Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > Cruiser Suite
Old 04-01-2009, 12:15   #1 (permalink)
Member: 166325
Thanks Meter: 44
Please check my credit
hello cruiser team,
please check my credit,
the credit is deducted for nothing.
The Log
17:56:10 SE Ultimate Unlocker v3.07 by Cruiser Team
17:56:10 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change
17:56:10 Initializing...
! 17:56:10 1. Please see the documentation first (the tab 'Info' or attached .pdf file)
! 17:56:10 2. Choose the phone model
! 17:56:10 3. Select the desired options
! 17:56:10 4. Please connect the phone either via USB while holding 2-5…
! 17:56:10 - or via a serial cable and double-click on it in the device list
17:56:24 Selected phone: K320
17:56:24 Connecting via Generic FTDI Cable (COM6)…
17:56:24 Device driver version: 2.0.0.0
17:56:24 Device driver date: 5-19-2006
17:56:25 Connecting to the baseband CPU...
17:56:25 Entering baseband CPU service mode...
17:56:25 Detected chipset: DB2012
17:56:25 Boot mode: ROM
17:56:25 Sending loader...
17:56:26 IMEI: 3525700228xxxx
17:56:26 OTP CID: 50
17:56:26 Effective CID: 50
17:56:26 Restarting phone …
17:56:28 Sending loader...
17:56:29 Communicating with server…
! 17:56:34 News: Your credit consumption policy: Level 2 (Junior)
17:56:35 Remainig credit (supreme): 2.50
E 17:56:38 Error: 0xE1E2479D
E 17:56:38 Error: 0x81DFD6C2
E 17:56:38 Error: 0xE7069ECB
E 17:56:38 Error: 0x99ABE76D
E 17:56:38 Error: 0x18CFA82A
E 17:56:38 Error: 0xF1FA9EA9
E 17:56:38 Error: 0x4826F9E1
E 17:56:38 Error: 0x834ACC0E
E 17:56:38 Error: 0x07F5EFDA
E 17:56:38 Error: 0x51A411A0
E 17:56:38 Error: 0x78E56923
E 17:56:38 Error: 0x5C5AEBE3
E 17:56:38 Error: 0x3D35EAF1
E 17:56:38 Failed!
! 17:56:38 To report errors right-click this window
17:57:05 SE Ultimate Unlocker v3.07 by Cruiser Team
17:57:05 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change
17:57:05 Initializing...
! 17:57:05 1. Please see the documentation first (the tab 'Info' or attached .pdf file)
! 17:57:05 2. Choose the phone model
! 17:57:05 3. Select the desired options
! 17:57:05 4. Please connect the phone either via USB while holding 2-5…
! 17:57:05 - or via a serial cable and double-click on it in the device list
17:57:34 Communicating with server…
! 17:57:37 News: Your credit consumption policy: Level 2 (Junior)
17:57:37 Remainig credit (supreme): 2.25
17:57:37 Done.
cek log i attach here
Old 04-01-2009, 12:42   #2 (permalink)
Member: 670274
Thanks Meter: 165
The credit is consumed due to a server resource consumprion.
Please make sure the phone battery is fully charged and repeat the procedure, it is for free for 2 more attempts.
GLaDOS
Old 04-01-2009, 12:51   #3 (permalink)
Member: 166325
Thanks Meter: 44
@glaodos....
aro u read my log
the credit is already eat before...
06:27:39 SE Ultimate Unlocker v3.07 by Cruiser Team
06:27:39 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change
06:27:39 Initializing...
! 06:27:39 1. Please see the documentation first (the tab 'Info' or attached .pdf file)
! 06:27:39 2. Choose the phone model
! 06:27:39 3. Select the desired options
! 06:27:39 4. Please connect the phone either via USB while holding 2-5…
! 06:27:39 - or via a serial cable and double-click on it in the device list
06:27:49 Selected phone: K320
06:27:49 Connecting via Generic FTDI Cable (COM6)…
06:27:49 Device driver version: 2.0.0.0
06:27:49 Device driver date: 5-19-2006
06:27:50 Connecting to the baseband CPU...
06:28:09 Entering baseband CPU service mode...
06:28:09 Detected chipset: DB2012
06:28:09 Boot mode: ROM
06:28:09 Sending loader...
06:28:10 IMEI: 3525700228xxxx
06:28:10 OTP CID: 50
06:28:10 Effective CID: 50
06:28:10 Restarting phone …
06:28:13 Sending loader...
06:28:13 Communicating with server…
! 06:28:17 News: Your credit consumption policy: Level 2 (Junior)
06:28:17 Remainig credit (supreme): 2.75
06:28:20 Remainig credit (supreme): 2.50
06:28:21 Restarting phone …
06:28:23 Sending loader...
06:28:36 Initializing GDFS access...
06:28:36 Writing GDFS…
E 06:29:36 Error: 0xE1E2479D
E 06:29:36 Error: 0x07F5EFDA
E 06:29:36 Error: 0x3173E984
E 06:29:36 Error: 0x4B055A8F
E 06:29:36 Error: 0xE9FB48DF
E 06:29:36 Error: 0xCC9B40DA
E 06:29:36 Error: 0x8F6C03FD
E 06:29:36 Error: 0x980B6A88
E 06:29:36 Error: 0x8118A648
E 06:29:36 Error: 0x59AF7680
E 06:29:36 Failed!
! 06:29:36 To report errors right-click this window
the credit alredy eat in 2.75 to 2.50
but check in 2.50 to 2.25
no phone connection
Old 04-01-2009, 13:08   #4 (permalink)
FilipLudvik's Avatar
Member: 135110
Thanks Meter: 302
How long was the time period between the two actions?
Old 04-01-2009, 13:12   #5 (permalink)
Member: 412097
Thanks Meter: 56
maybe therif mean he only check credit but his credit reduce 0.25
Old 04-02-2009, 16:22   #6 (permalink)
Member: 992243
Thanks Meter: 7
Kindly Cruiser team make some notes. This error causes by applications / bad GDFS / connection problem or just want some peny from us....
How to check my credits? BackSlash_cu SETool2 2 12-01-2009 11:22
sir kindly check my credit less receive blank code JMJ ALBERT Gsmfather The Wholesale Unlocking Database 4 08-28-2009 03:41
how can i check my credits in easy way ashish mobile Universalbox 2 06-14-2009 14:04
How can I check my credits balance on SMTi ? gsminfo SMTi 0 03-15-2009 10:15
Page generated in 0.19528 seconds with 10 queries
