08-03-2006, 20:41 | #1 (permalink) |
No Life Poster Join Date: Apr 2003 Location: ROMANIA Age: 45
Member: 26714 Status: Offline Thanks Meter: 14 | k750i problem cid 49 Pls need advice.Tnx |
08-04-2006, 02:09 | #2 (permalink) | |
No Life Poster Join Date: May 2005 Location: Denmark Age: 42
Member: 146369 Status: Offline Thanks Meter: 119 | Quote:
Also remember to recalculate CRCs wbr | |
08-04-2006, 04:26 | #3 (permalink) | |
Insane Poster Join Date: Apr 2006 Location: Xintang Canton P.R.China Age: 45
Member: 255886 Status: Offline Thanks Meter: 0 | Quote:
Use the R1BC002 version,1000% work. | |
08-05-2006, 12:30 | #4 (permalink) |
No Life Poster Join Date: May 2005 Location: CellcomEngineering Age: 41
Member: 147116 Status: Offline Sonork: 100.1578260 Thanks Meter: 316 | thanks bro............. nice work................. many many thank to you.................. 10000000000000000000000000000000% working................... |
09-25-2006, 18:31 | #5 (permalink) |
No Life Poster Join Date: Nov 2002 Location: Canary Islands Age: 53
Member: 17351 Status: Offline Thanks Meter: 41 | Good post this thanks! I was trying all sorts of firmware and this one worked! cheers Not quite ok says configuration error with sim but Im sure I can sort that |
09-26-2006, 08:39 | #6 (permalink) |
No Life Poster Join Date: May 2005 Location: iran Age: 43
Member: 143648 Status: Offline Thanks Meter: 179 | see this System diagnostics passed. Version 9.74 ready! [ --- Attach to Phone --- ] Connecting via Fighter USB Cable... Powering on the phone... Baseband chip ID: 0x8040 Protocol version: 3.1 Baudrate = 460800Bd Sony Ericsson phone detected. Phone CID: 49 Phone color: Red Flash certificate: A1_DB2010_49_RED Trying Red CID49 flash applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 2s Initializing phone hardware... Applet ID: 060206 1814 NPACXC125872_COMPACTPRODUCTION_ID_LOADER P3H Flash manufacturer: ST Microelectronics Flash ID: 0x200D OTP Security Level: 1 (Retail) OTP CID: 49 Sending applet... Applet ID: 050909 1014 NPACXC1250165_1_SEMC_COMPACTFLASHLOADER R2A RSA protection state cannot be determined for this CID. Phone hardware initialized OK [ --- Unlock RSA --- ] Preparing to program flash... Baudrate = 921600Bd Programming flash... Time: 00:00:00 Flash process done. Phone automatically detached. [ --- Attach to Phone --- ] Connecting via Fighter USB Cable... Powering on the phone... Baseband chip ID: 0x8040 Protocol version: 3.1 Baudrate = 460800Bd Sony Ericsson phone detected. Phone CID: 49 Phone color: Red Flash certificate: A1_DB2010_49_RED Trying Red CID49 flash applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 2s Initializing phone hardware... Applet ID: 060206 1814 NPACXC125872_COMPACTPRODUCTION_ID_LOADER P3H Flash manufacturer: ST Microelectronics Flash ID: 0x200D OTP Security Level: 1 (Retail) OTP CID: 49 Sending applet... Applet ID: 050909 1014 NPACXC1250165_1_SEMC_COMPACTFLASHLOADER R2A RSA protection state cannot be determined for this CID. Phone hardware initialized OK [ --- Direct Unlock --- ] Defeating RSA protection... Waiting for the phone to turn off... Should the communication hang, reinsert battery. Baudrate = 460800Bd Sending applet prologue... Sending applet body... Waiting for acknowledge... Defeating RSA protection... Waiting for the phone to turn off... Should the communication hang, reinsert battery. Baudrate = 460800Bd Sending applet prologue... Sending applet body... Waiting for acknowledge... Defeating RSA protection... Waiting for the phone to turn off... Should the communication hang, reinsert battery. Baudrate = 460800Bd Sending applet prologue... Sending applet body... Waiting for acknowledge... Defeating RSA protection... Waiting for the phone to turn off... Should the communication hang, reinsert battery. and when reinsert batt repeat this error i cant flash this phone |
09-26-2006, 08:41 | #7 (permalink) |
Member: 143648 Status: Offline Thanks Meter: 179 | when boot by test point show this [ --- Attach to Phone --- ] Connecting via Fighter USB Cable... Connect the testpoint! Powering on the phone... Baseband chip ID: 0x8040 Protocol version: 3.1 Baudrate = 460800Bd Trying recovery applet... Sending applet prologue... Disconnect the testpoint! Sending applet body... Time spent entering bootstrap: 6s Initializing phone hardware... Applet ID: 040319 0923 LLECXC1326739_COMPACTCERTLOADER R2E Flash manufacturer: ST Microelectronics Flash ID: 0x200D OTP Security Level: 1 (Retail) OTP CID: 49 Defeating RSA protection... Defeated! Sending applet... Applet ID: 060222 0202 CRUCXC1250166_1_SEMC_COMPACTPRODUCTION NAN Flash manufacturer: ST Microelectronics Flash ID: 0x200D OTP Security Level: 1 (Retail) OTP CID: 49 Analyzing configuration... Reading primary certificate... Primary certificate CID: 49 Primary certificate color: Red Secondary certificate not found. GDFS configuration not found. OSE configuration not found. TestProgram configuration not found. Done. The phone contains recovery certificate! You MUST repair EROM! Phone hardware initialized OK what show not found???? and im install last ver of fw restore 1.05 |
10-01-2006, 15:28 | #9 (permalink) | |
Member: 143648 Status: Offline Thanks Meter: 179 | Quote:
This may indicate damaged EROM area! Try repairing the phone via testpoint method. If it is an old phone, try converting it to brown first. | |
MR Zulea problem cid 49 otp after flashed erom cid 36 | gprsman | Others (USB-Smart) | 1 | 08-29-2006 11:53 |
K750i CID 49 problem | UnlockBR | Cruiser Suite | 3 | 07-19-2006 23:43 |
K750i cid 49 Dead flashing problem | irfanamin2 | SonyEricsson (USB-Smart) | 13 | 06-06-2006 20:22 |
K750i Cid 49 Problem | gedan | Cruiser Suite | 18 | 05-18-2006 00:44 |
safe unlock both K608 & K750i both cid 49 | zigma300 | Cruiser Suite | 17 | 05-10-2006 15:45 |
