05-20-2006, 04:30 | #1 (permalink) |
Junior Member Join Date: Dec 2004 Location: Augsburg/DE
Member: 95694 Status: Offline Thanks Meter: 0 | phone killer? after years of using div and atr I thought it's time to get a cruiser and got it yesterday. The installation was easy and everything worked well. Then I wanted to do the first flash and took a T68m which had emea1 instead of eu2 what I need. So I flashed eu2 avr and arm and after it the phone freezed when I powered it on. After flashing a second time it was ok. Then I took a T65 and updated avr and arm. After it I couldn't switch it on so I tried to flash it a second time like I did before with the T68m. At the end of flashing the avr-part cruiser told me that some bytes were wrong. The phone got detached automatically and was dead. I couldn't even boot it anymore. Maybe I just need to remove/reinstall the battery for booting but with the T65 it's not so funny to do this job. Today I upgraded a T39m and got the same problemagain: Another dead phone. I was able to boot it but cruiser told me to manually chose the modell because it can't be identified. So I did and was able to boot it correctly but the imei shown was 0000... It seems, that cruiser destroyed the gdfs-area of the phone. Fortunately I have some more T39 so I could make a full backup of one of them which I flashed in the dead T39. It works again but I still wonder why cruiser kills 3 of 5 phones which I flashed until today. Of course I can backup the gdfs every time before flashing but this is not what I expect of it. What can be the reason for it? I installed the latest cruiser v9.66. Is this version buggy in any way? I don't want to kill any more gdfs-areas and would be happy for any help. r0sewhite |
05-20-2006, 08:37 | #2 (permalink) |
No Life Poster Join Date: Jan 2004 Age: 45
Member: 49581 Status: Offline Thanks Meter: 73 | i have been using cruiser roughly about an year .... and i had to use it many times everyday .... in fact, i never used the function 'GDFS Backup' (and i don't know how to use it) for more than 1 thousand of sonyericsson phones that i had working on .... and i never got any problem that cruiser kill any single phone ~ oh, yeah, i remember that I had tried to unlock a C62 which i didn't look the warning that cruiser won't work on certains version of c62, and that is the only phone i kill using cruiser ... 1 out of more than a thousand so far ... |
05-20-2006, 08:40 | #3 (permalink) | |||
Freak Poster Join Date: Nov 2003 Location: 228 (Switzerland) :) Age: 34
Member: 44110 Status: Offline Thanks Meter: 1 | Quote:
And you must see: The phones you tried are quite old, Lead has to concentrate himself to the never phones... But one thin is sure: Cruiser overwrite nothing in the phone without your command, div wrote a new securityzone when you read codes... In few days, when you have tried new phones, you will be happy with cruiser. Friendly Greetings Sven | |||
05-20-2006, 13:42 | #4 (permalink) | ||||
Member: 95694 Status: Offline Thanks Meter: 0 | Quote:
- Phone can't be switched on and doesn't load if connected to a charger - Phone can't be autodetected by cruiser und must be set manually - Cruiser shows a 0000...-imei for the phone Quote:
- fully charging the phone - checking connector for dirt/damages - connecting and booting the phone - flashing AVR with the new version - flashing ARM with the new version - detaching the phone I think there's nothing I could have misunderstood. It's the same procedure like with DIV or other tools. As far as I see the only difference regarding flashing old phones is that I can detach the phone by sw-button after flashing. Quote:
Thanks, r0sewhite | ||||
05-20-2006, 14:55 | #5 (permalink) |
No Life Poster Join Date: Oct 2003 Location: Auckland, New Zealand
