04-02-2009, 11:55 | #1 (permalink) |
Junior Member Join Date: Mar 2008 Location: spain
Member: 739152 Status: Offline Thanks Meter: 2 | Pb with server Code: 12:52:21 SE S1 Flasher & Unlocker v2.05 by Cruiser Team 12:52:21 Initializing... ! 12:52:21 1. Choose the phone model ! 12:52:21 2. For flashing, select flash files and additional options ! 12:52:21 3. Double-click on the appropriate device (serial cable) ! 12:52:21 - or connect the phone via USB while holding its C button 12:52:27 Connecting via Cruiser UC-10 Cable (COM6)… 12:52:27 Device driver version: 1.0.2154.0 12:52:27 Device driver date: 4-16-2004 ! 12:52:27 Connect the phone now 12:52:27 Connecting to the baseband CPU... E 12:53:35 Error: 0xE1E2479D E 12:53:35 Error: 0x11990C76 E 12:53:35 Error: 0x03FA0F16 E 12:53:35 Failed! ! 12:53:35 Please disconnect battery and cable from the phone! ! 12:53:35 To report errors right-click this window |
04-02-2009, 12:18 | #3 (permalink) |
No Life Poster Join Date: Nov 2003 Location: in my PC of Montreal
Member: 43478 Status: Offline Thanks Meter: 33 | server not work for me also Code: 12:13:46 D-Ultimate Unlocker v3.07 by Cruiser Team 12:13:46 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 12:13:46 Initialisation en cours… ! 12:13:47 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 12:13:47 2. Choisir le model du telephone ! 12:13:47 3. Select the desired options ! 12:13:47 4. Please connect the phone either via USB while holding 2-5… ! 12:13:47 - or via a serial cable and double-click on it in the device list 12:13:51 Communicating with server… E 12:14:01 Error: 0xB3A47971 E 12:14:01 Login to server failed E 12:14:01 Echec! ! 12:14:01 Pour rapporter l'erreur cliquer droit sur cette fenetre |
04-02-2009, 12:24 | #4 (permalink) |
No Life Poster Join Date: Apr 2005 Location: between New Zealand - Canada Age: 42
Member: 135110 Status: Offline Thanks Meter: 302 | Code: 13:22:06 D-Ultimate Unlocker v3.07 by Cruiser Team 13:22:06 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 13:22:06 Initializing... ! 13:22:06 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 13:22:06 2. Choose the phone model ! 13:22:06 3. Select the desired options ! 13:22:06 4. Please connect the phone either via USB while holding 2-5… ! 13:22:06 - or via a serial cable and double-click on it in the device list 13:22:08 Communicating with server… ! 13:22:18 News: Your credit consumption policy: Level 3 (Skilled) 13:22:18 Remainig credit (supreme): xx 13:22:18 Done. |
pb with N70 +6680 with flashing | kifah | Universalbox | 3 | 11-21-2008 15:36 |
pb with nec server | SoSgSm | FuriousGold | 2 | 09-02-2007 00:45 |
big pb with dmtools | micmac | Motorola ODM | 1 | 06-06-2002 07:38 |
Many pb with ericsson T68 . | micmac | Sony Ericsson Hardware Repair | 1 | 05-13-2002 09:07 |
big pb with bf3 | micmac | BF, BG, TH, BHx Series | 11 | 04-22-2002 22:53 |
