10-21-2005, 06:44 | #1 (permalink) |
Freak Poster Join Date: Apr 2002 Location: Malaysia Age: 44
Member: 10977 Status: Offline Thanks Meter: 55 | K750 Camera problem all this kind of problem is only happen on empty baord, so i really think is a software problem. |
The Following User Says Thank You to danielkhaw For This Useful Post: |
10-21-2005, 08:53 | #3 (permalink) |
Member: 10977 Status: Offline Thanks Meter: 55 | already do all flashing again and again already.....still same, just want to know izt anyone have any experiance on this and have to special way or file to fix this kind of problem |
12-09-2005, 17:24 | #6 (permalink) |
Product Manager Join Date: May 2001 Location: Los Angeles
Member: 4584 Status: Offline Sonork: 100.69564 Thanks Meter: 15,093 | Well i have exactly the same problem on my K750i But strange thing is yes recording is working perfect and can save also. Using frames i can take pictures but the frames doesn't appears on the saved images + the quality is 640x480. Anybody found a trick for this ? Any help is welcome. Best regards, Steve. |
12-09-2005, 18:22 | #7 (permalink) |
Member: 4584 Status: Offline Sonork: 100.69564 Thanks Meter: 15,093 | IS OK NOW I have to say that i wanted to change the casing of my K750i because i found 1 cheap W800i casing in china So i flashed my K750 in W800. Flash was ok and new W800i menu in my phone. Then i opened the phone to change the casing so have to remove everything carefully and to transfer all parts in the new W800i casing. After job finish i power on my phone and then trying to take picture but cannot save it So here is the mistake, you have to connect VERY carefully the FLEX CABLE of the camera and MUST BE VERY WELL connected on mother board. I opened my phone again and check connexion with flex cable. Well now my phone is working perfect and i have brand new W800i for the price of K750 I add some pictures here, is this flex cable you have to take care : this one also : after you checked the connexion with flex cable is PERFECT you can try now to take picture before you finish to add screw on phone you will save little time Now can save picture without problems Hope this will help. Best regards, Steve. |
04-17-2009, 02:56 | #15 (permalink) |
Junior Member Join Date: Feb 2009
Member: 966859 Status: Offline Thanks Meter: 3 | hello, someone please help. "the version of camera v.4.4 please update the driver to 4.6" problem in my w600. i need the driver file camera of w600 with version 4.6 to flash it. Thanks in advance |
k750 camera problem | germany | Sony Ericsson Hardware Repair | 39 | 02-28-2011 17:24 |
k750 camera problem | germany | Sony Ericsson Hardware Repair | 1 | 07-30-2007 21:35 |
k750 camera problem | germany | Sony Ericsson Hardware Repair | 0 | 07-30-2007 13:20 |
K750 camera problem | burraq | Sony Ericsson | 1 | 09-30-2006 14:48 |
K750 camera problem no function! sw maybe? | microtel | Universalbox | 4 | 04-04-2006 13:54 |
