12-16-2005, 00:12 | #1 (permalink) |
Insane Poster Join Date: May 2004 Age: 54
Member: 64416 Status: Offline Thanks Meter: 0 | Problem with P900 Just got a used p900 that had a glass of water over it. When power on the phone, the display lightens and nothing more happends. When I connect the phone to cruiser, and click "attach to phone", the phone starts up normaly and is apparently working perfekt. I would like to flash new sw into it, but everytime I push the "attach to phone" button, the phone starts up. Do I need to use TP to be able to boot it up with cruiser ? BR Totle |
12-16-2005, 00:23 | #2 (permalink) |
No Life Poster Join Date: Oct 2003 Location: Auckland, New Zealand
Member: 42570 Status: Offline Thanks Meter: 11 | Phone starting up when it should be booting indicates problems with the connector or your cable. Seeing as how you've said it had a glass of water tipped on it, I'd be looking at the connector. Open the phone and check the connector for corrosion/damage etc. Once you've fixed that problem, I'd also be looking at the battery as being faulty based on what you'd said. |
problem with nokia 6234 | pachicoo | Universalbox | 2 | 03-29-2010 15:19 |
Problem with p900 to p910 update | nerofight | Cruiser Suite | 0 | 08-19-2006 11:36 |
PDA Flash Problem with P900 | kasalapi | Twisterflasher | 3 | 11-24-2004 12:47 |
Problems with p900 when changing IMEI | lfc4eva | Sony Ericsson | 2 | 08-06-2004 13:37 |
