02-20-2006, 18:32 | #1 (permalink) |
Freak Poster Join Date: Feb 2003 Age: 42
Member: 22109 Status: Offline Thanks Meter: 0 | Which models are 100% supported without the use of TP ? I was wandering if someone could which models can be unlocked and flashed without the use of TP. I understand that not all hardware-versions of all CID 49 models are supported. K600/K608: Not all of these are supported without using TP. Is there anyway to tell just by checking the software on the phone wheither TP is need or not? There are 3 or 4 different TP's for K608. How do you know which one to use ? W550: Are all versions of W550i supported without the use of TP ? W600: Are all versions of W600i supported without the use of TP ? V600: Are all versions of V600 supported without the use of TP ? W900: All versions needs TP - right ? I'm looking foreward to your answers Thanks in advance. And finally I want to thank Lead for his hard work. Keep it up m8! Best regards Martin |
02-20-2006, 19:10 | #2 (permalink) |
No Life Poster Join Date: Aug 2008 Age: 52
Member: 1841 Status: Offline Thanks Meter: 469 | Old hardware versions of K600/K608/V600/W550/W600/W900 are supported without TP. Old HW version of W900 is supported via special trick, I've seen only one such phone in my life, therefore there is no need to explain this in detail. New hardware versions of K600/K608/V600/W550/W600/W900 are supported via TP only. The phone firmware has no effect on this. |
02-20-2006, 20:30 | #4 (permalink) | |
Member: 1841 Status: Offline Thanks Meter: 469 | Quote:
If it fails, it is new hardware. The phone won't be killed. | |
02-21-2006, 18:51 | #8 (permalink) | |
Fail Unlock nokia 6131 without the use of tp | ultracell2 | AdvanceUFS | 0 | 12-03-2008 20:13 |
unlock nokia N80 RM-92 without the use of tp | ultracell2 | AdvanceUFS | 0 | 12-02-2008 22:43 |
ub team pls give the list of tp supported model. | SHANU | Universalbox | 2 | 07-18-2008 22:21 |
Has anyone decode E71 without the need of TP ? | foosoomin | S-Gold Based Phones | 1 | 01-13-2007 13:48 |
Received 3 samsung cables! Which models are supported? | m_dige | UFS2 + UFS3-Tornadoflasher | 5 | 02-21-2004 10:14 |
