Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > Cruiser Suite
Old 06-09-2005, 11:14   #1 (permalink)
.::Zafar Communication::.'s Avatar
Member: 71045
lg 8180 R Orang colour problem
hi
i tryied to unlock the above subjected mobile with vygis but dead now i upgrade the the crusier when i connect the mobile following message appear
Flash manufacturer: Intel
Flash ID: 8900
All threads terminated.
Connecting via Fighter USB Cable...
Powering on the phone...
Baseband chip ID: 0x7100
Protocol version: 3.1
Baudrate = 460800Bd
Trying CID29 recovery applet...
Sending applet prologue...
Trying CID16 recovery applet...
Trying CID17 recovery applet...
Time spent entering bootstrap: 4s
Initializing phone hardware...
Flash ID: 8900
window below give the following message
Error: Unknown flash ID detected - 0x8900
Script error: Unspecified [4.02.82]
please comments what is wrong and what mistake i am doing please
waiting for immidiate response
Thanks and regards
Zafar Janjua
Old 06-09-2005, 11:31   #2 (permalink)
GSM SHADOW's Avatar
Member: 57430
first u have to use furious2 because it use com for flashing
second u have to be sure of the Tp that is right
and all will be ok i think
B.R
GSM SHADOW
Old 06-09-2005, 12:08   #3 (permalink)
Member: 22586
Let Cruiser Attach to the phone without TP connected.
If you have soldered the wire from TP to ground, cruiser can't boot the phone.
Mike
Old 06-09-2005, 12:32   #4 (permalink)
Member: 71045
Mike
sir i did not sold fix when ask for i connect proecedure is followed but the problem did not connect with and without same message is given which i start the thread
thanks & regards
Zafar Janjua
Old 06-09-2005, 14:46   #5 (permalink)
Lead's Avatar
Member: 1841
Seems like burned data bus.
Which testpoint have you used for Vygis?
Old 06-09-2005, 15:28   #6 (permalink)
Member: 71045
sir see the picture in attachment first i use the test point which vygis give with 150 ohm resistance but later i receive the crusier after upgradation my se- fighter but could no seem any thing positive now with crusier i am using cruiser testpoint same result
thanks regards
Zafar Janjua
Old 06-13-2005, 16:15   #7 (permalink)
mali_kruno's Avatar
Member: 6247
is there any way to solve this or it can be done only by flash ic change
Old 06-13-2005, 16:32   #8 (permalink)
Chawkiz_gsm's Avatar
Member: 3768
1 more 8180 dead i think this phone not supported to use with it the test point
Old 06-13-2005, 17:00   #9 (permalink)
mali_kruno's Avatar
Member: 6247
and now this phone act as it have test points conected, maybe it is in some boot mode and that why it cant be powered up???
Old 06-13-2005, 17:08   #10 (permalink)
Member: 3768
with furious i select 8120 this is the result
Press Power On shortly !
Phone Detected !
Chip ID: 71000301
Loading ...
Loader version:
40318 1450 LLECXC1325413_CERTLOADER R3J
Flash ID: 8900
Settings Done !
Certificate sent ...
HACK3R2K.COM GSM DEVELOPEMENT
Settings made ...
CID: 17
IMEI: 35554932004903-1
CSW BLOCKS: 00A8
drive_c.csw ... ERROR
CSW BLOCKS: 00D1
U8130_main.csw ... ERROR
Old 06-14-2005, 14:09   #11 (permalink)
scutarus's Avatar
Member: 80036
some news here?
Old 06-14-2005, 14:21   #12 (permalink)
Member: 71045
i check on see tool
GUI v0.8977008/UFS
standalone version engaged.
Registered version.
Loaded 25 flash descriptors
Opening box.
There is 1 ftdi devices
device opened.
boot ack received.
license checked,
ufs #xxxx ready to work
Elapsed:1 secs.
Powering...
ChipID is 71000301
CID not detected.
Cowardly refusing to load empty loader.
failed to load CERTLOADERS,try to use RECOVERY.
Elapsed:2 secs.
Old 06-14-2005, 14:22   #13 (permalink)
evan_silbert's Avatar
Member: 21920
UFS SETool can't work with new-CID phones...
Old 06-14-2005, 21:42   #14 (permalink)
Member: 24435
8180 to 8138 clone procedure works 100% with cruiser...with testpoints...disassemble the phone solder 2 wires than assemble the phone...and give short gnd conection external very safe untill now...but very hard plastic cover not to be scratched...not very nice for customer...and also some 8180 flash gifts like mp4 format support are gone forever...hope soon will come patched flashes from 8180 that accept 2 g cards and notestpoints solution....NOTE: Cable that was used for flashing was usb/serial used with factory lg flasher before...and go to setting and set port one for this cable,
NTZ112334 Programing Interface...
lg 8180 reset problem sesime VygisToolbox 0 06-06-2009 15:38
Lg 8180 problem QguAr LG 6 02-28-2006 05:58
Hwk Cracked And Lg 8180 Unlock Problem Sparagna Twisterflasher 12 10-25-2005 11:43
Need help 8180 (R) orange Ron2pet Cruiser Suite 4 06-13-2005 04:01
lg 8180 R Orang colour .::Zafar Communication::. VygisToolbox 10 06-08-2005 22:04
Page generated in 0.70045 seconds with 12 queries
