Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > Cruiser Suite
Old 05-13-2006, 14:23   #1 (permalink)
Member: 94508
k750i CID49 Problem
i have a little problem with k750i
Sony Ericsson phone detected.
Phone CID: 49
Phone color: Red
Flash certificate: A1_DB2010_49_RED
OTP CID: 49
Sending applet...
RSA protection state cannot be determined for this CID.
Phone hardware initialized OK
then
unlock rsa ok
Please remove battery from the phone...
Remember to restore the main firmware in the end.
Unlocking RSA damages first 128/256KB of main FW in red CID49 phones.
but when i try to flash restore files;
Should the communication hang, reinsert battery.
Baudrate = 460800Bd
Sending applet prologue...
Sending applet body...
Waiting for acknowledge...
Invalid response
Please turn the phone off and then unlock RSA!
Script error: Unspecified [9.61.41]
i try to convert it to brown49 but no luck it cant, so i try with testpoint its converted to brown49 but then cruiser says i must to have erom repair but when press button it says erom file for this phone not found or something like this.
can anyone help me?
P.S: i tried these for more than 10 times but no luck...
Old 05-13-2006, 14:25   #2 (permalink)
Member: 223442
you don't need convert red to brown!
Old 05-13-2006, 14:53   #3 (permalink)
Lead's Avatar
Member: 1841
Thanks Meter: 468
I am uploading new user manual right now.
Old 05-13-2006, 16:15   #4 (permalink)
Member: 94508
ok, thanks for guide but....;
Version 9.63 ready!
attaching Phone:
OTP CID: 49
Sending applet...
attaching ok!!!
Programming flash...
Time: 00:00:01
Flash process done.
Phone automatically detached.
Unlocking Rsa Ok!!!
re-attaching (removing battery.....) Ok!!!
Security RSA Tab-->Restore Firmware
Baudrate = 460800Bd
!! It hangs there and;
Invalid response
You have to reflash main FW.
i tryed to flash main fw but same it hangs on Waiting acknowledge...
So i try to change phone color to brown --> cruiser says changed but when i re attach i can see its red
so i tryed to change phone color with tp... but when i changed the phone color i cant flash main fw or raw fs cause cruiser says repair erom but repairing erom impossible .. am i right?
i try all combinations but i cant get the phone alive...
Old 05-17-2006, 11:27   #5 (permalink)
Member: 94508
v9.66 tested ..... still same problem...
Old 05-17-2006, 11:46   #6 (permalink)
Member: 94508
all senario caught on;
The phone contains recovery certificate!
You MUST repair EROM!
Sorry, no EROM is available for this phone.
will erom for this phone be avaible soon?
Old 05-17-2006, 12:35   #7 (permalink)
Member: 248353
Thanks Meter: 3
flash db2010 erom browncid49
Old 05-17-2006, 14:20   #8 (permalink)
Member: 94508
already tried;
after flashing erom;
Phone CID: 36
Phone color: Red
Flash certificate: A1_DB2010_36_RED
Trying Red CID36 flash applet...
Trying CID16 recovery applet...
All threads terminated.
cruiser cant detect phone normally so i use tp and change cert. to red49 but phone dead always...
Old 05-17-2006, 14:23   #9 (permalink)
Member: 94508
and by the way the file with k750i extension is;
DB2010_EROMRed36_signed_by_Brown36.erom2
i flashed with that file
you are saying brown49 only file with brown49 is;
DB2010_W810_EROMBrown49_signed_by_Brown49.erom4
its for w810, thanks anyway...
Old 05-17-2006, 15:42   #10 (permalink)
davesmobiles's Avatar
Member: 92178
Thanks Meter: 14
I have the same problem as you.. hangs at Waiting for acknowledge and if use a testpoint says no erom available so can't repair.
Seems a problem that is spreading. Hopefully a solution is found soon
k750i CID49 flash problems all-gsm Sony Ericsson 9 10-08-2007 11:44
K750i CID49 problem ayaz ali Cruiser Suite 4 06-10-2007 16:03
k750i cid49 problem it says erom may be damaged vish_thakkar786 Cruiser Suite 17 11-09-2006 02:58
K750i CID49 error 302324 OR 303041 - need CID49 EROM? DarrenNewsgroup SonyEricsson (USB-Smart) 2 08-25-2006 12:46
K750i CID49 Red ??? blackrose Cruiser Suite 3 04-15-2006 10:34
Page generated in 0.35146 seconds with 8 queries
