11-13-2006, 15:45 | #1 (permalink) |
Freak Poster Join Date: Apr 2004 Location: Buckinghamshire, England Age: 51
Member: 63904 Status: Offline Thanks Meter: 12 | K750 Brown Converted to Red, How to recover?? Have a K750 here that I was asked to flash with W800 firmware, was rushed and under pressure at the time, and accidently converted it from Brown to Red. Done a search on how to fix this, and not getting on very well with it, It doesn't seem to want to connect via TP either (I may be doing this wrong though, 1st time i've needed to connect a SE via TP!) If anyone has a working solution on how to fix this, it would be greatly appreciated as the customer is flying out of the country for 6months tomorrow!! Regards Mobilesunlocked. PS if it helps I have:- Cruiser UniversalBox GTI |
11-14-2006, 06:16 | #6 (permalink) |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 56
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | At least there no way without testpoint EROM repair operation ... SeTool2 do not work well on f.ucked brown CID 49 phones - http://www.m o b i l e - f i l e s.com/forum/showpost.php?p=176984&postcount=19, so using Cruiser is right choice, but need to use TP to boot phone. So after this you need to write EROM ( at me with W810 erom work fine ) ... boot phone again, without TP and do what you want ... - flash / unlock / customise / revert to RED ect... |
11-14-2006, 10:42 | #7 (permalink) |
No Life Poster Join Date: Apr 2005 Location: between New Zealand - Canada Age: 42
Member: 135110 Status: Offline Thanks Meter: 302 | Hi, recover solution: http://forum.gsmhosting.com/vbb/show...90&postcount=4 Conect phone: -Normal boot with TP2. -Flash ARM this file: http://PhilipFotos.com/SE/EROM_Brown.erom2 -Detach and Atach Phone: Normal boot (no TP) Flash ARM: RDB001 Flash RAW FS: R1DB001 Finalize Phone 100% working REPAIR SOLUTION FOR SAYS: This may indicate damaged EROM area! Try repairing the phone via testpoint method. If it is an old phone, try converting it to brown first and Invalid response Please turn the phone off and then unlock RSA! BR, FL Last edited by FilipLudvik; 11-14-2006 at 10:57. |
How to convert w830i red 51 to red 52 | kalpesh.1978 | Cruiser Suite | 5 | 12-30-2007 23:03 |
K750 to W800 how to ? | sschn07 | Cruiser Suite | 6 | 05-10-2006 14:56 |
6590 TO 6510???? how to convert | andrew14 | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 01-04-2005 09:28 |
6590 TO 6510???? how to convert | andrew14 | Nokia Hardware & Hardware Repair | 0 | 01-02-2005 06:28 |
3310 convert to 3315 How to do it ? | momento | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 10 | 08-19-2004 18:03 |
