Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cruiser Team Products > Cruiser Suite
Old 06-13-2008, 17:38   #1 (permalink)
EMINEMGSM's Avatar
Member: 57652
Thanks Meter: 1,893
Post here Successful Unlocked phones With JavaUnlocker
K610I
  17:34:31  SE A1 Java Unlocker v1.02 by Cruiser Team
  17:34:31  Initializing...
! 17:34:31  1. Choose the phone model
! 17:34:31  2. Select main firmware flash file (*.a1sw)
! 17:34:31  3. Select raw FS flash file (*.a1fs)
! 17:34:31  4. Please connect the phone while holding its C button…
  17:57:16  Connecting via SEMC USB Flash Device (USB3)…
  17:57:16  Device driver version: 2.0.0.4
  17:57:16  Device driver date: 9-12-2007
  17:57:16  Connecting to the baseband CPU...
  17:57:16  Entering baseband CPU service mode...
  17:57:17  Detected chipset: DB2020
  17:57:17  Boot mode: EROM
  17:57:17  EROM version: R3A016      prgCXC1250487_EROM_DB2020_THELMA_MIWA_RIKO_FOTA_SIMLOCK_FLAFLA_SIBLEY_SEMCUSB
  17:57:17  Initializing flash files...
  17:57:31  Sending loader...
  17:57:32  Sending loader...
  17:57:32  About to flash 37 MB of data…
  18:02:19  Sending loader...
  18:02:21  System starting up...
  18:02:21  GDFS starting up...
  18:02:34  FS starting up...
  18:02:55  FS data uploading...
! 18:03:06  1. Please disconnect battery and cable from the phone!
! 18:03:06  2. Turn on the phone with inserted test card or sim card for which is the phone locked
! 18:03:06  3. Wait to customize finish
! 18:03:06  4. Turn off the phone
! 18:03:06  5. Please connect the phone while holding its C button…
  18:06:15  Connecting via SEMC USB Flash Device (USB3)…
  18:06:15  Device driver version: 2.0.0.4
  18:06:15  Device driver date: 9-12-2007
  18:06:15  Connecting to the baseband CPU...
  18:06:15  Entering baseband CPU service mode...
  18:06:15  Detected chipset: DB2020
  18:06:15  Boot mode: EROM
  18:06:15  EROM version: R3A016      prgCXC1250487_EROM_DB2020_THELMA_MIWA_RIKO_FOTA_SIMLOCK_FLAFLA_SIBLEY_SEMCUSB
  18:06:15  Sending loader...
  18:06:16  Sending loader...
  18:06:17  Sending loader...
  18:06:19  System starting up...
  18:06:19  GDFS starting up...
  18:06:36  FS starting up...
  18:06:43  FS data uploading...
! 18:06:58  1. Please disconnect battery and cable from the phone!
! 18:06:58  2. Turn on the phone with inserted test card or sim card for which is the phone locked
! 18:06:58  3. Connect the phone again
! 18:06:58  4. If asked, Install phone drivers
! 18:06:58  5. Choose 'PHONE MODE' in the phone
! 18:33:30  After choosing 'PHONE MODE' press the Ready button
  18:33:36  Connecting via SEMC WMC Device (COM22, COM34)…
  18:33:36  Device driver version: 4.34.0.2705
  18:33:36  Device driver date: 5-1-2006
! 18:33:47  1. Please disconnect battery and cable from the phone!
! 18:33:47  2. Please connect the phone while holding its C button…
  18:34:31  Connecting via SEMC USB Flash Device (USB3)…
  18:34:31  Device driver version: 2.0.0.4
  18:34:31  Device driver date: 9-12-2007
  18:34:31  Connecting to the baseband CPU...
  18:34:31  Entering baseband CPU service mode...
  18:34:31  Detected chipset: DB2020
  18:34:31  Boot mode: EROM
  18:34:31  EROM version: R3A016      prgCXC1250487_EROM_DB2020_THELMA_MIWA_RIKO_FOTA_SIMLOCK_FLAFLA_SIBLEY_SEMCUSB
  18:34:31  Sending loader...
  18:34:32  Sending loader...
  18:34:32  About to flash 1 MB of data…
  18:34:52  Done.
! 18:34:52  Please disconnect battery and cable from the phone!
