02-03-2010, 19:58 | #1 (permalink) |
Junior Member Join Date: Jun 2006
Member: 296219 Status: Offline Thanks Meter: 2 | lost credit loss but failed to reconstuction gdfs k320(cid detect 51) regards, log: first try Code: 02:23:09 SE Ultimate Unlocker v3.07 by Cruiser Team 02:23:09 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 02:23:09 Initializing... ! 02:23:10 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 02:23:10 2. Choose the phone model ! 02:23:10 3. Select the desired options ! 02:23:10 4. Please connect the phone either via USB while holding 2-5… ! 02:23:10 - or via a serial cable and double-click on it in the device list 02:24:01 Selected phone: K320 02:24:01 Connecting via Generic FTDI Cable (COM4)… 02:24:01 Device driver version: 2.2.4.0 02:24:01 Device driver date: 6-27-2007 02:24:02 Connecting to the baseband CPU... 02:24:02 Entering baseband CPU service mode... 02:24:02 Detected chipset: DB2012 02:24:02 Boot mode: ROM 02:24:02 Sending loader... 02:24:03 IMEI: 35257002377897 02:24:03 OTP CID: 50 02:24:03 Restarting phone … 02:24:05 Sending loader... 02:24:06 Communicating with server… ! 02:24:16 News: Your consumption level is: Level 1 (Novice) 02:24:17 Remainig credit (supreme): 1.00 02:24:27 Remainig credit (supreme): 0.67 02:24:28 Restarting phone … 02:24:31 Sending loader... 02:24:43 Initializing GDFS access... 02:24:43 Writing GDFS… E 02:25:43 Error: 0x07F5EFDA E 02:25:43 Error: 0x3173E984 E 02:25:43 Error: 0x4B055A8F E 02:25:43 Error: 0xE9FB48DF E 02:25:43 Error: 0xCC9B40DA E 02:25:43 Error: 0x8F6C03FD E 02:25:43 Error: 0x980B6A88 E 02:25:43 Error: 0x8118A648 E 02:25:43 Error: 0x59AF7680 E 02:25:43 Failed! ! 02:25:43 To report errors right-click this window Code: 03:36:33 SE Ultimate Unlocker v3.07 by Cruiser Team 03:36:33 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 03:36:33 Initializing... ! 03:36:33 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 03:36:33 2. Choose the phone model ! 03:36:33 3. Select the desired options ! 03:36:33 4. Please connect the phone either via USB while holding 2-5… ! 03:36:33 - or via a serial cable and double-click on it in the device list 03:37:05 Selected phone: K320 03:37:05 Connecting via Generic FTDI Cable (COM4)… 03:37:05 Device driver version: 2.2.4.0 03:37:05 Device driver date: 6-27-2007 03:37:06 Connecting to the baseband CPU... 03:37:06 Entering baseband CPU service mode... 03:37:06 Detected chipset: DB2012 03:37:06 Boot mode: ROM 03:37:06 Sending loader... 03:37:07 IMEI: 35257002377897 03:37:07 OTP CID: 50 03:37:07 Effective CID: 51 03:37:07 Restarting phone … 03:37:10 Sending loader... 03:37:22 Initializing GDFS access... 03:37:22 Writing GDFS… E 03:38:22 Error: 0x3173E984 E 03:38:22 Error: 0x4B055A8F E 03:38:22 Error: 0xE9FB48DF E 03:38:22 Error: 0xCC9B40DA E 03:38:22 Error: 0x8F6C03FD E 03:38:22 Error: 0x980B6A88 E 03:38:22 Error: 0x8118A648 E 03:38:22 Error: 0x59AF7680 E 03:38:22 Failed! ! 03:38:22 To report errors right-click this window |
02-18-2010, 23:33 | #4 (permalink) |
Member: 296219 Status: Offline Thanks Meter: 2 | That day i try couple time & have no solution..can't flash either..i tried to flash with MT-SE & Setool also...for k320 can do recovery but can write erom & gdfs in to it..but after a few days i can write gdfs in to that phone...problem solved (If the battery is fully charged, it seems to be a problem of the flash chip somewhere in the GDFS area ) @ glados thanx for this tip,i'll try for next case but i lost 2 credit :-(... |
P990 Credit used but fails to repair | meisam | D-Unlock Suite | 8 | 04-29-2010 10:10 |
w850 test point sucses but failed to write gdfs | naurah | DreamBox | 8 | 02-11-2010 17:53 |
lost credits n78 unlock fail 08 | unlock_kda | Universalbox | 11 | 04-17-2009 20:43 |
lost credits dont no waht to do | tahataha | Universalbox | 2 | 03-28-2009 11:51 |
unlock n96 credit loss but donn't work | mwmobile2 | Universalbox | 16 | 03-13-2009 22:56 |
