05-15-2006, 10:33 | #1 (permalink) |
Cheater -Don't Deal with him- Join Date: Jan 2005 Location: U S A / GOA /CHINA Age: 44
Member: 106367 Status: Offline Sonork: 100.1577436 Thanks Meter: 2,452 | Lead J210i _repair_v2.arm.flp PHONE WAS WORKING BEFORE FLASH BUT ONLY WHITE LCD |
05-15-2006, 10:57 | #2 (permalink) |
Freak Poster Join Date: Mar 2006
Member: 248353 Status: Offline Thanks Meter: 3 | flash r2h file than clear nvram clear locks or direct unlock phone automaticly detached attach manually phone type select j200 (do not select j210 it's important!!!!) than do CRC . phone is detached and alive again |
05-15-2006, 12:34 | #3 (permalink) | |
Member: 106367 Status: Offline Sonork: 100.1577436 Thanks Meter: 2,452 | still dead Quote:
after doing following things still dead could someone pls help here to solve thnks | |
05-15-2006, 12:51 | #5 (permalink) |
No Life Poster Join Date: Feb 2006 Location: EDSELLULAR
Member: 236564 Status: Offline Sonork: 100.1667122 Thanks Meter: 816 | 1. Flash phone with cuiser, make clear nvRAM recalc DRCRC's etc 2. Make init security block on UFS_ATRZ select as model j210 (on latest atrz it's implemented, and WITHOUT HWK USE j200 will do the job tested by me) then soft will tel you what to do. Most important thing, after all ok, your phone will be charging, switch it on and off normaly. Phone alive. |
05-15-2006, 13:17 | #6 (permalink) | |
Member: 106367 Status: Offline Sonork: 100.1577436 Thanks Meter: 2,452 | thnks bro Quote:
is there ne idea thnsk | |
05-15-2006, 13:36 | #7 (permalink) | |
Insane Poster Join Date: Jun 2004 Location: Romania
Member: 67493 Status: Offline Thanks Meter: 5 | Quote:
05-15-2006, 13:46 | #9 (permalink) |
Member: 106367 Status: Offline Sonork: 100.1577436 Thanks Meter: 2,452 | bro i have cruiser and this is cruiser section if possible post cruiser soluiotn thnks pls dont mind |
05-15-2006, 13:50 | #10 (permalink) | |
05-15-2006, 13:52 | #11 (permalink) | |
Member: 106367 Status: Offline Sonork: 100.1577436 Thanks Meter: 2,452 | steps Quote:
2.ON J210I WRITTING THE REPAIR FILE 3.clear nvram 4.reattach select dcrcs all done succes but phone still dead | |
05-15-2006, 14:21 | #12 (permalink) |
Member: 248353 Status: Offline Thanks Meter: 3 | no do exactly like these: attach j210i flash with r2h file not repair_v2 file (go to cruiser support arm 2003 j210 folder\r2h folder\J210i_CXC1250107_EMEA5_R2H.ARM.rarfor exemple. after flash attach j210i and "clear nvram " then do clear locks or direct unlock anyway then now it's important attach with phone J200i do dcrc loock to your phone it seems to be alive important !!! do not remove battery before shut it normally off by its button goodluck |
05-15-2006, 15:06 | #13 (permalink) | |
as ur info everything was ok but still dead Version 9.64 ready! Connecting via Fighter USB Cable... Powering on the phone... Baseband chip ID: 0x9002 Protocol version: 3.0 Baudrate = 115200Bd Time spent entering bootstrap: 0s Initializing phone hardware... Baudrate = 115200Bd Phone hardware initialized OK Flash file: "J210i_CXC1250107_EMEA5_R2H.ARM.flp" Waiting for flash file to load... Sending flash applet... Baudrate = 115200Bd Sending ARM block... Finalizing block... Time: 00:12:54 Sending ARM block... Finalizing block... Time: 00:02:05 Sending ARM block... Finalizing block... Time: 00:00:31 Sending ARM block... Finalizing block... Time: 00:00:04 Flash process done. Phone automatically detached. Connecting via Fighter USB Cable... Powering on the phone... Baseband chip ID: 0x9002 Protocol version: 3.0 Baudrate = 115200Bd Time spent entering bootstrap: 0s Initializing phone hardware... Baudrate = 115200Bd Phone hardware initialized OK Clearing NVRAM area... Waiting for flash file to load... Sending flash applet... Baudrate = 115200Bd Sending ARM block... Finalizing block... Time: 00:00:31 Flash process done. Phone automatically detached. Connecting via Fighter USB Cable... Powering on the phone... Baseband chip ID: 0x9002 Protocol version: 3.0 Baudrate = 115200Bd Time spent entering bootstrap: 0s Initializing phone hardware... Baudrate = 115200Bd Phone hardware initialized OK Uploading direct access applet... Setting all keys to 00000000... Use the sequence <**< to enter unlocking codes. Done. Phone automatically detached. Connecting via Fighter USB Cable... Powering on the phone... Baseband chip ID: 0x9002 Protocol version: 3.0 Baudrate = 115200Bd Time spent entering bootstrap: 0s Initializing phone hardware... Baudrate = 115200Bd Phone hardware initialized OK Uploading direct access applet... Recalculating CRCs... Done. Phone automatically detached. | |
05-15-2006, 15:36 | #15 (permalink) | |
Member: 106367 Status: Offline Sonork: 100.1577436 Thanks Meter: 2,452 | yes Quote:
selected j200i manually thnks for ur time still waiting to solve this | |
i need ARM flsh file for J210i | kamot37 | Sony Ericsson | 0 | 07-27-2008 06:37 |
J210i russian langpack needed.arm | ccont | Sony Ericsson | 0 | 09-16-2007 17:26 |
Bluetooth issues with T610_TAE_Standard_CXC125562_R7A011.ARM.flp | odinb | Cruiser Suite | 2 | 02-01-2006 23:19 |
please lead help j210i | 2xxu | Cruiser Suite | 0 | 12-04-2005 10:01 |
Z200 arm flash .flp needed | Raklm | Cruiser Suite | 6 | 10-04-2004 07:39 |