The Following 8 Users Say Thank You to EMINEMGSM For This Useful Post:
Old 06-13-2008, 20:10   #2 (permalink)
Member: 154834
Thanks Meter: 20
z310a movistar unlock ok
The Following User Says Thank You to servisoft For This Useful Post:
Old 06-13-2008, 21:19   #3 (permalink)
antoniolcrd's Avatar
Member: 283943
Thanks Meter: 124
w200i
W200i Vivo Brasil, ok.
The Following User Says Thank You to antoniolcrd For This Useful Post:
Old 06-13-2008, 22:33   #4 (permalink)
Mainboard's Avatar
Member: 25671
Thanks Meter: 719
Guys, it will help if you can post phone's model and phone's CID instead of name of original network.
"OTP CID" is NOT Phone's CID, ignore it.
Use Cruiser 13.11.
If Cruiser don't show you "Phone CID:", you can see CID of your phone if you'll look at the attaching process.
CID52 phone:
Booting via EROM...
Trying Red CID50 flash applet...
Trying Red CID51 flash applet...
Trying Red CID52 flash applet...
Sending applet prologue...
CID51 phone:
Booting via EROM...
CID50 phones:
Booting via EROM...
In other words, important is what flash applet is used as the last one. That is CID of your phone.
The Following 3 Users Say Thank You to Mainboard For This Useful Post:
Old 06-14-2008, 02:02   #5 (permalink)
Member: 113340
w200i
CD52_DB2012
ok 100% thank you
The Following User Says Thank You to rone For This Useful Post:
Old 06-14-2008, 04:58   #6 (permalink)
kcgckc2002's Avatar
Member: 42539
Thanks Meter: 182
w200 cid51, unlocked ok
The Following User Says Thank You to kcgckc2002 For This Useful Post:
Old 06-14-2008, 08:17   #7 (permalink)
joe cellular's Avatar
Member: 340957
Thanks Meter: 65
w850 success
  08:58:26  SE A1 Java Unlocker v1.02 by Cruiser Team
  08:58:27  Initializing...
! 08:58:27  1. Choose the phone model
! 08:58:27  2. Select main firmware flash file (*.a1sw)
! 08:58:27  3. Select raw FS flash file (*.a1fs)
! 08:58:27  4. Please connect the phone while holding its C button…
  08:58:44  Connecting via SEMC USB Flash Device (USB1)…
  08:58:44  Device driver version: 1.1.0.12
  08:58:44  Device driver date: 9-25-2006
  08:58:44  Connecting to the baseband CPU...
  08:58:44  Entering baseband CPU service mode...
  08:58:45  Detected chipset: DB2020
  08:58:45  Boot mode: EROM
  08:58:45  EROM version: R3A022      prgCXC1250616_EROM_DB2020_HB106GENERIC_FOTA_SIMLOCK_FLAFLA_SIBLEY_SEMCUSB
  08:58:45  Initializing flash files...
  08:58:49  Sending loader...
  08:58:49  About to flash 45 MB of data…
  09:04:30  Sending loader...
  09:04:32  System starting up...
  09:04:32  GDFS starting up...
  09:04:46  FS starting up...
  09:05:17  FS data uploading...
! 09:05:27  1. Please disconnect battery and cable from the phone!
! 09:05:28  2. Turn on the phone with inserted test card or sim card for which is the phone locked
! 09:05:28  3. Wait to customize finish
! 09:05:28  4. Turn off the phone
! 09:05:28  5. Please connect the phone while holding its C button…
  09:07:08  Connecting via SEMC USB Flash Device (USB1)…
  09:07:08  Device driver version: 1.1.0.12
  09:07:08  Device driver date: 9-25-2006
  09:07:08  Connecting to the baseband CPU...
  09:07:08  Entering baseband CPU service mode...
  09:07:08  Detected chipset: DB2020
  09:07:08  Boot mode: EROM
  09:07:08  EROM version: R3A022      prgCXC1250616_EROM_DB2020_HB106GENERIC_FOTA_SIMLOCK_FLAFLA_SIBLEY_SEMCUSB
  09:07:08  Sending loader...
  09:07:09  Sending loader...
  09:07:10  Sending loader...
  09:07:11  System starting up...
  09:07:11  GDFS starting up...
  09:07:27  FS starting up...
  09:07:30  FS data uploading...
! 09:07:45  1. Please disconnect battery and cable from the phone!
