12-23-2005, 16:50 | #1 (permalink) |
Freak Poster Join Date: Aug 2005 Age: 51
Member: 170494 Status: Offline Thanks Meter: 9 | k700i cosfiguration problem i have flashed the phone ARM and Raw FS and than costumize FS and after that i git this Error Norespons from aplet . finally i shotdown FS. now if i want to do on the phone i get conriguration Error contact to ....... Thaks and i am waiting for your help??????? Connecting via Fighter USB Cable... Powering on the phone... Baseband chip ID: 0x8000 Protocol version: 3.1 Baudrate = 115200Bd Sony Ericsson phone detected. Phone CID: 29 Phone color: Red Flash certificate: A1_SEMC Trying Red CID29 flash applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 6s Initializing phone hardware... Flash manufacturer: Intel Flash ID: 0x890D OTP Security Level: 1 (Retail) OTP CID: 29 Phone hardware initialized OK Analyzing configuration... Reading primary certificate... Primary certificate CID: 29 Primary certificate color: Red Secondary certificate not found. OSE configuration found. Analysing GDFS... Done. Analyzing RSA protection... RSA protection is weak. RSA protection weakness type: PERMANENT Defeating RSA protection... Sending applet... Defeated! Sending CS applet... |
12-25-2005, 00:04 | #3 (permalink) |
Member: 170494 Status: Offline Thanks Meter: 9 | Hallo Hallo, i ded as you say. but no lock and when i want to unlock RSA and consumize FS than i git thes ERROR( No response from applet Error: Could not initialize GDFS access.) i cant do enything with this phone. i flashed weth the full charged battery, defferent boudrate and i ded anything what i could. and now i dont know more what i must to do to get this phone a live. i flashed again and i give you the log. lock it for my and tell me pls what i must to do???? thanks Version 7.10 beta ready! Connecting via Fighter USB Cable... Powering on the phone... Baseband chip ID: 0x8000 Protocol version: 3.1 Baudrate = 115200Bd Sony Ericsson phone detected. Phone CID: 29 Phone color: Red Flash certificate: A1_SEMC Trying Red CID29 flash applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 5s Initializing phone hardware... Flash manufacturer: Intel Flash ID: 0x890D OTP Security Level: 1 (Retail) OTP CID: 29 Phone hardware initialized OK Analyzing configuration... Reading primary certificate... Primary certificate CID: 29 Primary certificate color: Red Secondary certificate not found. OSE configuration found. Analysing GDFS... Done. Analyzing RSA protection... RSA protection is weak. RSA protection weakness type: PERMANENT Flash file: "K700_CXC125821_EU1_R2AE033_Red29.ck7sw" Waiting for flash file to load... Reading phone RSA certificate... Preparing to program flash... Programming flash... Time: 00:20:24 Flash process done. Flash file: "K700_CXC125822_EU3_R2AE033_Red29.ck7fs" Waiting for flash file to load... Reading phone RSA certificate... Preparing to program flash... Programming flash... Time: 00:09:18 Flash process done. Defeating RSA protection... Sending applet... Defeated! Sending CS applet... Initializing CS applet... Initializing CS applet... Initializing CS applet... Phone automatically detached. Applet startup code has failed Applet startup code has failed Applet startup code has failed Error: Could not initialize GDFS access. i am waiting for your help thanks |
12-27-2005, 09:36 | #6 (permalink) |
No Life Poster Join Date: Oct 2003 Location: Auckland, New Zealand
Member: 42570 Status: Offline Thanks Meter: 11 | Shoja: Use the seach feature. Your question has been asked about 5000 before. You need to go to the FileSystem TAB, select the customisation that matches what you flashed to the phone and click on "Customise FS" |
12-27-2005, 16:25 | #7 (permalink) |
Member: 170494 Status: Offline Thanks Meter: 9 | Solve of the problem I had knew how i must to do, but when i must flash the and after cosumize FS, it had stopt. i hove tryed several times with no lock. finaly i must to open the phone to lock inside the phone. inside the phone was derthy and i must to clean it with the tiner and teethsbrush. and then i flashed again ARM, ..., and then *******ze Fs (with succes) and finaly evrything was with succes. thanks for yours help Shoja |
K700i charging problem | simono_xm | Sony Ericsson Hardware Repair | 17 | 06-09-2006 10:17 |
k700i screen problem help plz | fender62 | Sony Ericsson Hardware Repair | 0 | 04-29-2005 18:40 |
K700i headset problems | rikesh | Sony Ericsson Hardware Repair | 3 | 03-13-2005 11:16 |
K700i with problems... | FLaMeWaRe | TOTAL MultiServer | 3 | 12-20-2004 18:03 |
K700i BT problem after flash/decustom. | pali | Griffin | 6 | 12-05-2004 10:18 |
