Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > Cruiser Suite
Old 08-17-2007, 21:19   #1 (permalink)
Member: 237382
Exclamation K800i CID_52 "Insert correct sim card"
Hello,
I am a owner of the cruiser plus 2 and am having a problem. I got this K800i and needed to unlock it. When I connected it to the cruiser it said it was a CID_49 and recommended to upgrade. I unlocked the RSA, 1 log. I then modified it from CID_49 to CID_52, another log. I then flashed the phone's ARM and FS with the R1KG001 files. I then customised the FS, 1 log. I then tried to insert a sim and was told to "Insert correct sim card". Now when the phone is connected, its not giving the option to "Direct Unlock" nor read Codes and my setting are through the server connection. When I tried the "secret sequence" under the service info, the network was still locked. Could anyone tell me if they had the same problem and how could I get this repaired. This is costing me too many logs. Should I buy SE tools?
Old 08-17-2007, 21:24   #2 (permalink)
fonecellar's Avatar
Member: 545165
Originally Posted by Boloraw View Post
Hello,
you should not have upgraded to cid 52, only to cid 51
52 cannot be unlocked with cruiser
Old 08-17-2007, 21:30   #3 (permalink)
bogdanrex0's Avatar
Member: 289243
when you upgraded cid to 52 forget about unlock i hope i'm wrong but afraid you made mistake doing this ( modified to 52)
Old 08-17-2007, 21:34   #4 (permalink)
snsoftkiller's Avatar
Member: 250468
Sonork: 100.110362
Hello,
You are dealing with SEMC and you dont know that our headache for us is CID 52 unlock ? From what planet are you from ?
Now only davinci or ubbox is your solution and believe me its cost not 3 pennys.
Old 08-18-2007, 09:13   #5 (permalink)
Member: 480351
where is to buy davinci ?
Old 08-18-2007, 09:17   #6 (permalink)
Member: 31632
wrong section boss.just search.
Old 08-18-2007, 12:06   #7 (permalink)
Lhick's Avatar
Member: 333359
Try here... http://www1.davinciteam.com/phoneinfo
Old 08-19-2007, 08:57   #8 (permalink)
davesmobiles's Avatar
Member: 92178
Hello,
If you would have unlocked rsa, flash main, flash raw, direct unlock, customise fs, you would have only used ONE LOG. Then wait until cid52 is more supported before going up. Now your stuck until 52 is more supported unless you use different box.
Read the manual m8 its explained in there about updating to CID52, and also how to unlock & flash 49/51 all for 1 Log.
davesmobiles
Old 08-19-2007, 14:05   #9 (permalink)
service_sad's Avatar
Member: 65862
@Boloraw
if u are from London contact me
regards
Old 08-19-2007, 19:06   #10 (permalink)
SekingServer's Avatar
Member: 565161
Sonork: 100.1585588
Hello,
Seking flash is FREE
Old 08-19-2007, 19:07   #11 (permalink)
Member: 565161
Sonork: 100.1585588
http://forum.gsmhosting.com/vbb/showthread.php?t=433251 http://forum.gsmhosting.com/vbb/show...0&postcount=50
cool software
Old 08-19-2007, 19:15   #12 (permalink)
::gsmcoder::'s Avatar
Member: 172434
Sonork: 100.161280
seeking server i really hope it remain s.
Old 08-19-2007, 23:00   #13 (permalink)
Member: 237382
Thanks all of you for the help, I really appreciate it. Gonna try another solution. Probably DaVinci.
Old 08-20-2007, 12:17   #14 (permalink)
shinta2004's Avatar
Member: 76266
you just need to unlock the rsa then flash your phone after phone flashing before you customise your phone do unlock and then customise your phone it will be ok 100% with this method you lost just one log
Old 08-20-2007, 13:45   #15 (permalink)
fonecellar's Avatar
Member: 545165
[quote=shinta2004;2653687]you just need to unlock the rsa then flash your phone after phone flashing before you customise your phone do unlock and then customise your phone it will be ok 100% with this method you lost just one log[/quo
@ shinta 2004 why dont you read the post proper, the phone is CID52 silly person
W700i flash done, error "Insert correct SIM card" ??? phamhoangvnn SETool2 3 02-06-2010 05:40
HELP WITH k310i DISPLAYING "insert correct sim card" alihersi1 Sony Ericsson 0 10-18-2007 21:03
"insert correct sim card" on T630 and K700i MC Harami Cruiser Suite 3 09-13-2006 14:32
T610 "insert correct sim card" MC Harami Cruiser Suite 9 04-06-2004 21:59
"Insert right sim card" A1018s with card in ... gladeo Old Ericsson Phones & Sony Phones 4 01-23-2002 03:16
Page generated in 0.43629 seconds with 11 queries