! 09:07:45  2. Turn on the phone with inserted test card or sim card for which is the phone locked
! 09:07:45  3. Connect the phone again
! 09:07:45  4. If asked, Install phone drivers
! 09:07:45  5. Choose 'PHONE MODE' in the phone
! 09:08:41  After choosing 'PHONE MODE' press the Ready button
  09:08:45  Connecting via SEMC WMC Device (COM9, COM8)…
  09:08:45  Device driver version: 4.34.0.2705
  09:08:45  Device driver date: 5-1-2006
! 09:08:59  1. Please disconnect battery and cable from the phone!
! 09:08:59  2. Please connect the phone while holding its C button…
  09:09:06  Connecting via SEMC USB Flash Device (USB1)…
  09:09:06  Device driver version: 1.1.0.12
  09:09:06  Device driver date: 9-25-2006
  09:09:06  Connecting to the baseband CPU...
  09:09:06  Entering baseband CPU service mode...
  09:09:06  Detected chipset: DB2020
  09:09:06  Boot mode: EROM
  09:09:06  EROM version: R3A022      prgCXC1250616_EROM_DB2020_HB106GENERIC_FOTA_SIMLOCK_FLAFLA_SIBLEY_SEMCUSB
  09:09:06  Sending loader...
  09:09:07  Sending loader...
  09:09:08  About to flash 1 MB of data…
  09:09:26  Done.
! 09:09:26  Please disconnect battery and cable from the phone!
The Following User Says Thank You to joe cellular For This Useful Post:
Old 06-14-2008, 10:41   #8 (permalink)
Member: 143802
Sonork: 100.1585023
Thanks Meter: 15
K610i successfully done
  14:51:01  SE A1 Java Unlocker v1.02 by Cruiser Team
  14:51:01  Initializing...
! 14:51:01  1. Choose the phone model
! 14:51:01  2. Select main firmware flash file (*.a1sw)
! 14:51:01  3. Select raw FS flash file (*.a1fs)
! 14:51:01  4. Please connect the phone while holding its C button…
  14:51:39  Connecting via SEMC USB Flash Device (USB1)…
  14:51:39  Device driver version: 2.0.0.4
  14:51:39  Device driver date: 9-12-2007
  14:51:39  Connecting to the baseband CPU...
  14:51:39  Entering baseband CPU service mode...
  14:51:40  Detected chipset: DB2020
  14:51:40  Boot mode: EROM
  14:51:40  EROM version: R3A016      prgCXC1250487_EROM_DB2020_THELMA_MIWA_RIKO_FOTA_SIMLOCK_FLAFLA_SIBLEY_SEMCUSB
  14:51:40  Initializing flash files...
  14:51:43  Sending loader...
  14:51:44  Sending loader...
  14:51:44  About to flash 37 MB of data…
  14:56:19  Sending loader...
  14:56:20  System starting up...
  14:56:20  GDFS starting up...
  14:56:36  FS starting up...
  14:56:48  FS data uploading...
! 14:56:58  1. Please disconnect battery and cable from the phone!
! 14:56:58  2. Turn on the phone with inserted test card or sim card for which is the phone locked
! 14:56:58  3. Wait to customize finish
! 14:56:58  4. Turn off the phone
! 14:56:58  5. Please connect the phone while holding its C button…
  15:02:48  Connecting via SEMC USB Flash Device (USB1)…
  15:02:48  Device driver version: 2.0.0.4
  15:02:48  Device driver date: 9-12-2007
  15:02:48  Connecting to the baseband CPU...
  15:02:48  Entering baseband CPU service mode...
  15:02:48  Detected chipset: DB2020
  15:02:48  Boot mode: EROM
  15:02:48  EROM version: R3A016      prgCXC1250487_EROM_DB2020_THELMA_MIWA_RIKO_FOTA_SIMLOCK_FLAFLA_SIBLEY_SEMCUSB
  15:02:48  Sending loader...
  15:02:49  Sending loader...
  15:02:50  System starting up...
  15:02:50  GDFS starting up...
  15:03:10  FS starting up...
  15:03:13  FS data uploading...
! 15:03:27  1. Please disconnect battery and cable from the phone!
