12-08-2005, 06:23 | #1 (permalink) |
Freak Poster Join Date: Jan 2002 Location: India Age: 48
Member: 8587 Status: Offline Thanks Meter: 4 | The K700i problem... This is a K700i handset which I am not able to switch on. But every time I try to connect I get the following info on the main status window... Version 7.00 alpha ready! Connecting via SEMC DSS-25 SyncStation... Powering on the phone... Baseband chip ID: 0x8000 Protocol version: 3.1 Baudrate = 921600Bd Sony Ericsson phone detected. Phone CID: 29 Phone color: Red Flash certificate: A1_SEMC Trying Red CID29 flash applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 1s Initializing phone hardware... Flash manufacturer: Intel Flash ID: 0x890D OTP Security Level: 1 (Retail) OTP CID: 29 Phone hardware initialized OK Analyzing configuration... Reading primary certificate... Primary certificate CID: 29 Primary certificate color: Red Secondary certificate not found. OSE configuration found. Analysing GDFS... Done. Analyzing RSA protection... RSA protection is normal. Use the Unlock RSA function first! and in the error status window..... GDFS CONFIGURATION MISMATCH! Error code: 2.7.8.17648 Continue at your own risk... Please, disconnect phone and select its type manually. and if I select the phone type manually to K700i and flash full gdfs and arm and the fs, for the first time I switch on the phone It switches on and comes to the please wait window and process till some 40% and then restarts and the display lights blinking.... and then on everytime I try to switchon the mobile it goes into this blinking mode directly... Any good solutions friends. Ciao. |
12-08-2005, 10:44 | #3 (permalink) | |
Member: 8587 Status: Offline Thanks Meter: 4 | Quote:
I did friend but it is still the same..... Ciao | |
12-08-2005, 14:26 | #5 (permalink) | |
Done and no improvements... Ciao. | |
12-09-2005, 10:08 | #9 (permalink) | |
No Life Poster Join Date: Jul 2004 Location: 127.0.0.1 Age: 79
Member: 545165 Status: Offline Thanks Meter: 578 | Quote:
you can always flash with se logs main fs only and detatch , then finalize with cruiser this will not cost a credit ,oops keep that trick quiet rgds Last edited by fonecellar; 12-09-2005 at 18:11. | |
How to make the K700i buzzer louder? | hooi76 | Sony Ericsson Hardware Repair | 0 | 10-27-2005 02:46 |
K700i problem | wazim187 | FuriouS II | 0 | 07-18-2005 02:16 |
k700i problem whith server | zata222 | Redbox | 1 | 06-02-2005 17:23 |
K700i problem | dragc | Sony Ericsson Hardware Repair | 1 | 04-23-2005 18:47 |
k700i problem | Roughrider202 | Cruiser Suite | 21 | 03-21-2005 22:41 |