Member: 42570 Status: Offline Thanks Meter: 11 | @r0sewhite: As Cruiser keeps developing I'm sure there's a *lot* of code changes that go on. As these changes happen, newer phones are tested while the older phones often get left behind. If you spend a while reading these forums you sometimes read where a update for a new phone type will accidently break an older phone. Just from what I've read here, I don't think you've done anything wrong - though these phones are so old (at least - I've never held one) that I'm not sure what the correct procedure to use them is. If I would you I'd read through the manual for the procedure for these phones (if it's even listed?) and make sure you keep a log of what happens as you go. If something doesn't work as expected, cut and paste the log here along with what happened to the phone. Lead might then be able to fix the problem for you. |
05-20-2006, 19:01 | #6 (permalink) | |
Thanks, the procedure was alright as it is the same like with DIV. Unfortunately most of the phones I work with are old Ericsson models and not the newer SE-models. For now I will first backup the GDFS before flashing anything at any phone. I will forward any error report and hope that one day it won't be necessairy anymore. Maybe some older Cruiser-SW works better with my old phones. Regards, r0sewhite | |
05-22-2006, 10:06 | #9 (permalink) |
Freak Poster Join Date: Mar 2006 Location: Winnipeg Canada
Member: 244492 Status: Offline Thanks Meter: 8 | If I would you I'd read through the manual for the procedure for these phones (if it's even listed?) and make sure you keep a log of what happens as you go. If something doesn't work as expected, cut and paste the log here along with what happened to the phone. Lead might then be able to fix the problem for you.[/quote] you are very right my bro.this problem also occur witht610/630 you cannot flash arm completely and most of olds version. pl's my Lead this should not be left out by words updating should not live the odd fones. my regards. Last edited by bambo clan; 05-22-2006 at 10:20. |
05-22-2006, 16:17 | #10 (permalink) |
No Life Poster Join Date: Aug 2004 Location: US/DK/S
Member: 76964 Status: Offline Thanks Meter: 2 | Using Cruiser 9.66 (not the latest, I know) flashing both T610 and T630 and T616 and T637 with no issues except for the usual boot problems. Retrying a couple of times, cleaning connectors inbetween, usually does the trick. Also, do not forget a fully charged bnsttery also helps....... (and my old "reliable" DSS-20....) The major reason for these boot issues in my experience is that these have really old FW, so RSA is not enabled. As soon as they have been reflashed with RSA firmware, they attach almost instantly. If you have a phone that totally does not want to attach, having an EMMA-card handy does the trick. Have Cruiser use it, and it will boot instantly. |
05-22-2006, 21:59 | #11 (permalink) |
Freak Poster Join Date: Dec 2002
Member: 18369 Status: Offline Thanks Meter: 3 | @ everyone that answered to this tread In the information site for cruiser it says it works with all old Ericsson phones....complete fighter functionality... I think Lead is responsible for his information to us, arent you Lead ? I dont think that adding new models should make old phones crash..because they certainly dont use the same code...? Of course mistake can occur like the flashing T28/R320/R310 bug that was corrected a few versions ago. I have not flashed old phones lately but I have done in the past and then it has been working good with T39 and T65. /Best regards Daniel |
05-22-2006, 22:21 | #12 (permalink) |
Member: 76964 Status: Offline Thanks Meter: 2 | Well, just like Muppet confirmed, some updates by Lead will crash functionality for older phones. I have personally experienced support for the Txxx phones (T610,T616,T630,T637) go crashing after updates for the newer phones by Lead. He usually fixes it a release or 2 later, but the fact is that it crashes! This is why I stated above that Cruiser 9.66 works for these phones. |
Zulea not Pkey killer but He is phone killer | Mr.3. | Nokia Base Band 5 ( BB-5 ) | 0 | 04-11-2009 16:02 |
Free siemens unlocker - slow phone killer :-) | hackgsm.net | E-Gold Based Phones | 21 | 09-05-2003 21:40 |
does zulea bfg key a phone killer? | Wriwolff | BF, BG, TH, BHx Series | 6 | 04-17-2003 12:49 |
SonyEricsson phone unlocker becomes phone killer! | cgigate | Sony Ericsson | 72 | 02-06-2003 12:51 |
Another One Phone Killer | nikist | BF, BG, TH, BHx Series | 6 | 01-23-2003 16:23 |