! 15:03:27  2. Turn on the phone with inserted test card or sim card for which is the phone locked
! 15:03:27  3. Connect the phone again
! 15:03:27  4. If asked, Install phone drivers
! 15:03:27  5. Choose 'PHONE MODE' in the phone
! 15:05:13  After choosing 'PHONE MODE' press the Ready button
  15:05:19  Connecting via SEMC WMC Device (COM35, COM34)…
  15:05:19  Device driver version: 4.40.2.0
  15:05:19  Device driver date: 4-3-2007
! 15:05:30  1. Please disconnect battery and cable from the phone!
! 15:05:30  2. Please connect the phone while holding its C button…
  15:05:47  Connecting via SEMC USB Flash Device (USB1)…
  15:05:47  Device driver version: 2.0.0.4
  15:05:47  Device driver date: 9-12-2007
  15:05:47  Connecting to the baseband CPU...
  15:05:47  Entering baseband CPU service mode...
  15:05:48  Detected chipset: DB2020
  15:05:48  Boot mode: EROM
  15:05:48  EROM version: R3A016      prgCXC1250487_EROM_DB2020_THELMA_MIWA_RIKO_FOTA_SIMLOCK_FLAFLA_SIBLEY_SEMCUSB
  15:05:48  Sending loader...
  15:05:49  About to flash 1 MB of data…
  15:06:07  Done.
! 15:06:07  Please disconnect battery and cable from the phone!
Old 06-16-2008, 13:29   #9 (permalink)
Member: 111730
Thanks Meter: 118
z310i unlocked succefully with SE A1 Java Unlocker
  13:12:48  SE A1 Java Unlocker v1.02 by Cruiser Team
  13:12:48  Initialisation en cours…
! 13:12:48  1. Choisir le model du telephone
! 13:12:48  2. Selectionner le principal fichier flash firmware(*.a1sw)
! 13:12:48  3. Selectionner la ligne FS du fichier flash (*.a1sw)
! 13:12:48  4. Connecter le telephone en maintenant le bouton C…
  13:13:48  Se connecte via Generic EMP USB Flash Device (USB1)…
  13:13:48  Device driver version: 1.1.0.12
  13:13:48  Device driver date: 9-25-2006
  13:13:48  Connexion a la Baseband CPU en cours…
  13:13:48  Baseband CPU service mode entrant…
  13:13:49  Chipset detecte: PNX5230
  13:13:49  Boot mode: EROM
  13:13:49  EROM version: R4A012      prgCXC1250596_EROM_PNX5230_ALVA_FOTA_SIMLOCK_FLAFLA_SIBLEY_SEMCUSB
  13:13:49  Initializing flash files...
  13:13:59  Envoi du loader en cours…
  13:14:00  Envoi du loader en cours…
  13:14:00  Pret a flasher 31 le MB du data...
  13:17:19  Envoi du loader en cours…
  13:17:21  System starting up...
  13:17:21  GDFS starting up...
  13:17:26  FS starting up...
  13:17:43  FS data uploading...
! 13:17:55  1. Deconnecter la batterie et le cable du telephone!
! 13:17:55  2. Turn on the phone with inserted test card or sim card for which is the phone locked
! 13:17:55  3. Wait to customize finish
! 13:17:55  4. Turn off the phone
! 13:17:55  5. Connecter le telephone en maintenant le bouton C…
  13:20:11  Se connecte via Generic EMP USB Flash Device (USB1)…
  13:20:11  Device driver version: 1.1.0.12
  13:20:11  Device driver date: 9-25-2006
  13:20:11  Connexion a la Baseband CPU en cours…
  13:20:11  Baseband CPU service mode entrant…
  13:20:12  Chipset detecte: PNX5230
  13:20:12  Boot mode: EROM
  13:20:12  EROM version: R4A012      prgCXC1250596_EROM_PNX5230_ALVA_FOTA_SIMLOCK_FLAFLA_SIBLEY_SEMCUSB
  13:20:12  Envoi du loader en cours…
  13:20:13  Envoi du loader en cours…
  13:20:16  System starting up...
  13:20:16  GDFS starting up...
  13:20:22  FS starting up...
  13:20:22  FS data uploading...
! 13:20:37  1. Deconnecter la batterie et le cable du telephone!
! 13:20:37  2. Turn on the phone with inserted test card or sim card for which is the phone locked
! 13:20:37  3. Connect the phone again
! 13:20:37  4. If asked, Install phone drivers
! 13:20:37  5. Choose 'PHONE MODE' in the phone
! 13:21:33  After choosing 'PHONE MODE' press the Ready button
  13:23:12  Se connecte via SEMC WMC Device (COM15, COM14)…
  13:23:12  Device driver version: 4.38.6.1
  13:23:12  Device driver date: 9-19-2006
! 13:23:23  1. Deconnecter la batterie et le cable du telephone!
