01-29-2009, 11:59 | #16 (permalink) |
No Life Poster Join Date: Apr 2005 Age: 45
Member: 132856 Status: Offline Thanks Meter: 36 | Code: 10:52:21 SE S1 Flasher & Unlocker v1.01 by Cruiser Team 10:52:21 Initializing... ! 10:52:22 1. Choose the phone model ! 10:52:22 2. For flashing, select flash files and additional options ! 10:52:22 3. Double-click on the appropriate device (serial cable) 10:52:33 Connecting via Cruiser UC-20 Cable (COM6)… 10:52:33 Device driver version: 2.4.6.0 10:52:33 Device driver date: 3-13-2008 ! 10:52:33 Connect the phone now E 10:52:36 Error: 0x1DDC1593 E 10:52:36 Failed! ! 10:52:36 Please disconnect battery and cable from the phone! ! 10:52:36 To report errors right-click this window |
01-29-2009, 12:37 | #17 (permalink) | |
Freak Poster Join Date: Jul 2008
Member: 670274 Status: Offline Thanks Meter: 165 | Quote:
GLaDOS | |
01-29-2009, 12:44 | #18 (permalink) | |
Banned Join Date: Apr 2005 Age: 42
Member: 137474 Status: Offline Sonork: 100.109924 Thanks Meter: 471 | Quote:
01-29-2009, 16:05 | #20 (permalink) |
Junior Member Join Date: Oct 2005
Member: 188689 Status: Offline Thanks Meter: 2 | Must J132 be on or off when connecting to UC-10 ? i get this : Code: 16:00:17 SE S1 Flasher & Unlocker v1.01 by Cruiser Team 16:00:17 Initializing... ! 16:00:17 1. Choose the phone model ! 16:00:17 2. For flashing, select flash files and additional options ! 16:00:17 3. Double-click on the appropriate device (serial cable) 16:00:28 Connecting via Cruiser UC-10 Cable (COM8)… 16:00:28 Device driver version: 1.0.2154.0 16:00:28 Device driver date: 4-16-2004 ! 16:00:28 Connect the phone now 16:00:28 Connecting to the baseband CPU... E 16:02:15 Error: 0x11990C76 E 16:02:15 Error: 0x03FA0F16 E 16:02:15 Failed! ! 16:02:15 Please disconnect battery and cable from the phone! ! 16:02:15 To report errors right-click this window |
01-30-2009, 19:45 | #21 (permalink) | |
http://forum.gsmhosting.com/vbb/showthread.php?t=674693 | |
The Following User Says Thank You to GLaDOS For This Useful Post: |
01-30-2009, 19:50 | #22 (permalink) | |
It must be off, like any other phone. But J132 phone is a bit tricky. For Unsigned mode, it is mostly enough to doble-click the cable and connect it to the phone. For signed mode, connect it when holding '2' | |
01-30-2009, 20:28 | #23 (permalink) | |
GLaDOS | |
02-02-2009, 13:42 | #24 (permalink) |
Member: 188689 Status: Offline Thanks Meter: 2 | i connected the J132 now.. by pressing 2 button and quickly pressing the power button. now i get this : Code: 13:12:40 SE S1 Flasher & Unlocker v1.01 by Cruiser Team 13:12:40 Initializing... ! 13:12:40 1. Choose the phone model ! 13:12:40 2. For flashing, select flash files and additional options ! 13:12:40 3. Double-click on the appropriate device (serial cable) 13:13:08 Connecting via Cruiser UC-10 Cable (COM8)… 13:13:08 Device driver version: 1.0.2154.0 13:13:08 Device driver date: 4-16-2004 ! 13:13:08 Connect the phone now 13:13:08 Connecting to the baseband CPU... 13:13:17 Entering baseband CPU service mode... 13:13:18 IMEI: 35710702092985 13:13:18 Phone type: J132 13:13:18 CDA info: 1215-5021 R5A 13:13:18 Phone software: 1211-2311 R1AA029 13:13:18 Sending loader... E 13:14:19 Error: 0x4835B81D E 13:14:19 Error: 0xE09A592A E 13:14:19 Error: 0xB40A84A8 E 13:14:19 Error: 0xBD26CE5A E 13:14:19 Error: 0x1D5EF9BD E 13:14:19 Error: 0x93D2F1E5 E 13:14:19 Error: 0xC41C185B E 13:14:19 Failed! ! 13:14:19 Please disconnect battery and cable from the phone! ! 13:14:19 To report errors right-click this window |
02-09-2009, 16:21 | #26 (permalink) |
Freak Poster Join Date: Aug 2007
