11-23-2005, 11:10 | #1 (permalink) |
No Life Poster Join Date: Nov 2004
Member: 91102 Status: Offline Thanks Meter: 34 | my first 8330 unlocked with cruiser and is dead i have unlocked my first 8330 with cruiser 7.10 by patching but it doesn't power on now now i don't know what do i do next now any help please? here is the log Version 7.10 beta ready! Connecting via UC-10 Universal Cable... Powering on the phone... Baseband chip ID: 0x7100 Protocol version: 3.1 Baudrate = 460800Bd LG 3G phone detected. Phone CID: 42 Phone color: Red Flash certificate: A1_LGE_DB2000_RED Trying Red CID42 flash applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 1s Initializing phone hardware... Flash manufacturer: Intel Flash ID: 0x890D OTP Security Level: 1 (Retail) OTP CID: 42 Phone hardware initialized OK Analyzing configuration... Reading primary certificate... Primary certificate CID: 42 Primary certificate color: Red Secondary certificate not found. OSE configuration found. Analysing GDFS... Done. Turning off phone... Phone turned off. Phone automatically detached. Connecting via UC-10 Universal Cable... Powering on the phone... Baseband chip ID: 0x7100 Protocol version: 3.1 Baudrate = 460800Bd LG 3G phone detected. Phone CID: 42 Phone color: Red Flash certificate: A1_LGE_DB2000_RED Trying Red CID42 flash applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 1s Initializing phone hardware... Flash manufacturer: Intel Flash ID: 0x890D OTP Security Level: 1 (Retail) OTP CID: 42 Phone hardware initialized OK Analyzing configuration... Reading primary certificate... Primary certificate CID: 42 Primary certificate color: Red Secondary certificate not found. OSE configuration found. Analysing GDFS... Done. Defeating RSA protection... Waiting for the phone to turn off... Should the communication hang, reinsert battery. Baudrate = 460800Bd Sending applet prologue... Sending applet body... Sending applet... Defeated! Analyzing firmware... Reading firmware block 1... Reading firmware block 2... Reading firmware block 3... Reading firmware block 4... Creating firmware backup file... SIMLock checking code 1: Found, original. 3G SIM checking code: Found, original. SIMLock checking code 2: Found, original. Firmware anti-tampering code: Not found. Sending applet... Preparing to program flash... Baudrate = 921600Bd Programming flash... Time: 00:00:07 Flash process done. Done. Turning off phone... Phone turned off. Phone automatically detached. br |
11-23-2005, 11:30 | #3 (permalink) | |
Member: 91102 Status: Offline Thanks Meter: 34 | Quote:
it is not the battery also checked the battery before unloc was fully charged br | |
11-24-2005, 19:18 | #9 (permalink) |
Member: 91102 Status: Offline Thanks Meter: 34 | one thing is for sure this unlock by patching is not working for 8330 cid42 tryed another one today but exactly the same (the phone doesn't power on) tryed on different versions like 6.05, 6.10, 7.00, 7.10 but all the same br |
11-24-2005, 19:34 | #11 (permalink) | |
BR | |
11-24-2005, 19:40 | #12 (permalink) |
No Life Poster Join Date: Feb 2003 Location: albania Age: 52
Member: 22586 Status: Offline Thanks Meter: 36 | It must be a bug Hope that Lead checks it as soon as possible. In order to unlock the phone by Cruiser, try the following: 1. Flash the phone with the file U8330_V20a_Austria_Red42.flp 2. After flashing switch the phone ON and reset it. 3. Re-attach phone and unlock it by patching. If you don't solve your problem, use another tool till Lead fixes the bug. BR Mike |
11-25-2005, 09:37 | #13 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Timeless zone! Age: 35
Member: 152244 Status: Offline Sonork: 100.1591179 Thanks Meter: 162 | HI MATES, I have been unlocked more than 10 pcs via patching but still no problem with it i think its the problem with some versions so as doctormike says flash it with another version and check it and then use unlock via patching and dont forget to post the results here..............OK BR MUNEEB AKHTAR RAZA |
11-25-2005, 10:01 | #14 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Holland China Brazil Age: 43
Member: 88016 Status: Offline Thanks Meter: 320 | Don't worry man , its common problem in Lg fones, u just write flash with patch files, your set will be alive again , if not so download orignal files from support area and use Tp, post results i have more solutions. Goodluck. BR Kashif Khan |
11-28-2005, 15:55 | #15 (permalink) |
Member: 91102 Status: Offline Thanks Meter: 34 | thanks everybody i got it unlocked with FURIOUSBOX2 by flashing an unlocked flashfie into it i tryed as mr doctormike said, flashed with the flashfile he mentioned and unlocked by patch with cruiser but the phone went dead again but got it sorted with FB2 BR |
how to unlock with cruiser and the version 2.05 | s4lzburgo | Cruiser Suite | 0 | 04-04-2009 20:53 |
My first o2x1 unlock with Fgold not detecting ... | MohammedSharif | FuriousGold | 3 | 12-25-2007 16:42 |
can Z525a unlock with cruiser and flash to chinese? | squall82 | Cruiser Suite | 5 | 04-04-2007 11:21 |
Cruiser v4.00 - the first to unlock Sharp V802SH and V902SH via video connector! | Lead | Cruiser Suite | 54 | 07-06-2005 12:19 |
phiilips 330 killed with red-box my first phone killed with it and i hope last one | loopkiller | Redbox | 1 | 11-25-2004 15:19 |