! 13:23:23  2. Connecter le telephone en maintenant le bouton C…
  13:23:38  Se connecte via Generic EMP USB Flash Device (USB1)…
  13:23:38  Device driver version: 1.1.0.12
  13:23:38  Device driver date: 9-25-2006
  13:23:38  Connexion a la Baseband CPU en cours…
  13:23:38  Baseband CPU service mode entrant…
  13:23:39  Chipset detecte: PNX5230
  13:23:39  Boot mode: EROM
  13:23:39  EROM version: R4A012      prgCXC1250596_EROM_PNX5230_ALVA_FOTA_SIMLOCK_FLAFLA_SIBLEY_SEMCUSB
  13:23:39  Envoi du loader en cours…
  13:23:39  Pret a flasher 1 le MB du data...
  13:23:55  Effectue.
! 13:23:55  Deconnecter la batterie et le cable du telephone!
Old 06-17-2008, 11:39   #10 (permalink)
Member: 271980
Sonork: 100.1573370
Thanks Meter: 227
Smile Successful Unlock K800i Cid53 with A1JavaUnlocker v1.02
13:22:04 SE A1 Java Unlocker v1.02 by Cruiser Team
13:22:04 Initializing...
! 13:22:04 1. Choose the phone model
! 13:22:04 2. Select main firmware flash file (*.a1sw)
! 13:22:04 3. Select raw FS flash file (*.a1fs)
! 13:22:04 4. Please connect the phone while holding its C button…
13:22:22 Connecting via SEMC USB Flash Device (USB3)…
13:22:22 Device driver version: 1.0.0.8
13:22:22 Device driver date: 3-30-2006
13:22:22 Connecting to the baseband CPU...
13:22:22 Entering baseband CPU service mode...
13:22:23 Detected chipset: DB2020
13:22:23 Boot mode: EROM
13:22:23 EROM version: R3A022 prgCXC1250616_EROM_DB2020_HB106GENERIC_FOTA_SIMLOC K_FLAFLA_SIBLEY_SEMCUSB
13:22:23 Initializing flash files...
13:22:30 Sending loader...
13:22:30 About to flash 45 MB of data…
13:28:34 Sending loader...
13:28:35 System starting up...
13:28:35 GDFS starting up...
13:28:59 FS starting up...
13:29:06 FS data uploading...
! 13:29:16 1. Please disconnect battery and cable from the phone!
! 13:29:16 2. Turn on the phone with inserted test card or sim card for which is the phone locked
! 13:29:16 3. Wait to customize finish
! 13:29:16 4. Turn off the phone
! 13:29:16 5. Please connect the phone while holding its C button…
13:33:01 Connecting via SEMC USB Flash Device (USB3)…
13:33:01 Device driver version: 1.0.0.8
13:33:01 Device driver date: 3-30-2006
13:33:01 Connecting to the baseband CPU...
13:33:01 Entering baseband CPU service mode...
13:33:02 Detected chipset: DB2020
13:33:02 Boot mode: EROM
13:33:02 EROM version: R3A022 prgCXC1250616_EROM_DB2020_HB106GENERIC_FOTA_SIMLOC K_FLAFLA_SIBLEY_SEMCUSB
13:33:02 Sending loader...
13:33:04 System starting up...
13:33:04 GDFS starting up...
13:33:20 FS starting up...
13:33:26 FS data uploading...
! 13:33:41 1. Please disconnect battery and cable from the phone!
! 13:33:41 2. Turn on the phone with inserted test card or sim card for which is the phone locked
! 13:33:41 3. Connect the phone again
! 13:33:41 4. If asked, Install phone drivers
! 13:33:41 5. Choose 'PHONE MODE' in the phone
! 13:34:47 After choosing 'PHONE MODE' press the Ready button
13:35:08 Connecting via SEMC WMC Device (COM16, COM15)…
13:35:08 Device driver version: 4.34.0.2705
13:35:08 Device driver date: 4-28-2006
! 13:35:20 1. Please disconnect battery and cable from the phone!
