Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > Cruiser Suite
Old 08-20-2006, 13:00   #1 (permalink)
falcon2's Avatar
Member: 116295
Thanks Meter: 14
Please!!Can anyone help me for K600 imei
Has a k600i cid 49 wants to changed imei
tries and tries with cruiser 9.74 but do not succeed
I do this procedure >>>>>
Red CID49 W550/W600 IMEI change procedure (more complicated variant)
Note A: Unlocking RSA overwrites the first 128 or 256 KBytes of firmware.
Note B: To attach the phone use Ctrl-A key combination.
Attach (phone should be red CID49)
Security RSA -> Unlock RSA, then remove battery when prompted to do so.
Reattach and flash main FW. (RSA will be relocked)
Turn off and reattach.
Unlock RSA again, remove battery when prompted to do so.
Reattach.
IMEI -> Disable OTP check
Flash raw FS (not the main FW part).
Customize FS.
Turn off phone.
Reattach.
IMEI -> Write GDFS IMEI
Reattach
Flash the corresponding firmware restore file (for example R4BA041_CXC1250031_GENERIC_EL.cw55sw)
Turn off phone.
After then says "Pleasewait
This procedure
Red CID49 W550/W600 IMEI change procedure (simpler variant)
Reattach.
Turn off phone.
says insert sim
most important imei is not changed in in the telephone
what will do
tries in a month
please help me
Old 08-21-2006, 10:46   #2 (permalink)
falcon2's Avatar
Member: 116295
Thanks Meter: 14
Nobody can help me??
Is the not possible to change imei on that telephone??
Old 08-21-2006, 13:49   #3 (permalink)
RGUY's Avatar
Member: 277942
When you connect the phone check and see if you can replace the certificate to a brown CID 49. If you can then follow the procedure for older phones with normal EROM. Unlocking RSA is only for phones with Locked-Down EROM.
Old 08-21-2006, 23:34   #4 (permalink)
falcon2's Avatar
Member: 116295
Thanks Meter: 14
Does not go replace
when I try replace the certificate to a brown CID 49
says this message
Applet error: ERROR|EraseBlock| 04 FF FF FF 1F
Error flashing block at address: 0x215F0000
Script error: Flash error [9.74.75]
can anyone help me for sony ericsson j110l boussoula Infinity-Box 6 12-24-2009 20:01
e63 config key: 0000 can anyone help me for this, locked from 3 uk. dragories Nokia Base Band 5 ( BB-5 ) 0 05-10-2009 17:13
CAN ANYONE HELP me for update my ORIGINAL - NOT CLONE hwk .. hangout2511 HWK 0 07-14-2008 14:43
Please Can anyone help me need point n88 masad Infinity-Box 2 10-26-2007 18:41
Page generated in 0.31100 seconds with 8 queries
