01-13-2005, 01:27 | #1 (permalink) |
No Life Poster Join Date: Jun 1999 Location: Germany
Member: 233 Status: Offline Thanks Meter: 36 | P910i killed by wrong flash I have flash a P910i, but I select the CDA file instad of the phone file. Now phone can by flashed, but can't turn on anymore, I think overwrited GDFS Area. I backup security area befor but cant write back. Any help is welcome Jan |
01-13-2005, 02:13 | #2 (permalink) |
No Life Poster Join Date: Mar 2002 Location: Guadeloupe Age: 50
Member: 9955 Status: Offline Thanks Meter: 7 | tell us exactly what u do. coz in p910 THERE IS / PDA, CDA Bluetooth, MCU and GDFS so it can be a lot of possiblilty Anyways, best solution for u if u have 2 P910 is to go in support area of sony ericsson and flash the dead phone using the Good phone first, then when u have message READY TO UPDATE, put dead one phone in to BASE and download will start |
01-13-2005, 02:31 | #3 (permalink) |
No Life Poster Join Date: Jul 2004 Location: 0xBA, 0xBE Age: 38
Member: 73743 Status: Offline Thanks Meter: 2 | @jan If your phone is indeed "dead" and you have tried reflashing all phone and symbian parts with correct files then it may need a "Full AVR" flash which is AVR + the GDFS part. This will revive your phone. However you will need a image from a good phone so maybe you could politely ask some one to read out the full AVR or you. |
01-13-2005, 07:52 | #4 (permalink) | |
No Life Poster Join Date: Jan 2004 Location: Southern California, USA
Member: 51190 Status: Offline Thanks Meter: 0 | Quote:
01-13-2005, 10:37 | #5 (permalink) |
Member: 233 Status: Offline Thanks Meter: 36 | Hi Thanks, I think this is what I need. Another Question, must I flash CDA and Symbian as PDA file ( first CDA, then same procedure with symbian ) ? CDA is working, symbian give error in finialization. send flash to [email protected] Thanks |
01-13-2005, 10:42 | #6 (permalink) |
No Life Poster Join Date: Oct 2003 Location: Auckland, New Zealand
Member: 42570 Status: Offline Thanks Meter: 11 | Yes, you flash both those files via the PDA option. You only use the ARM button when flashing Bluetooth Module. If you're getting an error in finialization then make totally sure the battery is fully charged and lower the baudrate the 460800 in the Fighter Settings -> Baudrate for P90x PDA If I had a P910i file I'd send it, but I don't I'm afraid. |
01-16-2005, 00:38 | #10 (permalink) |
Guest
Posts: n/a
Member: | Yes im taking backup and i will upload into my server, try to be active on this topic until 01:00 ! Ready! Connecting via Fighter USB Cable... Activating phone... Secure bootloader ID: 5B 08 02 01 Checking RSA protection feature... Sending applet prologue... Sending applet body... RSA protection feature ACTIVE. Time spent entering bootstrap: 3s Initializing phone hardware... Phone hardware initialized OK Removing RSA lock... Sending flash applet... Baudrate = 921600Bd Programming flash... Time: 00:00:01 Flash process done. RSA unlocked successfully! Connecting via Fighter USB Cable... Activating phone... Secure bootloader ID: 5B 08 02 01 Checking RSA protection feature... RSA protection feature inactive. Bypassing authority check... Time spent entering bootstrap: 13s Initializing phone hardware... Phone hardware initialized OK Firmware: P910 R3E008 [CXC162042] RSA area is empty and MUST BE REFLASHED! |
01-16-2005, 01:02 | #12 (permalink) |
Guest
Posts: n/a
Member: | http://www.araashs.com/P910i/ .. Good luck |
E1310M killed by wrong flash | Trixxie | UST Pro II | 10 | 04-21-2010 14:53 |
L6 killed by wrong flash | mmanduri | Smart-Clip | 5 | 04-18-2006 18:43 |
p910i killed by furious box again | nokia_dan | FuriouS II | 4 | 09-07-2005 19:24 |
P800 killed by wrong flash Cruiser | simlockman1 | Cruiser Suite | 30 | 07-24-2005 19:49 |
any solution for c25 v61 killed by wrong unlock? | sat | x1x to x45/x50 | 20 | 03-26-2002 20:46 |