! 13:35:20 2. Please connect the phone while holding its C button…
13:35:34 Connecting via SEMC USB Flash Device (USB3)…
13:35:34 Device driver version: 1.0.0.8
13:35:34 Device driver date: 3-30-2006
13:35:34 Connecting to the baseband CPU...
13:35:34 Entering baseband CPU service mode...
13:35:35 Detected chipset: DB2020
13:35:35 Boot mode: EROM
13:35:35 EROM version: R3A022 prgCXC1250616_EROM_DB2020_HB106GENERIC_FOTA_SIMLOC K_FLAFLA_SIBLEY_SEMCUSB
13:35:35 Sending loader...
13:35:36 Sending loader...
13:35:36 About to flash 1 MB of data…
13:35:54 Done.
! 13:35:54 Please disconnect battery and cable from the phone!
Old 06-17-2008, 20:29   #11 (permalink)
Member: 271980
Sonork: 100.1573370
Thanks Meter: 227
Succesfully unlock w200 with A1javaUnlocker
22:09:56 SE A1 Java Unlocker v1.02 by Cruiser Team
22:09:56 Initializing...
! 22:09:56 1. Choose the phone model
! 22:09:56 2. Select main firmware flash file (*.a1sw)
! 22:09:56 3. Select raw FS flash file (*.a1fs)
! 22:09:56 4. Please connect the phone while holding its C button…
22:11:30 Connecting via SEMC USB Flash Device (USB3)…
22:11:30 Device driver version: 1.0.0.8
22:11:30 Device driver date: 3-30-2006
22:11:30 Connecting to the baseband CPU...
22:11:30 Entering baseband CPU service mode...
22:11:31 Detected chipset: DB2012
22:11:31 Boot mode: EROM
22:11:31 EROM version: R3A022 prgCXC1250729_EROM_DB2010_MELINDA_FOTA_SIMLOCK_FLA FLA_SIBLEY_SEMCUSB
22:11:31 Initializing flash files...
22:11:34 Sending loader...
22:11:35 About to flash 29 MB of data…
22:15:39 Sending loader...
22:15:42 System starting up...
22:15:42 GDFS starting up...
22:16:03 FS starting up...
22:16:30 FS data uploading...
! 22:16:41 1. Please disconnect battery and cable from the phone!
! 22:16:41 2. Turn on the phone with inserted test card or sim card for which is the phone locked
! 22:16:41 3. Wait to customize finish
! 22:16:41 4. Turn off the phone
! 22:16:41 5. Please connect the phone while holding its C button…
22:19:52 Connecting via SEMC USB Flash Device (USB3)…
22:19:52 Device driver version: 1.0.0.8
22:19:52 Device driver date: 3-30-2006
22:19:52 Connecting to the baseband CPU...
22:19:52 Entering baseband CPU service mode...
22:19:52 Detected chipset: DB2012
22:19:52 Boot mode: EROM
22:19:52 EROM version: R3A022 prgCXC1250729_EROM_DB2010_MELINDA_FOTA_SIMLOCK_FLA FLA_SIBLEY_SEMCUSB
22:19:52 Sending loader...
22:19:53 Sending loader...
22:19:55 System starting up...
22:19:55 GDFS starting up...
22:20:22 FS starting up...
22:20:35 FS data uploading...
! 22:20:50 1. Please disconnect battery and cable from the phone!
! 22:20:50 2. Turn on the phone with inserted test card or sim card for which is the phone locked
! 22:20:50 3. Connect the phone again
! 22:20:50 4. If asked, Install phone drivers
! 22:20:50 5. Choose 'PHONE MODE' in the phone
! 22:21:52 After choosing 'PHONE MODE' press the Ready button
22:25:35 Connecting via SEMC WMC Device (COM7, COM6)…
22:25:35 Device driver version: 4.34.0.2705
22:25:35 Device driver date: 10-24-2006
! 22:25:47 1. Please disconnect battery and cable from the phone!
! 22:25:47 2. Please connect the phone while holding its C button…
22:25:56 Connecting via SEMC USB Flash Device (USB3)…
22:25:56 Device driver version: 1.0.0.8
22:25:56 Device driver date: 3-30-2006
22:25:56 Connecting to the baseband CPU...
22:25:56 Entering baseband CPU service mode...
22:25:56 Detected chipset: DB2012
22:25:56 Boot mode: EROM
22:25:56 EROM version: R3A022 prgCXC1250729_EROM_DB2010_MELINDA_FOTA_SIMLOCK_FLA FLA_SIBLEY_SEMCUSB
22:25:56 Sending loader...
