03-24-2009, 11:35 | #1 (permalink) |
Freak Poster Join Date: Dec 2005 Location: tunisia
Member: 207494 Status: Offline Thanks Meter: 22 | pls solved my problem old log ok System diagnostics passed. Version 13.20 ready! Connecting via Fighter USB Cable... Connecting to server... Connection established, checking server status... Server version: 2.55 Retrieving credit info... Your ID: user_8AE3A1E0 Credit: 6 _Prepaid time: 0d 0:0:0 _Free operations: 0 Time: 00:00:02 bat superm log no Code: 11:33:38 SE S1 Flasher & Unlocker v2.03 by Cruiser Team 11:33:38 Initialisation en cours… ! 11:33:38 1. Choisir le model du telephone ! 11:33:38 2. For flashing, select flash files and additional options ! 11:33:38 3. Double-click on the appropriate device (serial cable) ! 11:33:38 - or connect the phone via USB while holding its C button ! 11:33:40 Your card activation ID is: 221A0B18C1AA2C03A2F3A0F2D41B2700-07 11:33:40 Communicating with server… E 11:33:41 Error: 0x1F41CF97 E 11:33:41 Cannot connect to the server E 11:33:41 Check server host name and port in the settings E 11:33:41 Echec! ! 11:33:41 Pour rapporter l'erreur cliquer droit sur cette fenetre |
03-24-2009, 16:26 | #3 (permalink) |
Member: 207494 Status: Offline Thanks Meter: 22 | problem not solved with ultimate wen get credi info give me error Code: 16:17:33 SE Ultimate Unlocker v3.07 by Cruiser Team 16:17:33 - Fast & Full - Unlock, Relock, Show codes, Sec.zone rebuild, EROM repair, CID change 16:17:33 Initializing... ! 16:17:33 1. Please see the documentation first (the tab 'Info' or attached .pdf file) ! 16:17:33 2. Choose the phone model ! 16:17:33 3. Select the desired options ! 16:17:33 4. Please connect the phone either via USB while holding 2-5… ! 16:17:33 - or via a serial cable and double-click on it in the device list 16:18:14 Communicating with server… E 16:18:35 Error: 0x1F41CF97 E 16:18:35 Cannot connect to the server E 16:18:35 Failed! ! 16:18:35 To report errors right-click this window |
03-24-2009, 16:41 | #4 (permalink) |
No Life Poster Join Date: Apr 2005 Location: between New Zealand - Canada Age: 42
Member: 135110 Status: Offline Thanks Meter: 302 | you had to do what I wrote! search for ultimate unlocker solution written by me means to use the search button and you will get this working solution: http://forum.gsmhosting.com/vbb/show...ction+solution read the whole thread because the proxy has been changed. |
Uploade File failed Pls Solv My Problem | delower10 | Board, Server and Login Problems/Support | 6 | 05-15-2010 08:04 |
Pls solve my Problem | sangwilson | iPhone 2 / iPhone 3G / iPhone 3GS | 9 | 01-11-2010 00:24 |
pls solve my problem | cellncare | BB5 RPL | 0 | 08-22-2008 14:10 |
Pls Supporters Solve My Problem | New Style | iPhone 2 / iPhone 3G / iPhone 3GS | 7 | 07-26-2008 03:41 |
pls all enter solve my problem | odayking | Sharp | 8 | 02-10-2007 13:25 |
