02-13-2008, 08:12 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: sri lanka/thailand/maldives Age: 44
Member: 283763 Status: Offline Thanks Meter: 102 | k800 unlocking problem pl help me i try to unlock k800 but comming msg what is the problem pl help me [ --- Direct Unlock --- ] ****yzing firmware... Preparing for direct unlock... Processing... Status: Success [O] Creating firmware backup file... Preparing to program flash... Programming flash... Time: 00:00:02 Flash process done. If the phone cannot be turned on anymore, report its type and firmware version. Starting up GDFS service... Failed! It is strongly recommended to upgrade EROM! Please remove battery from the phone... Could not initialize GDFS access. Obviously the firmware has not been restored yet! |
02-13-2008, 09:08 | #2 (permalink) |
No Life Poster Join Date: Mar 2008
Member: 25671 Status: Offline Thanks Meter: 719 | Do only what Cruiser said, "It is strongly recommended to upgrade EROM!". If you don't know how to do it, check Cruiser's manual. And about "Starting up GDFS service... Failed!", flash phone with ARM+FS (you don't need customize it), then check if you can power on phone. Only when you can power on phone, only then perform unlock procedure. |
02-15-2008, 10:05 | #4 (permalink) |
No Life Poster Join Date: Apr 2005 Location: between New Zealand - Canada Age: 42
Member: 135110 Status: Offline Thanks Meter: 302 | open the cruiser manual, read about upgrade EROM and DO IT.. very simple... btw: you can use UC-10 but also DCU-60 cable for upgrade EROM. for the unlock ONLY DCU-60 regards, Filip |
n95-8G unlock problem.pl help me | jimmymobile | Nokia Base Band 5 ( BB-5 ) | 5 | 02-03-2010 13:49 |
5300 unlock problem pl help me | ruvanw1979 | UID - Box | 4 | 01-17-2008 10:13 |
6300 unlocking problem pl help me | ruvanw1979 | UID - Box | 9 | 11-16-2007 15:54 |
pl help lg 275 lock problem pl help me | ruvanw1979 | Infinity-Box | 3 | 11-06-2007 13:12 |
u880 unlock problem pl help me | ruvanw1979 | FuriousGold | 5 | 08-28-2007 04:19 |
