06-02-2007, 17:09 | #1 (permalink) |
No Life Poster Join Date: Sep 2004 Location: coast Age: 53
Member: 83397 Status: Offline Thanks Meter: 204 | PLEASE HELP W550i DEAD |
06-02-2007, 17:23 | #2 (permalink) |
Super Moderator Join Date: Aug 2005 Location: UK.... Age: 57
Member: 173077 Status: Offline Sonork: 100.1594293 Thanks Meter: 2,784 | Bit of a silly question . make sure your battery is fully charged first. Attach.. unlock RSA, remove battery replace, Direct unlock (do it) Now flash the filesystem first. (choose correct file) customise filesystem from drop menue select same as your files. Now flash the ARM, (main) remove battery and replace . DONE.. (hopefully) |
06-02-2007, 17:56 | #3 (permalink) |
Banned Join Date: Jan 2007 Location: India Age: 34
Member: 432364 Status: Offline Thanks Meter: 270 | OR download video from support site...N see for easy... W550 CID 49 FLASH W550 CID 49 LAST STEP Use n pass: cruiser B.r. Sunil. |
The Following User Says Thank You to ..::Sunil::.. For This Useful Post: |
06-05-2007, 06:24 | #6 (permalink) |
Member: 83397 Status: Offline Thanks Meter: 204 | thanks all for reply but when try to flash i get this log [ --- Attach to Phone --- ] Connecting via Fighter USB Cable... Powering on the phone... Baseband chip ID: 0x8040 Protocol version: 3.1 Baudrate = 460800Bd Sony Ericsson phone detected. Phone CID: 49 Phone color: Brown Flash certificate: A1_DB2010_49_BROWN Trying Brown CID49 flash applet... Sending applet prologue... Sending applet body... Time spent entering bootstrap: 2s Initializing phone hardware... Applet ID: 060206 1814 NPACXC125872_COMPACTPRO... Flash manufacturer: Intel Flash ID: 0x890D OTP Security Level: 1 (Retail) OTP CID: 49 Phone type (from GDFS): W550i CXC article: R4AB048 prgCXC1250086_CHINA_EL CXC version: R4AB048 Language package: APAC_1 Operator: Generic Trade CDA article: CDA102415/40 CDA version: R1A Default article: cxc1250032 Default version: R4AB048 Phonecode: 0000 Sending applet... Applet ID: 060222 0202 CRUCXC1250166_1_SEMC_CO... Analyzing configuration... Reading primary certificate... Primary certificate CID: 49 Primary certificate color: Brown Reading secondary certificate... Secondary certificate CID: 36 Secondary certificate color: Brown GDFS configuration found. OSE configuration found. TestProgram configuration not found. Analysing GDFS... Done. RSA protection is normal. Phone hardware initialized OK [ --- Flash Raw File System --- ] Flash file: "W550i_CXC1250032_Europe1_R4CA004_Brown49.cw55 fs" Waiting for flash file to load... Reading phone RSA certificate... it stops here please advise what to do |
The Following User Says Thank You to jamohaki For This Useful Post: |
06-05-2007, 10:09 | #8 (permalink) |
Member: 432364 Status: Offline Thanks Meter: 270 | @ jamohaki Y u don't try step by step...Do unlock rsa frist...Read post no.2 if still u don't understand steps...Use this easy.. 1. Attach to phone 2. Unlock rsa ( Reinsert bettery ) 3. Flash fs 4. Customize fs 5. Shutdown fs ( Reinsert bettery ) 6. Attach to phone 7. Flash main 8. Turn off phone... N post result... B.r. Sunil. |
06-05-2007, 18:24 | #9 (permalink) |
No Life Poster Join Date: May 2005 Location: Emmc & Ufs Chips Age: 42
Member: 145494 Status: Offline Sonork: 100.111656 Thanks Meter: 18,407 | best solution for w550i or c any is (red 49) is this 1) attach phone 2) unlock rsa 3) restorefirmware 4) flash main 5) flash with cust 6) shutdown fs now phone is ok and working condition the flash file for RED49 phones are main W550c_CXC1250086_China_R4CB020_Red49 fs W550i_CXC1250032_APAC1_R4CB020_Red49 WBR. sachin |
The Following User Says Thank You to chinchik For This Useful Post: |
06-14-2007, 07:00 | #11 (permalink) |
Junior Member Join Date: Jun 2007
Member: 526607 Status: Offline Thanks Meter: 1 | get XS++ from SE NSE forum, search it. Use this application to flash your W550i download at 4shared.com the firmware with filename like this W550_R4CB020_MAIN_EU_EMEA.mbn also u need the USB Flash driver, also from SE NSE forum open the program XS++.exe, then connect ur fone search the procedure how to connect from esato.com use the file with .mbn, stated above, and flash the main firmware i think it's all about 346 block will be written on ur fone if it stops somewhere, it means ur battery has no enough power to continue flashing, try to borrow compatible batt and restart the procedure this thing made me crazy when i repair my w550i, the battery thing aftersuccessful flashing, u can charge ur batt again I hope this will help u I'm just sharing my success i repairing my dead W550i thanks to SE NSE forum, 4shared.com, esato.com credits due to them goodluck |
The Following User Says Thank You to albertsumajit For This Useful Post: |
Please help for DEAD L6, need your help! | KUBAT1 | Motorola P2k | 5 | 03-30-2006 18:57 |
zulea please help w550i blinkscreen. | wbiz10 | SonyEricsson (USB-Smart) | 3 | 01-27-2006 22:46 |
Please help me , dead SL4x | KATOUE | x1x to x45/x50 | 5 | 08-10-2002 15:20 |
Please Help Me45 Dead!!! | Max468 | x1x to x45/x50 | 4 | 06-29-2002 16:46 |
Please help GD52 dead after unlocking. | banKa | Panasonic | 3 | 04-20-2002 21:19 |