22:25:57 Sending loader...
22:25:57 About to flash 1 MB of data…
22:26:18 Done.
! 22:26:18 Please disconnect battery and cable from the phone!
Thanks to Mainboard for best help
Old 06-17-2008, 20:43   #12 (permalink)
Mainboard's Avatar
Member: 25671
Thanks Meter: 719
guys, from now please post logs only from version 1.10, thanks!
The Following User Says Thank You to Mainboard For This Useful Post:
Old 06-17-2008, 22:39   #13 (permalink)
renaldo2's Avatar
Member: 745550
Thanks Meter: 117
Thank you Mainboard . I have unlock successful 8 w200 from O2.
CID52
Old 06-18-2008, 02:29   #14 (permalink)
.ALDAGSM.'s Avatar
Member: 627885
Thanks Meter: 27
K800i CID53 using version 1.10 without flashing
Very fast!!
  21:33:18  SE A1 Java Unlocker v1.10 by Cruiser Team
  21:33:18  Initializing...
! 21:33:18  1. Choose the phone model
! 21:33:18  2. Select main firmware flash file (*.a1sw)
! 21:33:18  3. Select raw FS flash file (*.a1fs)
! 21:33:18  4. Please connect the phone while holding its C button…
  21:40:57  Connecting via SEMC USB Flash Device (USB2)…
  21:40:57  Device driver version: 2.0.0.4
  21:40:57  Device driver date: 9-12-2007
  21:40:58  Connecting to the baseband CPU...
  21:40:58  Entering baseband CPU service mode...
  21:40:58  Detected chipset: DB2020
  21:40:58  Boot mode: EROM
  21:40:58  EROM version: R3A022      prgCXC1250616_EROM_DB2020_HB106GENERIC_FOTA_SIMLOCK_FLAFLA_SIBLEY_SEMCUSB
  21:40:58  Initializing flash files...
  21:41:04  Sending loader...
  21:41:06  System starting up...
  21:41:06  GDFS starting up...
  21:41:20  FS starting up...
  21:41:32  FS data uploading...
! 21:41:41  1. Please disconnect battery and cable from the phone!
! 21:41:41  2. Turn on the phone with inserted test card or sim card for which is the phone locked
! 21:41:41  3. Connect the phone again
! 21:41:41  4. If asked, Install phone drivers
! 21:41:41  5. Choose 'PHONE MODE' in the phone
! 21:42:38  After choosing 'PHONE MODE' press the 'Ready' button
  21:42:44  Connecting via SEMC WMC Device (COM54, COM53)…
  21:42:44  Device driver version: 4.40.2.0
  21:42:44  Device driver date: 4-3-2007
! 21:42:51  1. Please disconnect battery and cable from the phone!
! 21:42:51  2. Please connect the phone while holding its C button…
  21:43:12  Connecting via SEMC USB Flash Device (USB2)…
  21:43:12  Device driver version: 2.0.0.4
  21:43:12  Device driver date: 9-12-2007
  21:43:13  Connecting to the baseband CPU...
  21:43:13  Entering baseband CPU service mode...
  21:43:14  Detected chipset: DB2020
  21:43:14  Boot mode: EROM
  21:43:14  EROM version: R3A022      prgCXC1250616_EROM_DB2020_HB106GENERIC_FOTA_SIMLOCK_FLAFLA_SIBLEY_SEMCUSB
  21:43:14  Sending loader...
  21:43:15  Sending loader...
  21:43:15  About to flash 1 MB of data…
  21:43:28  Done.
! 21:43:28  1. Please disconnect battery and cable from the phone!
! 21:43:28  2. Turn on the phone with inserted test card or sim card for which is the phone locked
! 21:43:28  3. Go to Entertainment and select Games.
! 21:43:28  4. Delete executor file.
! 21:43:28  5. Turn off the phone
Old 06-18-2008, 10:24   #15 (permalink)
Member: 82201
Sonork: 1576982
Thanks Meter: 32
SUCCESSFUL UNLOCK K320 THX CRUISER TEAM
  11:05:51  SE A1 Java Unlocker v1.10 by Cruiser Team
  11:05:51  Initializing...
