05-30-2006, 23:51 | #1 (permalink) |
No Life Poster Join Date: Dec 2003 Location: Out of Africa
Member: 45476 Status: Offline Thanks Meter: 16 | K750i White blank display only Already customised FS and right after that Shutdown FS. Problem still remains Any ideas? |
The Following User Says Thank You to simpa For This Useful Post: |
05-31-2006, 01:00 | #3 (permalink) |
Member: 45476 Status: Offline Thanks Meter: 16 | I just done the follwing steps 1. Select exact phone type - K750i 2. Start the phone in recovery mode (via Force RSA recovery mode, CID=36). 3. Repair certificate and turn off the phone. 4. Reattach the phone in normal mode and convert to brown 36 5. Unlock RSA incase the Repair EROM disable 6. Repair EROM 7. Flash K750 full GDFS file and turn Off Phone - reattach the phone. 8. Flash main firmware. - R1AA008 9. Unlock RSA and reattach. 10. Flash raw FS. - R1AA008 and reattach it again. 11. Customize FS by one of the built-in customizations and Shutdown FS. 12. Reattach Again 13. In Tab "Security RSA" tick "Format Security zone" and "Recalculate CRCs" then "write to security zone" 14. Direct Unlock and Convert to Red 36 Nothing changed Lead, any idea ? |
05-31-2006, 10:26 | #5 (permalink) |
Member: 45476 Status: Offline Thanks Meter: 16 | Already done 4. Reattach the phone in normal mode and convert to brown 36 5. Unlock RSA incase the Repair EROM disable 6. Repair EROM Lead: should i format GDFS? Last edited by simpa; 05-31-2006 at 10:44. |
05-31-2006, 10:30 | #6 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Timeless zone! Age: 35
Member: 152244 Status: Offline Sonork: 100.1591179 Thanks Meter: 162 | Try all the flashes!!Becaz me tried sometimes different flashes it works for me!!So try it and let us know!! Br Muneeb Akhtar Raza |
05-31-2006, 12:45 | #12 (permalink) |
Member: 152244 Status: Offline Sonork: 100.1591179 Thanks Meter: 162 | Brother tell me is ur mobile is blinking on white screen or it stays on blank white screen???Or is it vibrate after power on??If yes then may b its hardware..So check hardware!! Br Muneeb Akhtar Raza |
05-31-2006, 12:49 | #13 (permalink) |
No Life Poster Join Date: Sep 2004 Location: in somewher in the earth Age: 43
Member: 82249 Status: Offline Sonork: 100.114416 Thanks Meter: 63 | try to repaire erom flash with correct flash file write gdfs recal crc |
The Following User Says Thank You to barhoomh For This Useful Post: |
05-31-2006, 15:59 | #14 (permalink) | |
No Life Poster Join Date: Aug 2004 Location: US/DK/S
Member: 76964 Status: Offline Thanks Meter: 2 | Quote:
Well R1BC002 and R1CA021_Latest are both WAY newer than the buggy R1N035, sorry to "bust your bubble"..... so, I would use R1CA021 first if I were you.... Please read http://forum.gsmhosting.com/vbb/showthread.php?t=219337 for clarification. | |
05-31-2006, 16:52 | #15 (permalink) | |
Member: 45476 Status: Offline Thanks Meter: 16 | Quote:
i flashed it many times, tried a lot of repair options (certificate recovery, erom repair), but still no changes now, i am sure it is 98% HW problem thanks for help guys | |
K750i White blank display only | simpa | SonyEricsson (USB-Smart) | 6 | 01-26-2009 09:43 |
K750i W700i W800i White Display Only SW Or HW | dil_PAKISTANI | SETool2 | 3 | 01-09-2009 08:27 |
3230 phone's working but only blank display | lrpa | Nokia Hardware & Hardware Repair | 6 | 10-10-2005 09:43 |
E710 only Blank Display | Hylko | Trident/AGERE Platform | 3 | 01-22-2005 12:38 |