Member: 577093 Status: Offline Thanks Meter: 1 | what's the maening of this error Code: 18:44:16 SE Full Unlocker v2.32 by Cruiser Team 18:44:16 Initializing... ! 18:44:16 1. Please see the documentation first (a PDF installed with the application) ! 18:44:16 2. Make sure the appropriate phone modem drivers are installed (if applicable) ! 18:44:16 3. Fill in the connection settings under settings tab ! 18:44:16 4. Turn the phone ON ! 18:44:16 5. Connect the phone… 18:44:48 Connecting via Generic EMP USB Flash Device (USB1)… 18:44:48 Device driver version: 1.0.0.8 18:44:48 Device driver date: 3-30-2006 18:44:48 Starting communication... 18:44:48 Connecting to the baseband CPU... E 18:46:36 Error: 0x11990C76 E 18:46:36 Error: 0x03FA0F16 E 18:46:36 Error: 0x28FF3CA4 E 18:46:36 Failed! ! 18:46:36 Please disconnect battery and cable from the phone! ! 18:46:36 To report errors right-click this window Code: ! 18:47:27 - for W880/W888 phone, connect it while holding 2-* instead of 2-5 18:47:27 SE Ultimate Unlocker v3.07 by Cruiser Team 18:47:27 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 18:47:27 Initializing... ! 18:47:27 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 18:47:27 2. Choose the phone model ! 18:47:27 3. Select the desired options ! 18:47:27 4. Please connect the phone either via USB while holding 2-5… ! 18:47:27 - or via a serial cable and double-click on it in the device list 18:47:43 Selected phone: W880/W888 18:47:43 Connecting via Generic EMP USB Flash Device (USB1)… 18:47:43 Device driver version: 1.0.0.8 18:47:43 Device driver date: 3-30-2006 18:47:44 Connecting to the baseband CPU... 18:47:44 Entering baseband CPU service mode... 18:47:44 Detected chipset: DB2020 18:47:44 Boot mode: ROM 18:47:44 Sending loader... 18:47:44 IMEI: 35777401990450 18:47:44 OTP CID: 51 18:47:44 Effective CID: 52 18:47:46 Please reconnect the phone (disconnect, connect while holding 2-5) E 18:48:04 Error: 0x4D5EFC5D E 18:48:04 Error: 0x8F9F6E1C E 18:48:04 Error: 0x4B4AFEF3 E 18:48:04 Error: 0x319AC5CC E 18:48:04 Error: 0x624C554E E 18:48:04 Error: 0x5577997D E 18:48:04 Error: 0x5C5AEBE3 E 18:48:04 Error: 0x3D35EAF1 E 18:48:04 Failed! ! 18:48:04 To report errors right-click this window |
02-17-2009, 16:46 | #28 (permalink) |
Junior Member Join Date: Nov 2004 Age: 41
Member: 94513 Status: Offline Thanks Meter: 2 | I have some problem with T280i-SE S1 Flasher & Unlocker Code: 16:41:50 SE S1 Flasher & Unlocker v1.01 by Cruiser Team 16:41:50 Initializing... ! 16:41:50 1. Choose the phone model ! 16:41:50 2. For flashing, select flash files and additional options ! 16:41:50 3. Double-click on the appropriate device (serial cable) 16:42:39 Connecting via Cruiser UC-10 Cable (COM1)… 16:42:39 Device driver version: 1.0.2154.0 16:42:39 Device driver date: 4-16-2004 ! 16:42:39 Connect the phone now 16:42:39 Connecting to the baseband CPU... E 16:43:26 Error: 0xE1E2479D E 16:43:26 Error: 0x06EB86E0 E 16:43:26 Error: 0x7E23C4B3 E 16:43:26 Error: 0x275F2EE0 E 16:43:26 Failed! ! 16:43:26 Please disconnect battery and cable from the phone! ! 16:43:26 To report errors right-click this window |
02-21-2009, 12:13 | #29 (permalink) | |
No Life Poster Join Date: Jan 2005 Location: On Roads... Age: 43
Member: 107839 Status: Offline Sonork: 100.1592822 Thanks Meter: 70 | Quote:
this version Version 1.01 can't reconize my dongle but old Version 1.00 work OK... i need to flash W302... any solution? B.R ZACHI | |
.: News: CruiserSuite S1 Flasher & Unlocker v3.00 released - Satio now supported :. | Mizar | Cruiser Suite | 40 | 11-04-2017 10:14 |
.: News: CruiserSuite S1 Flasher & Unlocker v3.00 released - Satio now supported :. | Mizar | Service Products News & Updates | 0 | 12-19-2009 11:36 |
.: New release: S1 Flasher & Unlocker v2.05 - Instant S1 unlock in many languages :. | Mizar | Cruiser Suite | 71 | 09-16-2009 05:59 |
.: New release: CruiserSuite S1 Flasher & Unlocker - Instant unlock now supported :. | Mizar | Service Products News & Updates | 1 | 03-06-2009 00:42 |
New release: CruiserSuite S1 Flasher & Unlocker - S1 Neptune flashing now supported | Mizar | Service Products News & Updates | 0 | 01-21-2009 10:52 |