! 11:05:51  1. Choose the phone model
! 11:05:51  2. Select main firmware flash file (*.a1sw)
! 11:05:51  3. Select raw FS flash file (*.a1fs)
! 11:05:51  4. Please connect the phone while holding its C button…
  11:06:06  Connecting via SEMC USB Flash Device (USB1)…
  11:06:06  Device driver version: 1.1.0.12
  11:06:06  Device driver date: 9-25-2006
  11:06:06  Connecting to the baseband CPU...
  11:06:06  Entering baseband CPU service mode...
  11:06:06  Detected chipset: DB2012
  11:06:06  Boot mode: EROM
  11:06:06  EROM version: R3A017      prgCXC1250692_EROM_DB2010_MARTINA_FOTA_FLAFLA_SIBLEY_SEMCUSB
  11:06:06  Initializing flash files...
  11:06:10  Sending loader...
  11:06:11  Sending loader...
  11:06:11  About to flash 29 MB of data…
  11:09:45  Sending loader...
  11:09:48  System starting up...
  11:09:48  GDFS starting up...
  11:10:08  FS starting up...
  11:10:34  FS data uploading...
! 11:10:39  1. Please disconnect battery and cable from the phone!
! 11:10:39  2. Turn on the phone with inserted test card or sim card for which is the phone locked
! 11:10:39  3. Wait to customize finish
! 11:10:39  4. Turn off the phone
! 11:10:39  5. Please connect the phone while holding its C button…
  11:13:59  Connecting via SEMC USB Flash Device (USB1)…
  11:13:59  Device driver version: 1.1.0.12
  11:13:59  Device driver date: 9-25-2006
  11:13:59  Connecting to the baseband CPU...
  11:13:59  Entering baseband CPU service mode...
  11:14:00  Detected chipset: DB2012
  11:14:00  Boot mode: EROM
  11:14:00  EROM version: R3A017      prgCXC1250692_EROM_DB2010_MARTINA_FOTA_FLAFLA_SIBLEY_SEMCUSB
  11:14:00  Sending loader...
  11:14:03  System starting up...
  11:14:03  GDFS starting up...
  11:14:26  FS starting up...
  11:14:35  FS data uploading...
! 11:14:44  1. Please disconnect battery and cable from the phone!
! 11:14:44  2. Turn on the phone with inserted test card or sim card for which is the phone locked
! 11:14:44  3. Connect the phone again
! 11:14:44  4. If asked, Install phone drivers
! 11:14:44  5. Choose 'PHONE MODE' in the phone
! 11:15:56  After choosing 'PHONE MODE' press the 'Ready' button
  11:15:58  Connecting via SEMC WMC Device (COM58, COM57)…
  11:15:58  Device driver version: 4.34.0.2705
  11:15:58  Device driver date: 7-13-2006
! 11:16:05  1. Please disconnect battery and cable from the phone!
! 11:16:05  2. Please connect the phone while holding its C button…
  11:16:15  Connecting via SEMC USB Flash Device (USB1)…
  11:16:15  Device driver version: 1.1.0.12
  11:16:15  Device driver date: 9-25-2006
  11:16:15  Connecting to the baseband CPU...
  11:16:15  Entering baseband CPU service mode...
  11:16:15  Detected chipset: DB2012
  11:16:15  Boot mode: EROM
  11:16:15  EROM version: R3A017      prgCXC1250692_EROM_DB2010_MARTINA_FOTA_FLAFLA_SIBLEY_SEMCUSB
  11:16:15  Sending loader...
  11:16:16  Sending loader...
  11:16:17  About to flash 1 MB of data…
  11:16:31  Done.
! 11:16:31  1. Please disconnect battery and cable from the phone!
! 11:16:31  2. Turn on the phone with inserted test card or sim card for which is the phone locked
! 11:16:31  3. Go to Entertainment and select Games.
! 11:16:31  4. Delete executor file.
! 11:16:31  5. Turn off the phone
Post here successfully unlocked phones by Nero-Key mikolaj NEROkey 45 11-23-2011 20:48
Please Post Here SuccessFully Unlock Phones With Samsung Rocker MOBIL CLINIC Rocker Dongle (By Legija) 1 11-22-2009 20:24
Please Post Here SuccessFully Unlock Phones With Spt-Box MOBIL CLINIC SPT BOX 1 11-01-2009 18:41
Post here Successfully unlocked phones by free patches reactos Sony Ericsson 3 01-10-2008 22:06
Page generated in 0.32808 seconds with 9 queries
