09-10-2006, 05:56 | #1 (permalink) |
Banned Join Date: May 2004 Location: Mauritius
Member: 64823 Status: Offline Thanks Meter: 438 | ..::Mobile Start CHARGING.When connect Cable::.. As i connect my cable the mobile start charging even using T68 cable and k750 cable.. the option CHARGER on is off.... so why this REACTION... more when i click on attached phone... it just stuck it here... FOR MANUEL IGNITION System diagnostics passed. Version 9.74 ready! [ --- Attach to Phone --- ] Connecting via Fighter USB Cable... Power on the phone, please! FOR AUTO IGNITION System diagnostics passed. Version 9.74 ready! [ --- Attach to Phone --- ] Connecting via Fighter USB Cable... Powering on the phone... Thats all and i just here a BIZZ sound from the cuiser... i remove battery and place again still the same drama it stuck right there!! The SMALL light indicating that the is communcation btwn the phone and the FIGHTER CABLE stuck on red no blinking.... My CRUISER IS NEW and has NEVER BEEN USED... U realise that more than one month not a SINGLE mobile i have been able to unlock.... the SAME problem... Please am desperate!! I need to unlock a SE j220i right now when i connect it start CHARGING... Why MAN ??? Why charging?? I did have DIV and when it was charging i just need to remove battery and press the ON key and the wok is done but here its completely different.... Give me a right SOLUTION the CRUISER MAN!! |
09-10-2006, 07:14 | #3 (permalink) |
Product Supporter Join Date: Sep 2004 Age: 39
Member: 81703 Status: Offline Thanks Meter: 1,332 | As Aussi said it's nearly 100% a pinout problem because I must assume that you have the phone disconnected just till you open the soft. Try but it's not going to work to press the function in Cruiser soft of Read Phone and then connect the phone. BR Luskao |
09-10-2006, 07:43 | #4 (permalink) | |
Member: 64823 Status: Offline Thanks Meter: 438 | Na didnt !! I dont have any other cable!! Quote:
Any other suggesion??? | |
09-11-2006, 04:51 | #5 (permalink) |
Member: 64823 Status: Offline Thanks Meter: 438 | After changing to this driver , the light that indicate communication between the mobile and cruiser started to blink... but unfortunately i still got some errors!! Version 2176 for Win2K and WinXP (test).rar So dont you think it might be a problem of driver and conflicting problem????? |
09-11-2006, 04:53 | #6 (permalink) | |
No Life Poster Join Date: Oct 2003 Location: Auckland, New Zealand
Member: 42570 Status: Offline Thanks Meter: 11 | Quote:
1) A faulty cable 2) A faulty connector on the bottom of the phone. I've seen a few people with driver problems, so it might help to totally remove all drivers and reinstall. But also if you can test with another phone and another cable. | |
09-11-2006, 05:45 | #7 (permalink) |
No Life Poster Join Date: Aug 2004 Location: US/DK/S
Member: 76964 Status: Offline Thanks Meter: 2 | 1. Clean connector at bottom of phone, dirty connector on the phone is the most common reason for this proble. 2. If it does not help, try inserting battery when cruiser says "powering on phone". |
09-11-2006, 05:58 | #8 (permalink) | |
Member: 64823 Status: Offline Thanks Meter: 438 | Quote:
Already DONE that!! 10000 times... still same problem!! did try not only with a set with 10 set same problem!! Thx for the HELP!! | |
09-11-2006, 06:00 | #9 (permalink) | |
Now am having this problem : System diagnostics passed. Version 9.74 ready! [ --- Attach to Phone --- ] Connecting via Fighter USB Cable... Powering on the phone... Powering on the phone... Powering on the phone... Powering on the phone... Powering on the phone... Powering on the phone... Powering on the phone... Powering on the phone... Powering on the phone... Powering on the phone... Powering on the phone... Powering on the phone... Powering on the phone... Powering on the phone... Powering on the phone... Powering on the phone... ---------------------------------------------------------------- Script error: Unspecified [9.74.29] Script error: Unspecified [9.74.29] Script error: Unspecified [9.74.29] Script error: Unspecified [9.74.29] Script error: Unspecified [9.74.29] Script error: Unspecified [9.74.29] Script error: Unspecified [9.74.29] Script error: Unspecified [9.74.29] Script error: Unspecified [9.74.29] Script error: Unspecified [9.74.29] Script error: Unspecified [9.74.29] Script error: Unspecified [9.74.29] Script error: Unspecified [9.74.29] Script error: Unspecified [9.74.29] Script error: Unspecified [9.74.29] | |
09-11-2006, 06:03 | #11 (permalink) |
No Life Poster Join Date: Jan 2006 Location: inside emmc ufs Age: 19
Member: 221603 Status: Offline Sonork: 100.1581270 Thanks Meter: 6,395 | you can also do like this....... connect the battery.... press attach to phone.. now put the cable...... some times it also help...... |
09-11-2006, 12:54 | #12 (permalink) |
No Life Poster Join Date: Mar 2004 Location: Nederlands / Germany / Danmark Age: 51
Member: 60001 Status: Offline Sonork: 100.106474 Thanks Meter: 151 | Do you use extern 3 Volt???? ok, sorry for J220 you need old cable, not fastport Ì didn?t read completely |
10-16-2006, 01:59 | #13 (permalink) |
Freak Poster Join Date: Jan 2004 Location: Bulgaria,France Age: 53
Member: 48820 Status: Offline Thanks Meter: 3 | it is so easy!Lot of peoples are in treobles with conections of j220.Conect your phone in normal way.Dont mather who is the first-battery or the cable.The phone wil begin to charge itself-dont take care about-push "attach to phone".The cruiser cannot conect at this time and this is normal.You just swich the phone on and after off-without disconecting fisicaly the cable! |
10-16-2006, 02:13 | #15 (permalink) |
Member: 48820 Status: Offline Thanks Meter: 3 | me too i was loosing couple nights cleaning connectors,reflowing IC-s,changing charging IC,remuving protection parts,testing with another comp and cables,another version of cruiser soft....no luck.And i discover that is more easy just to push one button two times |
Why Mobile Start CHARGING?When connect Cable?? | zakiyyboss | Cruiser Suite | 4 | 09-06-2006 05:41 |
newbie:when connect phone to unlock, phone start charging auto. | ashvin | Cruiser Suite | 4 | 08-08-2005 20:58 |
Nokia 3610 show not charging when connect with charger | TechPhone | Nokia Hardware & Hardware Repair | 2 | 01-27-2004 20:29 |
Ericsson T20 Doesn't Start Charge When Battery Is Empty | ARC | Sony Ericsson Hardware Repair | 6 | 04-03-2002 04:00 |
when connected to charger siemens c35 shows it's charging, but in fact not charging.. | sat | Siemens Hardware Repair Area | 0 | 09-03-2001 18:06 |
