03-04-2006, 06:19 | #1 (permalink) |
Junior Member Join Date: Oct 2005 Age: 43
Member: 186294 Status: Offline Thanks Meter: 0 | P900i Convert P910i Could I flash P910i APAC2 all flash files into P900i by cruiser pro 2? After convert P900i to P910i that P900i can support 512MB or 1GB MS Card? Best Regards, |
03-04-2006, 06:40 | #2 (permalink) |
No Life Poster Join Date: Oct 2003 Location: Auckland, New Zealand
Member: 42570 Status: Offline Thanks Meter: 11 | Yes, Cruiser can do this, but you have to flash the correct files. Just flashing P910 files to the phone will damage it, requiring TP to fix. Once converted to a P910 you can use larger MS Cards without problem. Read this thread. The link to the files probably isn't right anymore, the directory you want is now here. That dir contains the special P910 files, magically hacked to work with a P900. Again, remember DO NOT flash normal P910 files to the P900. You'll be sad. Also once converted, BT headsets do not work correctly. |
help p900i convert to P910 | dauyeuqn | Cruiser Suite | 2 | 08-29-2008 17:01 |
P900i to p910 now file manager won't work<<flashed p910i gdfs>> | Logitext | Cruiser Suite | 1 | 11-29-2007 10:08 |
Any way of converting p910i to p900 | aj4u | SonyEricsson (USB-Smart) | 1 | 07-19-2006 14:59 |
Converting a P900 to P910i | mash7669 | Twisterflasher | 0 | 12-26-2005 10:26 |
P900i/P910i Orignal LCD for Sale | ansartec | Main Sales Section | 0 | 08-04-2005 12:38 |
