05-16-2006, 09:33 | #1 (permalink) |
No Life Poster Join Date: Apr 2005 Location: PAKISTAN Age: 45
Member: 133436 Status: Offline Sonork: 100.1577364 Thanks Meter: 191 | Problem Unlocking Z300i Thnxxx in Advance Take Care ENJOY |
05-16-2006, 11:29 | #3 (permalink) |
Member: 133436 Status: Offline Sonork: 100.1577364 Thanks Meter: 191 | i tried it says Not Allowed on every code. and still saying incorrect sim card after restart thnxxx for reply Take Care ENJOY |
05-16-2006, 11:40 | #5 (permalink) | |
Member: 133436 Status: Offline Sonork: 100.1577364 Thanks Meter: 191 | Quote:
How its damaged when i use <**< it says locks are open not closed. i think i need to lock it again and then unlock buy there is no such feautre available to lock it back. thnxxx for reply Take Care ENJOY | |
08-06-2006, 17:24 | #7 (permalink) |
No Life Poster Join Date: Feb 2006 Location: URL - UnlockRepairLandia Age: 41
Member: 236218 Status: Offline Thanks Meter: 35 | Unlock Red CID49 Phones without TP Older phones with unlocked EROM area: • Connect the phone to the cable and select Normal boot. • Attach Cruiser to the phone, • Go to the Security RSA page and replace the certificate by Brown CID49. Remove battery when asked by Cruiser. IF this process fails, the phone has a locKed-down EROM area and therefore it cannot be converted to Brown CID49, • Now press the Direct Unlock button. Newer phones with locked-down EROM area: • Be sure to have installed the latest Cruiser firmware restora! package from our support area. • Connect the phone to the cable and select Normal boot. • Attach Cruiser to the phone. • Go to the Security RSA page and press the Unlock RSA button. Remove battery when asked by Cruser. This will overwnte part of main firmware by special code thus causing the phone to appear "dead". • Reinsert the battery and reattach Cruiser to the phone. • Go to the Security RSA page anc press the Restore firmware button. Cruiser will search for a restore file then. If it cannot be found, you will also have to reflash main FW and raw FS and to customize the phone. • Now go to the Locks page and press the Direct unlock button. Remember, if you encounter any new firmware it is wise to make a security zone backup too (or a full GDFS backup). Note: You may use the Ctrt-A key combination to attach the phone and the Ctrl-O key combination to turn the phone off. |
08-06-2006, 17:29 | #8 (permalink) |
Member: 236218 Status: Offline Thanks Meter: 35 | If you have problems to attach phone - connect the phone to cable without battery, press attach button, than insert battery. best regards mail0 |
08-09-2006, 14:20 | #9 (permalink) | |
No Life Poster Join Date: Jan 2002 Location: tunis,Tunisia Age: 54
Member: 8228 Status: Offline Sonork: 12399830 Thanks Meter: 136 | Quote:
Version 9.74 ready! [ --- Attach to Phone --- ] Connecting via Fighter USB Cable... Powering on the phone... Baseband chip ID: 0x9003 Protocol version: 2.0 Baudrate = 115200Bd Time spent entering bootstrap: 0s Initializing phone hardware... Baudrate = 115200Bd Sending applet... Waiting for acknowledge... All threads terminated. Script error: No response [9.74.729] i got always those error | |
08-09-2006, 19:59 | #10 (permalink) |
No Life Poster Join Date: Aug 2004 Location: US/DK/S
Member: 76964 Status: Offline Thanks Meter: 2 | List of stuff you can try: Check cables Clean connectors Lower speed Make sure battery is fully charged Check external power is really 3VDC, get fresh batteries if not Try with 9VDC external power, only use sparse, since 9VDC will reduce life of flash chip, but is ok for a one-timer Get new cables Downgrade to Cruiser 9.66 |
08-10-2006, 15:57 | #11 (permalink) | |
Script error: No response [9.74.729]or Script error: No response [9.66.729] | |
08-10-2006, 16:54 | #13 (permalink) |
Member: 8228 Status: Offline Sonork: 12399830 Thanks Meter: 136 | only when i try this phone or any other z300i , because i unlock many other se phone(w810;k750;w600i; etc ) and always success |
Problem Flashing Z300i with HWK | imran_qasim | HWK | 0 | 04-30-2007 13:42 |
urgent problem with z300i | gsm-tech1385 | Cruiser Suite | 0 | 07-18-2006 02:55 |
how to unlock Z300i with cruiser ????? | tfcell | Cruiser Suite | 2 | 03-13-2006 18:24 |
Unlock Z300i | mobelix | Sony Ericsson | 0 | 03-11-2006 12:18 |
Unlock Z300i... update? | Spalato | SonyEricsson (USB-Smart) | 0 | 02-17-2006 23:38 |
