04-03-2007, 19:47 | #2 (permalink) |
No Life Poster Join Date: Apr 2004 Location: Milano, Italy Age: 37
Member: 62336 Status: Offline Thanks Meter: 115 | You don't need any TP.. Code: Older phones with unlocked EROM area: · Connect the phone to the cable and select Normal boot. · Attach Cruiser to the phone. · Go to the Security RSA page and replace the certificate by Brown CID49. Remove battery when asked by Cruiser. If this process fails, the phone has a locked-down EROM area and therefore it cannot be converted to Brown CID49. · Now press the Direct Unlock button. Newer phones with locked-down EROM area: · Be sure to have installed the latest Cruiser firmware restoral package from our support area. · Connect the phone to the cable and select Normal boot. · Attach Cruiser to the phone. · Go to the Security RSA page and press the Unlock RSA button. Remove battery when asked by Cruiser. This will overwrite part of main firmware by special code thus causing the phone to appear "dead". · Reinsert the battery and reattach Cruiser to the phone. · Go to the Security RSA page and press the Restore firmware button. Cruiser will search for a restore file then. If it cannot be found, you will also have to reflash main FW and raw FS and to customize the phone. · Now go to the Locks page and press the Direct unlock button. Remember, if you encounter any new firmware it is wise to make a security zone backup too (or a full GDFS backup). Note: You may use the Ctrl-A key combination to attach the phone and the Ctrl-O key combination to turn the phone off. Bypx PS: The user manual is a very good friend. |
04-03-2007, 19:50 | #3 (permalink) |
No Life Poster Join Date: Nov 2005 Location: MATRIX.REAL
Member: 202333 Status: Offline Thanks Meter: 178 | NO NEED TP FRIEND ... just do attach phone unlock rsa attach phone again direct unlock RESTORE FIRM already posted PLZ next time use search button or read manual guide ... |
04-27-2007, 22:44 | #7 (permalink) | |
No Life Poster Join Date: Nov 2006 Location: Where money is made Age: 33
Member: 390642 Status: Offline Sonork: 100.1573430 Thanks Meter: 2,476 | Quote:
1.Attach the phone 2.Go to security tab then unlock rsa 3.Attach again 4.Go to security tabs and restore frimware 5.Then go to lock tabs and press direct unlock BR, Tito Millo | |
04-27-2007, 22:50 | #8 (permalink) |
Member: 390642 Status: Offline Sonork: 100.1573430 Thanks Meter: 2,476 | For db2020 flashing u need to use logs....only u have to do this: 1.Attach the phone 2.Go to flash tab and write sw and fs 3.Then selec the languaje that u want in the tab down teh custimize option and cuztomize fs 4.Go to file systen tab and shutdown Fs BR, Tito Millo |
05-30-2007, 17:36 | #9 (permalink) | |
Junior Member Join Date: Oct 2006
Member: 363420 Status: Offline Thanks Meter: 0 | I realy arreciate your advice Quote:
Your procedure works 100% Your are good With regards | |
07-23-2007, 13:26 | #11 (permalink) |
Freak Poster Join Date: Sep 2006
Member: 341812 Status: Offline Thanks Meter: 7 | System diagnostics passed. Version 10.42 alpha ready! [ --- Attach to Phone --- ] Connecting via UC-10 Universal Cable... Powering on the phone... always that messege appear reinsert battery nothing wat can i do i tried more times please helping |
w810i unlock | wayne_icu | SonyEricsson (USB-Smart) | 25 | 07-24-2006 19:20 |
w810i unlock help | smart phones | SonyEricsson (USB-Smart) | 16 | 05-07-2006 22:11 |
so solution for W810i unlock ??? | the new | SonyEricsson (USB-Smart) | 6 | 04-14-2006 00:45 |
w810i unlock ????? | gadzetxp | MT-BOX | 0 | 04-11-2006 21:41 |
