12-14-2005, 19:24 | #1 (permalink) |
Freak Poster Join Date: Mar 2003 Age: 46
Member: 25392 Status: Offline Thanks Meter: 10 | LG u 8550 unlock problem i readed codes ..and after this phones is in a kind of blink it starts ..shows 3g than turn off anybody have any ideea |
12-14-2005, 22:42 | #3 (permalink) |
No Life Poster Join Date: Feb 2003 Location: albania Age: 52
Member: 22586 Status: Offline Thanks Meter: 36 | I think that 1. Your battery is low or 2. You didn't assemble the phone properly. Low possibility for software damages. Also Rebuild security is not supported for this model, as far as i can remember. BR Mike |
12-15-2005, 09:27 | #4 (permalink) | |
No Life Poster Join Date: Aug 2004 Age: 47
Member: 76522 Status: Offline Thanks Meter: 30 | Quote:
12-15-2005, 10:55 | #5 (permalink) |
Member: 22586 Status: Offline Thanks Meter: 36 | Did you try to "Relock" the phone ? (You will need TP for that) The relock procedure recalculates CRCs and repairs partially the phone GDFS. Try this option and report results. BR Mike |
12-15-2005, 11:09 | #6 (permalink) |
Member: 25392 Status: Offline Thanks Meter: 10 | i solved the problem by reflashig the phone ... with U8550_V10a_Italy_Red54.flp but phone is still locked ... with U8550_v09b_Italy_Brown17.flp phone is still in blink direct unlock has no effect and 2945#*... has no efect ..becouse phone is in insert sim ....not "sim locked" nenmobil |
12-15-2005, 14:40 | #7 (permalink) |
Member: 25392 Status: Offline Thanks Meter: 10 | after flash with U8550_v09b_Italy_Brown17.flp phone is in blink i try to reflash with : U8550_V10a_Italy_Red54.flp i always have this error Analyzing configuration... Reading primary certificate... Primary certificate CID: 54 Primary certificate color: Red Secondary certificate not found. OSE configuration found. Analysing GDFS... Done. Flash file: "U8550_V10a_Italy_Red54.flp" Waiting for flash file to load... Reading phone RSA certificate... Preparing to program flash... Baudrate = 921600Bd Analysing flash file... Replacing primary certificate... Signing... Programming flash... Time: 00:04:47 Preparing to program flash... Analysing flash file... Programming flash... Applet error: ERROR|UnlockBlock| 04 00 00 00 22 FF FF 00 22 Script error: EAccessViolation |
01-07-2006, 14:50 | #8 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Timeless zone! Age: 35
Member: 152244 Status: Offline Sonork: 100.1591179 Thanks Meter: 162 | Those who have not the mobile in their hands they only posting here an there without any good knowladge....Becaz as i think the cid 17 is unlockable for this phone not the cid 54 ......yet......I also have cid 54 still locked......Flashed etc done everything no result.....So its only for show that is unlocking is avialable ....SO unlocking came sonn but not at the momment.....No deviece can unlock it....Still as i seen..... Br Muneeb Akhtar Raza |
01-07-2006, 19:57 | #10 (permalink) | |
No Life Poster Join Date: Nov 2004
Member: 91799 Status: Offline Thanks Meter: 3 | Quote:
It does not unlock 8550 cid 54. Why you people do not stop talking nonsense? | |
01-08-2006, 13:00 | #12 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Holland China Brazil Age: 43
Member: 88016 Status: Offline Thanks Meter: 320 | Mr muneeb_akhter. here is a lot of peoples are more genius than you man,now u are a little kid in Gsm and you are talking like a master, this is not fair. All peoples can reads your posts by the search button,your mostly posts wrong,i can prove it,next time be carefull to insalt any forum member. BR Kashif Khan |
01-08-2006, 13:49 | #13 (permalink) | |
It will be when and IF it will be. In the meantime it is just nonsense. It is like binary logic. It is either true or false. Now it is false, so please stop making false statements. | |
LG KG 110 unlocking problem | shritelmob | Infinity-Box | 2 | 05-12-2007 15:13 |
Lg U 8550 unlock solution | Unlocker AL | LG | 48 | 12-27-2005 16:39 |
lg 8330 direct unlock problem | Kanwalgee | LG | 0 | 07-19-2005 10:31 |
lg 8330 direct unlock problem | Kanwalgee | FuriouS II | 2 | 07-17-2005 18:18 |
lg u8110 v108 unlock problem???? | Siemens man | LG | 1 | 03-30-2005 18:32 |
