avatar
Member: 292695
Thanks Meter: 43
try with just read codes and and put one by one all or write GDFS
Old 04-19-2007, 17:27   #5 (permalink)
Member: 247981
k700i...
My phone indicate after "attach phon":
System diagnostics passed.
Version 10.41 alpha ready!
[ --- Attach to Phone --- ]
Connecting via Fighter USB Cable...
Powering on the phone...
Baseband chip ID: 0x8000
Protocol version: 3.1
Baudrate = 460800Bd
Booting via ROM...
Sony Ericsson phone detected.
Phone CID: 29
Phone color: Red
Flash certificate: A1_SEMC
Trying Red CID29 flash applet...
Sending applet prologue...
Sending applet body...
Time spent entering bootstrap: 2s
Initializing phone hardware...
Applet ID: 040618 1025 LLECXC1326738_COMPACTFL...
Flash manufacturer: ST Microelectronics
Flash ID: 0x200D
OTP Security Level: 1 (Retail)
OTP CID: 29
Analyzing configuration...
Reading primary certificate...
Primary certificate CID: 29
Primary certificate color: Red
Secondary certificate not found.
GDFS configuration found.
OSE configuration found.
TestProgram configuration not found.
Analysing GDFS...
Done.
Analyzing RSA protection...
RSA protection is weak.
RSA protection weakness type: PERMANENT
Phone hardware initialized OK
Old 04-20-2007, 04:01   #6 (permalink)
MATRIX.REAL's Avatar
Member: 202333
Thanks Meter: 178
write GDFS + direct unlock then CUSTOMIZE ...
Old 04-20-2007, 05:16   #7 (permalink)
jjosef's Avatar
Member: 56634
Thanks Meter: 71
conwert on brown.............
Old 04-20-2007, 08:53   #8 (permalink)
sven.soltermann's Avatar
Member: 44110
It's a CID 29 phone with already unlocked RSA zone. No need to convert to brown.
Old 04-20-2007, 15:40   #9 (permalink)
Member: 247981
ok but.....
I succeeded has to remove the error message, but when i insert sim the phone indicate "SIM INACTIVE"
Thx.
Old 04-20-2007, 15:45   #10 (permalink)
Member: 247981
ok but.....
I succeeded has to remove the error message. But when i insert the sim card, the phone indicate "INACTIVE SIM"
Please Help...
Thx.
Old 04-20-2007, 16:01   #11 (permalink)
.::AD Com::.'s Avatar
Member: 486626
Thanks Meter: 89
Please Help...
Thx.
your phone imei no is block on network try change imei no and check
post result
Old 04-20-2007, 16:33   #12 (permalink)
platforms's Avatar
Member: 83090
Sonork: 1626857
Thanks Meter: 52
I like the way some of our members advice others. If you can read some replies of our freinds it becomes amasing.
Anyway you only need to unlock RSA and then directly customise your phone. And nothing else.
Problem with unlock Z105 :( gsavv723 NSPRO 2 03-22-2006 17:06
problem RSA unlock k700i Shoja Cruiser Suite 12 12-23-2005 10:28
Display problem after unlocking T10s 00w48 Rik Old Ericsson Phones & Sony Phones 9 03-20-2001 19:07
SH 888 - problem after unlocking mobitech Old Ericsson Phones & Sony Phones 0 08-20-2000 12:42
Page generated in 0.23195 seconds with 9 queries
